PT Cruiser Electrical and Lighting Problems
in Chrysler
This is the place to work out solutions to electrical problems with your Cruiser.
I have a 2004 Touring Edition Pt Cruiser with 7,000 miles. I brought it in because it also was misfiring. The dealer updated the computer and installed new spark plugs because the old plugs would not work with the updated computer program. Your dealer should know what is wrong because this is a common problem with the PT's, though they might tell you they don't!!!
Frustrating.
Good luck with your problem...
Does anyone have a solution yet?
since this is happening to many at the same time, i wonder if the computer chip is signalling them to come on(much like my oil indicator after 3000 miles!). i have about 55000 on my car and have had no real problems(except for my replacement eagles of which ive had to rereplace 2 of in the last few weeks). will keep googling and see if i can find any other references.
http://www.recalldata.org/2001/39483.shtml
http://www.recalldata.org/2001/39484.shtml
http://www.recalldata.org/2001/39485.shtml
http://www.recalldata.org/2001/39486.shtml
Here was a list I found but I couldn't find free links to the info yet
Automotive Recall and Technical Service Bulletin Titles for 2001 Chrysler PT Cruiser L4-2.4L VIN B.
Safety Recalls
TSB Number & Issue Date TSB Title
D18 SEP 04 Recall - Power Steering Pressure Hose Replacement
B23 AUG 02 Recall - Fuel Pump Module Secondary Seal
957 NOV 00 Recall - Child Restraint, Owner's Manual Update
Service Bulletins
03-006-04 SEP 04 Drivetrain - Front Hub/Half Shaft Pop/Click Sound
23-034-04 SEP 04 Body - Front or Rear Bumper Fascia Discoloration
19-003-04A AUG 04 Steering - Steering Column Clicking Sound
18-020-04 MAY 04 Engine Controls - Rough Idle/Sag/3,000 RPM Surge
21-004-04 MAR 04 A/T - ATF Usage List
22-004-03 SEP 03 Wheels - Chrome Wheel Care
21-009-03 AUG 03 A/T - Diagnostic Teardown Procedure
24-003-03 MAY 03 A/C - System Sealer Usage Prohibition
08-012-03 APR 03 Alarm System - Inadvertent Siren Activation
08-010-03 APR 03 Interior - Seat Belt Cinch Bar Service
18-008-03 MAR 03 Engine Controls - Co-Pilot Support/Cable Selection
23-046-02 NOV 02 Interior - Non-U.S. Vehicles, Child Seat Anchorage
24-010-02 NOV 02 A/C - Performance Test Ports
24-009-02 OCT 02 A/C - System Leak Detection
08-008-02 JUN 02 Engine - No Start/No Crank Condition
18-020-02 JUN 02 Engine Controls - Flash Reprogramming Failure
23-015-02 APR 02 Outside Rearview Mirror - Glass Replacement
08-007-02 MAR 02 Keyless Entry - Programming Procedure
23-004-02 JAN 02 Front Window Regulator - Squeaks When Operated
08-028-01 DEC 01 Lighting - Moisture in Headlamps
08-037-00 DEC 01 Air Bag - Foam Rubber Pads Fall Off/Buzz or Rattle
08-025-01 NOV 01 Air Bag - On/Off Switches
18-027-01 NOV 01 Engine - Moderate To Severe Highway Speed Surge
19-009-01 OCT 01 Driver Airbag - Trim Cover Service
14-001-01A JUN 01 Fuel Gauge - Doesn't Register Full
23-010-01 JUN 01 Sunroof - Vibration/Flutter
08-013-01 JUN 01 Radio - Connector Repair Kit
08-010-01 MAY 01 Airbag/Clock Spring - Service
18-012-01 MAY 01 Generic Scan Tool - Reference Information
23-008-01 MAY 01 Body Exhauster - Ticking Noise In Passenger Compartment
09-003-01 MAY 01 Engine Oil - Additives/Supplements
24-005-01 APR 01 A/C System - Performance Test
