BMW Z4 Electrical Problems
Share questions andanswers about electrical issues.
1. My driverside door has spontaneously opened 3 times. No seat belt was stuck in the door (it was latched), I didn't unconsciously open the door and the door was not locked. I don't lean on the door. The last time this happened I was doing 80 on I-95 straightaway. You can hear it unlatch and must swing the door open and pull it close.
2. The interior dash "alarm" started beeping for reasons unknown to me. I had trouble getting the car unlocked and had to open/close it with the key several times. The seatbelt was NOT stuck in the door. I opened and closed all the doors and restarted the car 4 times. I had to drive 5 miles with it beeping, then left it (still beeping) while parked and no key in ignition. Came back in 2 hours and it had stopped.
CLOSED
I know the vehicles are different but could the problem be similar?
Many Z4 owners seem to experience this issue, if one goes by reading various forums on the 'net. Certainly NHTSA has heard about it time and again.
BMW's response to this problem (I asked) is that they don't support the addition of any third-party products.
I have the exact same issue with my Z4 (2003) and I nearly had 2 accidents already... BMW did reprogram the electric steering chip mechanism but I am still experiencing the same problem. This is very very dangerous... They plan to replace the complete steering mechanism, my car only has 60,000 km and I would like them to pay for the repair. Unfortunately they have a different opinion... Did you succeed to get an explanation or a document showing that this is a BMW known defect?
Thanks and regards,
Christophe
if it's just the microswitch that shouldn't be too expensive, although it's hard to get out of a BMW for less than $300 it seems.
SI B54 05 05
Special Roofs
July 2005
Technical Service
This Service Information bulletin supersedes Service Measure B54 202 04 dated May 2004.
SUBJECT
Convertible Top Fails to Operate
MODEL
E85 (Z4)
SITUATION
Customer may complain that the convertible top fails to operate.
CAUSE
The micro switch for the variable stowage compartment indicates that the compartment is not in the lowered position, due to incorrect adjustment or a damaged switch.
CORRECTION
On a customer complaint basis, check the micro switch actuation and replace the mount as required.
PROCEDURE
On cars produced prior to 2/03, replace the micro switch mount, part number 54 31 7 072 815, and if the micro switch is damaged, replace with part number 54 31 8 236 846.
On all cars, check the actuation of the micro switch, and if necessary, use washers under the mount to get correct actuation of the switch.
One of the best resources I've found that shows how to fix it (for the brave and talented) or at least shows you what the dealer will need to do and why the repair is so expensive is shipkillers site at:
http://www.shipkiller.com/SofttopToubleshooting.html
The best for showing how to clean the drains so it doesn't happen again is:
http://www.zpost.com/forums/showthread.php?t=63033
Why the dealers pretend there is no problem is beyond me. It's the same with Dodge Durango PCM failures that the dealers pretend is an isolated problem, yet a simple web search shows you tons of people experiencing the same problem.
Well could be either TSB problem, right?
If the electric/hydraulic soft top motor is bad, the windows should still go down, and the top latch should disengage. But the top won't power down any farther than that.
It seems like some people have been lucky recently getting BMW to cover the cost of the repair, others have been paying a little under $2000. I would imagine the better the customer you are at a dealer, the more likely you are to get the repair done for free.
That said, I understand BMW extended the warranty on the soft top, but my 2003 still falls outside the range, even though it only has 39,000 miles on it. And given that I like to do my own repairs, I'm not in the good customer category, and will probably tackle the repair myself.
Now the interesting thing is that I am also having problems with my outside temp sensor. I keep the car outside uncovered ( I know, horrors...) and when it's been very wet and damp outside and I start the car, the temp sensor indicates -40 degrees. As the car warms up and I drive the temp rises to almost normal, and then may drop again.
Now mostly this is annoying, but I noticed that when the temp was in the neg range the tops wouldn't work. But when the temp went up it did.
While I was reading the manual on how to put the top up manually, it mentioned not operating the top if it was below -10 (or so). So other than it may be a general short in the system that is also affecting the top, couls it be a temp interlock that prevents operating the top in really cold temps to prevent cracking?
Sorry for being so long winded...
I had the same issue today coming into work. I have a 2005 Z4 and live in northerN VA. The power steering light came on abruptly thrice and shut of the electricals in the car i.e. the nav screen folded in and up suddenly. Something tells me I need to be on the lookout for a hefty bill...please advise as to how you remedied this problem and the cost (if you don't mind). Thanks!
After I posted my original, I brought the car in for another problem, my fuel indicator was showing less then full on a full tank. There are two senders in the fuel tank (at least on my year) and one was bad. So they had to drop the gas tank to replace it (access ports in the trunk would have been a good design idea).
I think the final bill was over $1k, I don't remember the exact price (brain tries to protect itself after a traumatic incident).
I also had them fill the tires with Nitrogen, the car actually ran better with that (I'm not using run-flats).
They did verify that the top is interlocked with the temp sensor, so, below 40 degrees top won't operate.
There is something exhilarating about driving top down in the late fall and early spring.
I believe this is a design/manufacturing defect that is dangerous and should be repaired at no cost to owners. I certainly intend to contact every governmental agency I can find and would encourage every Z4 owner to do the same. Even tho your car may not be affected today it may start tomorrow and you will be facing a $3000 plus bill with a car company that doesn't know you.
If anyone has any ideas please contact me@bobcarnett@att.net.
This past weekend, after researching several Z4's, I found a 2006 that I wanted to purchase from a dealer. As I was in the car checking it out, I tried the soft-top roof. It went open, but when i went to close it, it did not move. The sales man and a service person at the dealership came out & tried. No luck. I will have to pass on THAT one.
Also, after reading these posts, I am having even MORE thoughts of NOT getting my mid-life crisis "dream car". UGH!
Any suggestions?
if you are expecting Camry-like reliability and a glitch-free world in a used BMW, that's simply not realistic. On the other hand, you'll have a LOT more fun in the BMW.
