Visitor Agreement.
That sound about right.
My first oil change was at 3K.
After that, I am doing one every 10K since the oils nowadays are such great. I use Motorcraft 5W-20 synthetic blend or Mobil1 0W-20.
Incidentally, that makes roughly 8 oil changes in 5 years now :shades:
I just checked it today after a tank of almost all city/surburban/short trips with one tiny trip of about 65 miles. It was 17.74 MPG.
I just turned 1,000 miles. My experience with new vehicles is it will get slightly better, but nothing to "write home about".
I don't have a lot of concern about mileage in town. My concern is highway mileage simply because of how often you will have to stop for gas. When I'm rolling, I like to keep rolling.
For a car as big and heavy as the 6 is, 24 MPG is acceptable. Of course everyone would like to get 50 MPG.
It's in your owners manual on page 4-6.
I have always driven a new car like I stole it. No harmful effects yet.
"If you treat them like a baby, they will act like a baby" - but that's just me. :shades:
Unless you drive 80% highway with out traffic, then 7,500 would be what you do as per maintenance schedule 1 on your owners manual. If you do mixed driving, then every 5,000 miles as per maintenance schedule 2 in your owners manual.
I do every 3,000 with mainly city driving.
It is P/N 0000-8K-H02 NOT 0000-8K-H02A that the website calls out. It appears this net had a mfg date of 2006 and was previously shipped to someone else. There are no instructions as someone else had said should come with it.
Does anyone know the difference between and "...HO2" and "...HO2A"?
I agree with the benefits of synthetic, but I wouldn't go past the manufacturers interval. If you do experience any problems and they require evidence of maintenance they won't give you "credit" for using synthetic disregarding their interval policies...you'll be SOL for the repairs.
Point taken.
But at nearly 90K miles, I am SOL anyways :sick:
The point is, new oils and premium filters are wonderful, and they retain excellent properties at least upto 10K, if not more. My engine is as clean as it was in the first year as a result of using synthetics.
I am an engineer and trust my engineering guts more than anything else.
I went with a Mazda (twice) when nobody in the right mind (in my social circle) would think about doing it. That was solely based upon what I felt,as an engineer, in the vehicle I test drove the first in 1999. Mazda builds solid cars. No doubt about that. The Protege, the 6 and the 3. All testament to that.
Getting back to oil change intervals, the rest of the world has a longer OCI than the usual 3K propoganda in the US, more like 15K.
I do the 3k change interval (105k mi) but only put the 'regular'; I only do about 7-8k mi per year so I don't want to go through multiple seasons (and over a year) on one oil change...plus I worry about the oil filter going that long too. Probably wouldn't matter anyway since I live in a temperate climate (86F now).
I think the oil change debate has been going around for a long time...usually ending where it starts
I ordered the cargo net from the dealer and received it in a mazda bag that was pre-opened and had evidence it was shipped out in 2007 by the pull ticket and had two mazda labels on it, one that was so old they did not use bar codes and the part number was 0000-"89"-H02, the other newer label had a date of 2006 and was 0000-8K-H02.
Both of those numbers are not what the website calls out for 0000-8K-H02A.
If I sent you an email, could you do me a favor and email back a scan of the instructions you got with yours? Mine did not come with any.
I don't know the difference in the part numbers, but with the "A" suffix I assume there was a modification made.
I think mine was made in 2006 also, but I threw the instructions and packaging away after installation.
If you got it at Mazdagear, email them and ask them. Otherwise ask who you bought it from.
If you decide to keep it I can explain installation.
I will inquire about receiving the instructions. I am still waiting on Mazda to answer my question regarding the difference between the two nets.
My dealer gave me a price of $180 + ~ $45 to program it for grand total of $225.
BTW I just found out that under the black cap on the steering column is an ignition lock and the key if the remote battery dies can start the car.
Here's instructions as I remember them:
Find the four plugs that hold the rear panel. Use a small screwdriver to remove those plugs. They are a center plug with a small washer – pry on the center plug. They should pop right out. Remove the little washers too. I used a medium jewelers screwdriver - pretty small.
Remove the panel and lay it aside.
Get a 5/16” drill and drill out the holes the plugs came from. Easy pressure – it doesn’t take much to enlarge the holes.
Find the 4 “T” shaped hooks and the 4 rubber plugs. Push the hooks through the rear panel you removed and screw the hooks into the rubber plugs. The hooks will face the front of the car and the rubber plugs will face the rear of the car. Do NOT tighten – just almost snug. If you do tighten them the rubber plugs will expand and you won’t be able to get the rubber plugs into the holes you just enlarged.
Put the panel back into the trunk and line up the new rubber plugs with the holes you just enlarged. This will take some fiddling and probably a flashlight. Push the panel in tight. Then, holding the panel tight where you are working, screw in the hooks thereby bulging the rubber plugs to secure the panel.
It’s not as hard as the instructions sound.
Do not turn that key to start the car though. Just insert the key and use the push button.
Thanks so much for the info on the keys! I opted not to go with the "replacement plan" since it looked shady. Especially since Mazda said they didn't know about it and wouldn't back it. It was a deal between the dealership and a 3rd party. As for the ignition on the steering column, none of the salesmen I ever talked to in person knew about it. But, one of the guys on here did and also filled me in. I swear, I have learned more valuable info from everyone on here than I did in any dealership.
Happy driving!
