Visitor Agreement.
But, Langka will also work on clear touchup if you happen to use it for some other reason.
Craig
I've had the problem on several other occasions,(once when forgetting to put the gas cap back on until the day after I gassed up), but it has "settled down" after letting it run for a while.
The problem has happened enough that I do not believe that it is simply a matter of water in the gas line. I've always used a drygas product during our cold winters, and it doesn't seem to have made any difference with this particular problem.
all goes well, may end up settin' up shop!
srp
Put a small dab of Langka on the cloth and buff away. Old bedsheet cloth works best, or anything with a really tight weave.
Craig
How does the Langka stuff work? The website doesn't give much info. Is it some kind of abrasive?
Ken
John
great service.
srp
Chuck
Craig
Craig
Now, if I could only figure out a way to do something about the seatbelts.... :-(
fyi; never tried it myself.
Sorry if I wasn’t clear - I am still driving the Grapevine in my Passat 4Motion. See, I am just hoping the XT allows at least similar effortless driving. I have postponed my XT purchase until after I have relocated to the Bay Area (probably, much after, given the home prices there!).
Half-loaded and at 77mph, I get about 23-24mpg for the portion of the Bay Area <--> San Diego County trip that uses Valley gas, and 25-26mpg for the portion using non-Valley gas. On the grapevine itself, it can be as little as 10mpg going uphill, and then in the high 30s or more, going down.
I know about the trucks, I would never go 80mph there in full traffic. I have been mostly driving in rather light traffic. In addition to being steep and full with slow trucks, the switchbacks are pretty tight in some places; you need a good suspension and good tires to make it through with the wide margin of safety that I prefer.
If you are bothered by the fuel costs of the XT, I think the X(S) should be just fine for you. Especially the MT (forgot your preference). If you were living in Colorado or some other places, I would clearly recommend the XT (given to the altitude).
Just to make your decision more complicated, though, I would like to see a mileage report for the same hills in these two cars. A number of small-engine cars use quite a lot of gas when pressed. I have rented Suzukis and Dodges in NM and CO, and neither one of them made it into the 20s on average in the mountains.
Grapevine at 90 plus on Friday nights – yeah, I have seen that. People showing off their SLKs and Porsches and BMWs, and kids in their Civics following (on the downhill parts, that is).
- D.
Larry
Now, I set the temp at 72 in AUTO mode (A/C off) - the cabin warms up quickly, does not noticeably overshoot the desired temp, and stays at a level temp throughout my commute. It's a night and day difference from before.
Why couldn't Subaru do this in the first place? Almost every other car make with climate control has this setup built in.
Anyone using one?
srp
-Frank P.
What makes this interesting is something I read in the auto-climate control diagnostic section a while ago. Basically, if you were to hold something small and really lightweight in front of that opening, you should see it move in one direction or another. Can't remember if its in or out, but the implication is that there should be something down there moving air already.
It would seem whatever it is, especially if its supposed to pull in the air, is not strong enough to get by without a powered assist.
Just for the yucks I'll look at the 04 climate control diagnostics I downloaded from the Subaru site over the holidays and post what the manual says its supposed to do.
Thanks for this info, as soon as the weather warms up, I'll be looking at making a minor mod to that area of the dash.
Larry
-Frank P.
The fan I installed blows the air into the sensor. I don't think there is anything in there now that pulls air in, Just a sensor sitting in a hollow plastic tube - I couldn't find a factory fan in there. Let me know what the diagnostics manual says - I'm very curious.
Sam
Ken
-juice
thanks,
Kyle
Not sure if they'll be able to swing getting the new Outback since it just debuted in Chicago.
-Dennis
http://www.oldforester.com/accolades2004/default.asp
;-) <burp>
-srp
-juice
Wake Up and Drive!
-s(hnokkered)rp
Is anyone here of like mind, has heard the same, or know otherwise?
Still, the stuff was NASTY, it looked like clowdy chocolate. New brake fluid is a clear yellow.
Brake fluid is hygroscopic, i.e. it absorbs moisture. Plus any oxydation within the system will discolor it, as with my Miata.
I'll be bleeding my brakes soon as it's warm. ;-)
-juice
Note: edited for spelling
-juice
Owen
-juice
But we know what you mean!
John
The Biggest drawback is what you would think was it's biggest asset! Sure it has a MUCH higher boiling temp, but it does NOT absorb water!
Water, or moisture will usually find it's way into the 'sealed' braking system either thru damaged seals or just osmosis.
Standard brake fluid will disperse this thruout and with regular replacement cause no further damage.
Synthetic or silicone can not absorb it and where ever it accumulates, it causes unequal pressure (spongy pedal) or rust / corrosion damage.
Since the late 80's, I have replaced my fluid every 60K and have yet to have a spongy pedal or frozen caliper.
My $.02 and experiences.
-juice
-Frank P.
Did you know that "William" becomes "Guilherme"? How whacked is that?
-juice
So it slightly jerks only that once when I'm shifting into R. Jerking is always the same, no matter, what a way it passes - P>R or D>N>R. No jerking in D at all. Is it normal for the tranny? Could be a reason of jerking the fluid pressure, which appears when the fluid is getting into the reverse canal, as my dealer says? Thanks in advance,
kind regards.