18-009-01 MAR 01 EVAP System - Leak Detection Pump Operation
18-007-01 FEB 01 A/T - Surge/Sag/Shift Bump
23-003-01 FEB 01 FMVSS201 - Head Impact Safety Standards
08-006-00A DEC 00 Wiring - Revised Splicing Procedure
08-037-00 DEC 00 Driver's Airbag - Service Information
08-038-00 DEC 00 Restraint Systems - Service Precautions
23-036-00 NOV 00 Roof Rack Stanchion Cover - Loose /Missing
08-034-00 NOV 00 Tools - Relay Removal & Installation Tool
08-033-00 NOV 00 Sound System - ``Cold CD'' Fault Code Information
18-18-00 SEP 00 PCM - Driveability Problem Improvements
18-12-00 AUG 00 MIL - Revised Features for OBDII Readiness
19-02-00A JUL 00 Ignition Lock Cylinder - Service Precautions
23-26-00 JUL 00 Rear Seat - Left/Right Floor Latch Won't Release
26-07-00 JUL 00 Fuel System - Throttle Body Torque Specification Update
14-04-00 JUN 00 Fuel System - Engine Slow To Start
18-07-00 JUN 00 MIL ON - DTCs P0645, P1282, P1489, P1490, P1495 Set
18-04-00 JUN 00 MIL - Erroneous P0441 Evap Purge Flow Monitor Failure
23-22-00 MAY 00 B & C Pillar Appliques - Brown Haze or Discoloration
26-05-00 MAY 00 Steering/Suspension - Alignment Specification Update
23-16-00 APR 00 Left/Right Front Door Speaker - Buzz or Hum
23-14-00 APR 00 Cargo Net - Installation Instructions
08-14-00 APR 00 Fuel Gauge - Does Not Register Full
05-02-00 APR 00 Parking Brake Equalizer Assembly - Removal
08-04-00 FEB 00 Headlight Bulb - Part Numbers/Replacement Information
03-01-00 FEB 00 Driveshaft - Removal Information
07-004-00 JAN 00 A/T - Cooler Line Splice Kit
Recall Date: JUN 03, 2004
Component: STEERING:HYDRAULIC POWER ASSIST:HOSE, PIPING, AND CONNECTIONS
Potential Units Affected: 438391
Summary: ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH 2.4L NON-TURBOCHARGED ENGINES AND AUTOMATIC TRANSAXLES, THE POWER STEERING PRESSURE HOSE MAY CONTACT THE AUTOMATIC TRANSAXLE DIFFERENTIAL COVER, POTENTIALLY DAMAGING THE HOSE.
Consequence: POWER STEERING FLUID LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE CAN RESULT IN AN UNDERHOOD FIRE.
Remedy: DEALERS WILL INSPECT AND RELOCATE, OR REPLACE AS NECESSARY, THE POWER STEERING HOSE AND CONFIRM TORQUE OF THE HOSE FASTENER AT THE STEERING GEAR END. THE RECALL BEGAN ON SEPTEMBER 20, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes: DAIMLERCHRYSLER CORPORATION, D18
The woman I talked to was very nice and seemed interested/concerned. More importantly, she told me that as long as I hang onto the receipts, I can claim a reimbursement if there ever IS a recall issued for this. In doing so, having a case/file number, which is one thing you get by calling the above number, is helpful/important so I would definitely encourage folks to call.
I'll send an update if any once the car's back from the dealer.
PS - fwiw I'm apparently due for the PS hose recall as well while it's in there...
I'm pretty sure it's fixed as I had noticed liked some others that jiggling the headlight/foglamp control would/could turn the fog lamps on/off. The new switch does not behave this way(!). I'll drop a note if I do see the problem recur anytime soon and otherwise wait and hope to hear that maybe Chrysler issues a recall for it. I'm dreading that the new switch will fall prey to the same problem in a few years if it isn't recalled/fixed/redesigned...
