Infiniti G35 Climate Control Questions
Help someone....I have a 2003 Infiniti G35 and few days ago my econo. AC came on by itself and will not stop unless I turn the vehicle off. During the same time the audio shuts down, won't even come on. Has anyone had this problem?
Anyone get frustrated to the point of bring it in to the dealer and were they able to solve it???
Thanks for the info....will bring it up to my infinity dealer and check it out.
This link has both bulletins and recalls, I think the issue was a recall but it may have been a bulletin.
Here is the bulleting:
VOLUNTARY SERVICE CAMPAIGN 2003 INFINITI G35 SEDAN; AUDIO FINISHER CIRCUIT BOARD
On some model year 2003 G35 Sedans manufactured through August 21, 2002, the audio and temperature controls may not operate as expected. When using the audio equipment or the temperature controls, the unit may become inoperative. In some cases, this can be corrected by turning the ignition switch off and back on again. In other cases, the unit remains inoperative and requires service by an Infiniti technician. To prevent this condition, Infiniti has initiated a Voluntary Service Campaign to replace the audio finisher circuit board on these vehicles. Use Infiniti Net to confirm if a specific vehicle is affected by this service campaign (P3104).
Not sure what a voluntary service campaign is... Do they do the replacement of the circuit board free of charge? What was your experience?
sharkman
I checked the recall it appears that it only covers G35 Sedans and not the coupe. Is yours a sedan?
Willy
Infiniti Consumer Affairs
P.O. Box 685003
Franklin TN 37068-5003
800.662.6200
8:00 a.m. - 5:00 p.m. Eastern / Central Time / Pacific Time
Monday through Friday
They said they have had many reports on this issue and are in discussions with their engineers. If you get on the list and there is a recall they will reimburse you for the problem. PLEASE CALL!
