Regarding sheer reliability - only time will tell for me. I doubt it will be as reliable as the camry, but as long as it's just one or two minor things here and there I would take the Mazda6 absolutely anyday compared to a camry or accord.
I had not had any real problem till this week:
- Hear a slight squeek from my serp. belt, when shift is on D.
- My front left shock also has developed a squeek. (Once and a while when getting off the car - I weight 200 lbs.)
- My A/C is not working.
I haven't been able to take the car in since I will be needing it for the next 3 weeks. Aside from that the car has been great, crazy the pull you get from this 4 cyl engine.
I had it at 25 and wasnt sure how far it goes up. Anyone know off the top of their heads? I read the owner's manual but it didnt say.
I have been slightly dissappointed with this stereo as its base response is not what I would expect from a Bose system with subwoofer. The factory system in my Dodge Ram has twice the base though is lacking in mid-range power.
My 2009 Mazda6 seems to have nothing in the center firewall area, only small pieces on the side. I am wondering if it is correct this way or if they forgot to install it while the car was being built. Can someone with the 4 Cyl 2009 mazda6 please check their firewall area and let me know. Thanks
Only twice in 10 months, that's sad.
It is a Mazda 6, known for its...
Stick shift? Firm handling? Zoom Zooms? A big trunk?
:shades:
Erotically...Mis-used the word. Meant to say it has ERROR.Can someone tell me how to edit my previous posting? Thanks.........
Do either of you have anything helpful to offer? Or perhaps an apology?
You only get a limited amount of time to go back and edit. You will see "Save | Reply | Edit | Delete" to the right in the title bar of recent posts. Once the time for editing expires you will see only "Save | Reply" there.
Don't worry about it, anyone reading it knew you meant "erratically".
Anyone else having the same problem? My phone is among those listed on the mazdahandsfree.com website as being supported for Bluetooth headset and Bt Audio. All other phone functions work flawlessly.
On the same site I found buried in the FAQs (THIS SHOULD BE LISTED IN THE MANUAL that comes with the car) that the phone book must not contain more than 1,000 contacts. So I deleted a ton of contacts that I am not likely to call anyways and got the list down to around 500 contacts. But the import phonebook hangs (well I lost my patience after about 3 minutes).
I even unpaired and re-paired but it continues to show the same behavior.
I can't believe they charge $2,000 for this nav and still don't get this to work right.
Any suggestions? Please email me.
And I can't add entries to the voice dial phone book either. It says "phone book is full", but when I ask it to list the entries, it says "phone book is empty". I guess it's time to call Mazda?
This just got done on my 09 GT 6s and it has indeed addressed the problem. There are 6 different parts that needed to be replaced as part of this SB and my dealership had to order them first. But finally this annoying noise is gone and in fact now the engine "sounds" smoother when starting from idle
I bought my Black 09 Mazda 6i Touring just over a year ago. Still in love with it! I am just shy of 21,000 miles (how did that happen so fast?!). I have a question for those of you who are more mechanically inclined. When I am driving at a low speed (in a parking lot or going up my driveway) and step on the brake to come to a complete stop, I hear a noise. It's metallic, seems to be coming from the front end and sounds like a "clank" or "clunk". Kind of like two metal plates coming into contact. It doesn't do it every time I stop, and it never does it at highway speeds or in street traffic. I've asked the service guys to check the brakes and investigate this noise a couple of times. They say everything looks fine. Last week when I was in for an oil change, I asked the service manager to check it again. Without hearing the noise, he said it was being caused by a "pad shift." Something about a gap between the brake pads and whatever they come into contact with (I can't remember exactly what part he said). He also said it's completely normal and after checking the brake system, he said everything is just fine. My boyfriend (who is enough of a mechanic to work on his own car) says he's never heard of it and he doesn't believe the service guy.
Are any of you 09 Mazda 6 drivers experiencing this noise? Does anyone know what "pad shift" is? Did he just make this up?
Interesting name! I worked for a local weather team at our ABC affiliate for a while - big weather nerd here!
Regarding pad-shift, I'm actually familiar with what the dealer was talking about. I have an '06 Accord, and my dad had an '03 and an '05 (all are basically the same design). When backing up, I hear a metallic "click" or "pop" noise when applying the brake. When applying the brake once moving forward again, you hear it "click" back into place. My dealer explained to me that this is a "floating caliper" design. While I don't understand the purpose, I do understand the method of how this works. Its almost like the adjustable wrench, that you can slide one way or another to make it open wider. Once it "pops" forward or backward, it doesn't do it again until you apply the brake while moving the other direction.