I have added a new battery cable to the starter as per feedback on this forum and thought it worked but after a month I was unable to start again yesterday. When I try and jump the car battery it will just sit there and then for some reason it jump started after 10 trys.
It doesnt seem to be a battery are starter problem. Maybe a ignition switch?
Someone said something about the alarm system doing this. Does anyone know how to disconnect the alarm system? Any help PLEZ
Sunday, 12/4/05
Got up to go to church. Car wouldn’t start. Had car towed to Midas where they replaced battery and fixed battery cables on Monday, 12/5/05 ~$180.00
Tuesday, 12/13/05
My wife went to work. When she got there the car wouldn’t shut off. She came home. We took it to Midas and talked to our Mechanic, Virgil (store manager). He had us take it to New Country Dodge (Saratoga Springs, NY) to run specific diagnostics.
Wednesday, 12/14/05
Stopped at Donahue Motor Car (Ballston Spa, NY)and talked to Mike. Explained that our PT Cruiser was in the shop once again and we might be pursuing Lemon Law (purchased used vehicle with 80,000 miles on it 11/3/05 had it three days car wouldn’t start Monday 11/7/05 had it towed to Gil’s Garage in Burnt Hills, NY they had car and couldn’t find problem returned car to us that night we took it to a banquet when we returned home car wouldn’t shut off had Gil’s tow it Tuesday 11/8/05 they kept it for over a week without problem arising we sent info about ignition switch Tom at Donahue’s had car brought to Terry Morris where the ignition switch was replaced for $9). Mike explained that Tom would make good on any repairs and to keep receipts. :lemon:
New Country performed diagnostic. Couldn’t find any problems...manager said he wouldn’t charge us said he spent 2 hours on the Internet and couldn’t find anything about the problem guess he didn’t look hard enough. When we asked him what we should do if the car wouldn’t shut off again he had no clue. I said something about pulling fuse 11, which shuts off the engine and fuel pump, then he agreed. Seems he was giving us the company line not very computer literate not good when you’re the manager and use computers.
Saturday, 12/17/05
I needed a new key somehow mine got lost on Wednesday 12/14/05. Lowe’s made a new one ~ 10:00 am. Opens the doors. Unfortunately when I turned on engine it started then shut off. Put my wife’s key into ignition and it started. We got home.
Left to go shopping ~ 3:30 pm. My wife's key was in the ignition didn’t even leave the garage. Car started then shut off. I did the following: 1) Pulled fuse 11 (engine). Nothing happened when we turned key. 2) Pulled fuse 12 (PDC Relays LDP) this shut off the idiot lights but the car wouldn’t start. 3) Pulled fuse 10 (Cluster RKE) and car then started OK.
We got to our destination. My wife turned off car, pulled out the key BUT car was still running. I pulled fuse 11, which shut off the car Thank you Lord.
Sunday, 12/18/05
We went to a Christmas get together. When we were leaving, we unlocked the car with the remote and the idiot lights turned on. My wife started the car but it shut off after a couple of seconds. I did the following: 1) Pulled fuse 12 which shut off the idiot lights 2) Pulled fuse 10 which reset the cluster (except the check engine light stayed on). The car started and we returned home. Everything shut off OK
As you can see we are dealing with problems similar to yours. Any help we can get would be appreciated. Will continue posting our developments.
Dan V.
I have only 38,000 miles on this car.
Over the last 36 months my battery has gone out about every 9 months. each time battery has a burned out cell & can not be recharged.
car now has a Mopar battery #5 in it.
Dealer says it's just bad batteries. nothing wrong with car.
I disagree, there has to be something else causing this.
Any information will be appreciated. :confuse:
In trying to ORDER a switch for replacement, he found out they were backordered due to SO MANY of them going bad.
I waited about two weeks and he charged about $100. Thank goodness for the little guys. Knowing why the switch was backordered tells alot about my dealers service department.
Gene
