Visitor Agreement.
Jim
Also, the Geos on the 03-04 Forester are a new design for the Forester. Unless the comments pertain to that specific version of the Geo, they're not even relevant.
Craig
For future reference, if the CEL is caused by an insufficiently tightened gas cap, it will normally reset by itself within a couple of days.
-Frank P
Jim
This also discourages owners and garages from doing a reset just before an inspection. Even most generic OBDII diagnostic equipment display these.
These are on ALL OBDII vehicles.....Toyota's, Subaru's, Ford's. GM, Mopar.....etc
If you can pinpoint the noise, it will help the dealer immensely. From there, it will depend on how good they are at fixing these things. If they tell you it's normal, then call Subaru of America and start a case. It definitely is not normal. Replacing the gusset made a huge difference in our car, it was much quieter afterwards. It was really driving my wife nuts.
I think this is a universal problem with the way Subaru designs the seals for their frameless windows, and the problem varies from car to car. My 2000 Outback never had this problem. My 2003 WRX does not have this problem. My 2002 Outback only makes the noise if the window has been rolled down and then back up while driving). And our 2003 Forester made the noise from the beginning. So it could be something that varies with the tolerances of vehicle assembly. Nothing would make me happier than to see this problem fixed on the 05 Legacys, so I will be very interested to look at the design of their window and gusset seals.
Craig
Jeannine Fallon
PR Director
Edmunds.com
MODERATOR /ADMINISTRATOR
Review your vehicle
He is also suggesting that I get the maintenance plan for 3 yr / 36k, for $800.
Is there any value in buying either of these? Are these prices fixed, or can they be negotiated? Thanks
Finally, you do not have to buy the extended warranty until just before the basic 3 year /36,000 mile warranty expires. So don't feel rushed. You can always decide later on, and perhaps have a better idea if you will even really want or need it.
$800 for 3/36 maintenance is really high. My wife's Forester probably only cost about $200-250 to maintain over 30,000 miles, and that includes the 30,000 mile service (did it myself but paid for parts). You're looking at about 5 oil changes and tire rotations in 36,000 miles and the 30,000 service (which includes many other items). Based on what most dealers charge for all that, it all should only cost $400-600 tops.
Craig
Elissa- That was one expensive CEL! Also, concur with what Craig said regarding pinpointing the noise. Unless you can do that you stand almost zero chance of the service dept fixing it.
Hosts- I certainly hope that there are no Subaru owners with 72-month loans! The crew is much smarter than that :-)
jsmith- re extended warranties: Ditto what Craig said.
-Frank P
Thanks again everyone : )
Joe
John
Thanks soooo much for yours and FRanks comments already. c_hunter - where did you buy the gusset and did it come with instructiosn?
thanks!!!
elissa
I bought the new gusset from Liberty Subaru online (you can email parts@libertysubaru.com). The part did not come with instructions, but it was very easy to figure out how it worked just by looking. You have to pull off the interior door panel, but that's the worst of it. You could probably use my pictures to aid in the installation.
I bought a new one because the opening was too wide and there was no way to adjust the angle and fix the problem. You may be able to fix your problem by just adjusting the angle, if the gusset is in fact the problem.
Craig
http://techinfo.subaru.com/html/whatsNew.jsp
Apparently in April this year, Subaru released a doc/tsb sort of thing on correcting the gusset wind noise. Also noticed it was a proble on '90 and '92 legacys. Guess I'll be going to my dealer after this document arrives at my doorstep. Hooray! Thanks everyone! -elissa
Does anyone have any experience as to where I can easily access an always-live 12V line (hot when ignition off) and an ignition switched 12V line?
The installation also requires securing a small control module and a loudspeaker under the dashboard. Any suggestions on good places to secure them and/or tips on drilling screws into the floor pan?
Finally, does anyone know of the factory Subaru radio for the XS (6-CD + cassette) has the ability to accept external audio inputs and/or external muting control? I'm probably not going to attempt to tap into the radio, but I thought I'd ask.
Thanks!!
Elliot
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Drop by for live chat with other members. Hope you can join us!
kirstie_h
Review your vehicle
Alternately, if you can get to the radio or clock, both of those harnesses contain constant and switched 12V lines. The radio harness has plenty of spare juice, but I would not want to draw too much current from the clock lines.
Craig
I've always had good luck with the Subaru OEM pads.
BTW, rotors are not that expensive either -- you could potentially buy new rotors instead of having the old ones turned.
If you do get the rotors turned, try to find a shop with an on-car lathe, it does a much better job. If they have to take the rotors off to use a standard lathe, you may as well just install new rotors.
Craig
I have the Turanza LS/Ts on my '98 S and they have been great. 31,000 miles and less than 1/2 worn. Excellent rain traction and better in snow than any tire I have ever had except Nokian dedicated snow tires. They seem a little squirmy when new because of very deep tread, but feel much better in time. They increase steering effort a little.
John
On the way back I calced my mileage. Did 50 miles on two-laners and 325 miles on interstates, and got 30.5 miles per gallon. That's much better than I expected, especially with the auto transmission.
BTW gas in rural western PA was $2.069 for regular; here in central NJ it is $1.939. I think the difference is in the amount of state tax.
Sara
My brakes are totally quiet, original pads at 62k miles. If those squeek it might be the pads are glazed. You can have them scuffed and then re-do the break-in, but I'd have the seller do that before I bought the vehicle.
As for re-painting? That's hard to do well. Expensive if done properly. For a 2003, you might as well buy a new 2004, which are being discounted since the '05s are on the way. I bet in the long run it'll cost you less to go with a 2004.
-juice
Craig
Ken
e
DaveM
Subaru does mention it in the owner's manual, but doesn't recommend running if FWD for longer than necessary - Mike / Juice / anyone else smarter than me (wait, not that many people) want to go into the technical issues re stress on the differentials, altered handling characteristics, etc?
Larry
-mike
Kyle
Had an annoying buzzing noise coming from behind my left ear while I drove.
Something in the pillar? Seat belt mechanism? My window or the one behind it?
It took a couple days, but found it, lower than I expected. It was that plastic popout access plate above the speaker in the rear door. Apparently some warping of the plastic prevents a tight seal.
Occasional taking it off and firm replacement takes care of things. Ah, quiet riding again.
http://www.geocities.com/samiam_68/SubaruCCS/SSC_Fix.htm
I will not quit until this thing is perfect or until Subaru gets a fix of their own ;-)
Kyle
Actually it's 80/20 initial split and goes up to 50/50 depending on load, acceleration, etc. Depending on your driving style you may have closer to 50/50 on a regular basis. I know that with my heavy right pedal action, my cars do not see 80/20 often.
-mike
Essentially the electronically controlled clutches will vary power to the driveshafts, not the axles, so you get a F/R split. By putting in the fuse it pulls the clutches off and sends 100% power to the front wheels, tricking the computer into thinking the rears are skidding sorta. By having the clutches not engaging or fully engaging (not sure which way it works) it puts extra stresses on the system that it wasn't designed to have for extended periods of time.
-mike
Never thought about it that way, Mike. I guess I shouldn't be so insistent on wanting to see VTD in AT equipped Foresters!
Ed