If they could they would sell you the warranty for air in your tires
I just got my first statement from Chase today for 3.9 for 60 months. I am going to call them tomorrow and ask about the 0.0. If I bring it down to 36 months it will raise my monthly significantly but I will save over 2 grand in interest.
Don't waste your time.
A couple isolated occurrences. Not the norm. Every manufacturer has parts go. Ask my father who replaced his tranny in his 04 Accord.
Mazda does not seem to be acknowledging or honoring the warranties
That is highly unlawful and untrue. A manufacturer must honor a warranty claim if it cannot be proven that the failed part or parts failed due to abuse or lack of maintenance. If the owner cannot prove they maintained the car in ordinance with manufacturers guidelines, no manufacturer will replace an engine for you.
Should we be worried since the 2.5 I4 is based on the 2.3 I4?
I would not be. Ask basically any Mazda6 owner here that has the 2.3L and they will tell you it's just fine. I have 46,000 trouble free miles on mine.
So, you can have Toyota give you flack when your engine develops engine sludge and Honda will give you grief when your tranny goes. My point is every car can have issues from time to time, and as long as you maintain your car, the manufacturer will honor the claim.
http://townhall-talk.edmunds.com/direct/view/.f1718f9!make=Mazda&model=MAZDA6&ed- _makeindex=.f1718f9
And it seems if you do your oil change by yourself mazda is not honoring it, and asking them to provide receipts where the VIN number and mileage are shown on the receipt where you bought the filter and oil from. Which is ridiculous.
I think in the warranty period the safest is to change the oil at the dealer so as not to give them an excuse. Also make sure you check the engine oil level regularly.
I was particularly worried from the post by a guy in Quebec Canada saying that his filter cracked and let the oil out. Since I live in Canada too, and it gets pretty cold in the winter, could the filter housings be affected by cold temperatures.
Oil change procedure
Listen, does it suck that many can no longer change their oil? I would say yes. I'm not one who was into that in the first place, so, it does not bother me. I would much rather have a professional do the work.
About the oil filter design. Yes, it's weird. A lot of cars are now going to the cartridge design. It's less costly I suppose.
Also, about the member with an issue with his 2.3L. We don't know that he did everything correctly, do we? No, we don't.
Do parts fail from time to time? Yes, absolutely! These are machines built by man, things do go wrong. There is no auto manufacturer immune to random parts failing from time to time. When things happen on a small and random scale, such as this oil filter thingy, it's not really something to be concerned with. It's when you see failures on a grand scale that there is a problem. I don't think this case is a problem to be concerned with. I rarely see any Mazda6 come into the shop with issues. I ask my service manager and my customers when I see them, and about 95% are here for routine maintenance.
First, thanks for all of your thoughts and suggestions in the forum. You are extremely helpful. My question, and I'm trying to follow your thread from the
original posting is that you feel mazda states that the owner of the mazda 6
cannot change their own oil? Oil changes have traditionally been something
that anyone with a little mechanical aptitude can do... what is the issue in
having someone change their own oil?
With my thanks,
Runningdoc
Love way people panic & destroy reputation of a great company like Mazda!
I'll try to answer this as best as possible. Mazda is not the only manufacturer to state warnings or recommended guidelines in their owners manual when it comes to maintenance. I think that people with basic mechanical skills can change their own oil. My bet is that there are a lot of people out there that do it successfully with no problems.
I think Mazda is trying to eliminate those who think they have skills, when in fact they don't, from performing routine maintenance, since the consequences can be disastrous. My bet is that it's happened in the past, and this is why manufacturers won't warranty a failed part due to unproper maintenance. My friend in high school decided to change his oil in his 1983 Chevy Caprice Classic wagon and thought you had to fill the oil up to the top of the engine. He put like 10 qt's in, and within a couple miles, the engine started knocking. The motor was destroyed.
Naturally, if you screw something up, you would bring it to the dealer and deny you did anything and just assume the manufacturer would foot the bill. Remember, unless a manufacturer can prove that the failed part or parts failed due to the reasons outlined in their owners manual or warranty guide, they must honor the claim. It is the responsibility of the owner to prove that they maintained the vehicle properly as well. A receipt for a case of oil does not prove that you changed it that day, or that it was even for that car. Any mechanic that does routine maintenance would give you a receipt with your name, VIN, mileage and date on it. There is a reason they do that. For the couple extra dollars you would save, why do it on your own? I see no reason to...
Did I answer your question? I think that's the best I can do
and I want to keep it for a very long time. This is the only reason for my concern. So far it has been flawless. Nothing has gone wrong and zero problems to report.
showed you how to do it, you would be ok. I guess my only concern is if you happened to move to a place where a mazda dealer didn't happen to be close by, then it might become an issue....
Thanks to all for their help...
I'm going to do a little digging, but keep us updated on the zero percent thang!
The passenger side fog lamp when gently pushed on seemed to have more play and upon returning to the normal position I hear a knock as if it hits the plastic frame around it upon return. I think this would tend to rattle some during driving subjecting the lamp to additional vibration. Another 6 on the showroom floor with an earlier VIN number also exhibited the same characteristic.
Probably not that important, but I was wondering if anyone else with factory installed fog lamps noticed this?
If the oil filter is an issue for you, there is a conversion to a conventional filter set up. Once I find out where it is, I will post the link.
But if there is a conversion to a conventional filter, I would greatly appreciate any information, I would change it right after warranty expires.
It has been tested...
The IIHS test looks pretty good to me.