I've got 53k miles on my '06 and have never had an issue with the brakes, despite the consistent "pop" in situations I've described. Odd, but never problematic; I have the original pads and rotors, and have never experienced problems when panic braking (using Anti-Lock and all). Don't worry too much about this; I'm not a Mazda guy, but I don't believe that the dealer is leading you astray - they just don't know how to describe it well; I doubt I made a whole lot of sense either!
Hope you continue liking your 6; my girlfriend wants one in Sangria Red!
Thank you so much for your explanation of Pad Shift! I am relieved to hear that other cars do actually do this and that your brakes continued to work normally. I will be sure to pass along your description to my also-skeptical boyfriend and do some follow up research on the topic. I'll also try not to squint suspiciously at the service manager anymore.
I hope your girlfriend gets her dream car! I have no regrets with mine. Thanks again!
Just a thought.
I'd try it with and without A/C on; see if it stops when the A/C isn't running. With a GT model I'm assuming you have Automatic Climate Control, which if like Honda, runs the A/C whether or not cool air is needed.
I hope this is what you're feeling!
Happy HondaingZoom Zoom!TheGrad
Anyone else out there with this problem?
MODERATOR /ADMINISTRATOR
Review your vehicle
I know it is a common problem on the Mazda 3 where their is a variable intake valve that starts rattling to the point where you think there is something wrong with the engine. But just disconnecting the intake valve actuator (power) makes the engine noise disappear.
Basically in your case I think the hesitation is due to the air being cut off momentarily from the engine.
Thanks for sharing, I'm passing along all these suggestions to my dealer & corporate mazda for them to check into.
Chris
Did the air filter solve the problem and if so track for how long it cures it. I don't think it should not mold up that much/fast unless there is a drain that's blocked?
I've seen reference to air quality issues on some other forms and I think in Edmunds as well.
It is getting very annoying, I cannot pinpoint the cause. But it sounds like piston slap that never goes away after the car has warmed up. In fact as the rpms decrease it becomes more noticeable.
Noise cannot be heared above 1500 rpm. but when idling it sounds like a VW diesel.
I rented a Ford Fusion last week, which had the same 2.5L engine as mine, but the engine sounded smoother at idle and it was tuned differently at highway speeds turning at least 400 rpms less at cruising speed than the mazda 6. How could the 2 identical Mazda made engines behave differently. Is there a way I can make mine behave the same? I think lower rpm at cruising speed is a gas saver.
Because they're "identical" in name only.
The 2.5L are similar in structure, but are tuned differently. The ECMs and heads are different from Ford's, and Mazda tends to run their engines at a higher RPM at certain speeds, which IMO helps to stay within the power band when sudden acceleration is needed (to pass someone).
It may make a slight difference in fuel economy, but IIRC it's negligible.
having connection issues again. Please check your carspace mailbox. I've sent you 2 e-mails from my carspace mailbox to yours.
Bob
To recap- I drove my car with the Mazda rep for 1-1/2 hours last monday. And, of course, the hesitation never occurred. That after happening 10+ times in the first mile of driving just a few days before. So- what they (Mazda) have agreed to do is to put a data recorder (black box) on my car. That's going to happen next Monday.
Strange that a dead battery seems to be a common thread in both our cars.
Bob
While I know that you & I had dead batteries - to my knowledge the loaner I drove did not have a dead battery and it had the same issue. Also my hockey teammate says his wifes car has a similar issue (though I have not experienced that myself). That and the fact that it happened 2x to me yesterday after the reflash means that there is more to this than it appers. I still think the drive by wire pedal sensor is too damm sensitive. I think what's happening is that at light throttle instead of being an analog/linear move from light to no throttle/off because it's digital, the sensor goes from on to off in an millisecond and it's you can't modulate that with your foot. Also since the electronics are so fast & on/off, they get ahead of the mechanics in the engine (valves/air intake etc. which open/close relatively more gradually) thus creating the conditions for the hiccup. I wish I had more mechanical training to get into the details.
Yesterday one of the hiccups occur just as I lightly applied gas which again points me to the on/off. The car drives fine if I run and gun but unfortunately real life traffic does'nt allow me to drive like that all day (wish that it did!)
Chris
PS - did you get snow tires for your car and if so what did you get & how do you like them. I'm thinking about going to 16" on steel rims when I do.
Chris
Bob
