So, "it's rare, but not as rare as you'd think". They declined to help. It surprised the Service manager at the dealership. He took me aside and said that in his time at the dealership he hadn't seen one fail at all. I was his first.
So I wrote a letter and mailed it this morning to Toyota USA. We'll see where that takes me.
It's that this has likely been a nagging problem for quite some time now, and that this master cylinder problem has also wiped out one set of rear brakes, and has now taken out a second set. This issue in total has cost you closer to $2500, right??
I called Toyota back then asking if they knew of anything regarding a 2010 Sienna and brakes. They said no. I was told it sounded like general wear and tear. I accepted their explanation.
Fast forward to 47,450 miles and we had the right rear tire seize again. So I took it directly to my closest Toyota based on that last advice from the mechanic. They kept the vehicle for three days and it took them two of the days to just diagnose the issue. They elected to pursue the master cylinder, which they didn't even keep in stock. On the third day the part had arrived and they fixed. ($1,800 total)
Meanwhile, I was calling Toyota Corporation. In the end, they said No. They still considered it general wear and tear. Oh, but if I had purchased the extended warranty when I got the van, this would have been covered.
But they brought up a valid point in the very last line of your presentation. I paid $1400 for an extended (8 yr / 125k) warranty. When the steering intermediate shaft started knocking, and the HVAC fan motor started squeaking, and the power port fell into the dash at under 60k miles, they covered it all, no questions asked. Around $900. So what's the value in buying this insurance, if they would have done it for free just by my complaining that these things shouldn't happen?
One could argue that you had exactly the same options I had. You chose to self-insure, while I bought the policy. So far I'm still in the loss column, and in the end so are you. Just another way of looking at the cost of ownership.
When I bought my diesel Jetta in 2011, I had an oven and a fridge go on us between the 2009 Toyota purchase and 2011. I had gotten the Sears warranties on those two items and it more than paid for itself. So with that in mind, with the Jetta purchase, I got the extended warranty from VW.
When this happened to my van with the Master Cylinder, it was the dealership service manager who told me to try Corporate. When I picked up the vehicle he didn't know they had already said, "no". When I told him, he admitted that in his time at the dealership he had never had a failure of this sort. This was his first and hence, why they didn't even have the piece in stock.
I have now also paid money to USAA for their version of an extended warranty for the van. I'm not having this happen again!
As you may notice, I have just registered myself in this forum, and hope this is the right place for what I am about to say and some else might have encountered the same issue with their Sienna 2013 or will. Here it goes:
I've recently had a very SCARY experience with my less-than-6-month Sienna LE. My family was about to embark on a fishing trip and every one was seated and we were ready to go. As I put the car in the reverse, and backed out of my driveway (our house is on a high ground), i did the natural thing as I always do. that is, I was applying the brake as I was backing out. However this time, the brake system was gone, i mean, not there at all. The backup monitor displayed the emergency message: "Check the brake system. Please contact the dealer immediately." the Car kept sliding backward until it hit the curb on the other side of road. Long story short, in the end, The brake system came back online and started working after I restarted the car the 3rd time. The experience is pretty traumatic, and none of us wanted to step into the car. we had the car towed in to the dealer and the Dealer service manager called back and informed me that they have found nothing wrong with the brake system. But this is not very comforting.
Now my questions are:
1. has anyone else here experienced the same problem?
2. What shall I do in this case?
My letter to Toyota produced a response via a phone message. They had received the letter and included it in my file for my established case number. But being a voicemail, that was all I learned. The caller, Alan, said if I wanted to ask any questions I could use any representative when calling Toyota Corp.
Your story sounds similar to mine. Except mine started at 42,500 miles. I did not go to Toyota originally when the problem first occurred last February, because USAA towed the vehicle to the nearest brake place. They wouldn't authorize a 30 minute tow to the nearest dealer. So I called Toyota Corporation then and was assured this was "normal wear and tear".
When it occurred again, I purposely drove the van to that dealership trying to use the brakes as little as possible. I wanted a dealership to be involved.
The backlash I received this time from Toyota Corporation, was 1.) I had called before for a similar problem and chose not to use an authorized Toyota dealer for the fix, 2.) I hadn't regularly maintained my Sienna at a Toyota dealership, and 3.) I should have bought the extended vehicle warranty.
To them it was "End of Story". In my written letter I took exception to #1 and #2. Due to the towing and due to the Sienna passing, without a single discrepancy, the official Toyota dealership 20-point inspection when my vehicle was seen recently. I take great care of my vehicles and due my own servicing.
As for #3, that is correct, as I described earlier in this thread. I hadn't gotten the extended warranty. In August 2009, I didn't think it would ever be needed. My trust was obviously misplaced.
Clearly Toyota is cutting corners to maintain a level of profit on each purchase. Cheaper components. The answer is now from Toyota Corporation: you didn't buy the extended warranty to cover our sub-par components. You are expected to purchase it and I had not.
I have done the phone calls and sat on hold. I have written a letter. I don't know if I'll ever get any satisfaction. As I told the service manager at the dealership, for a $1,005 part, Toyota Corporation would lose this customer forever? He just grimaced and smiled. He wasn't going to reply.
So what has Toyota said about your van? Have they resolved the brake problem? Your story is exactly the same as the incident we recently had with our brand new Sienna 2013 AWD Limited Edition. We just puchased it July 3. We started our van and drove down our driveway and within minutes the brake did not work at all - it froze along with the gas pedal. It felt like I was pressing my foot against something really stiff. We then turned left to go up the hill and the vehicle rolled back down without any braking system. The same emergency message came on and I immediately turned the engine off. I waited a few minutes and restarted the engine by stepping on the frozen brake pedal and then tried 5 times to push on brake pedal and finally it released itself. The emergency message went away and I immediately called Toyota. It was VERY SCARY because I had my two young children in the back of the van...luckily this all happened at about 30 km/h rather than 100 km/h. The dealership said this was the first they've heard of it - ya right! They made me fill out a bunch of forms for Toyota Canada. They checked the van and said it was probably the brake booster (I then told him to explain it in normal terms). They were going to let me drive the van home but I refused knowing I have to drive my kids everyday. He then came back and said they'll contact Toyota Canada for more inspection and gave me a loaner car. What is up with this brake issue with Toyota - they need to get this brake problem resolved for all their models before more accidents/deaths occur.
I do know my written letter was received as I received a phone call, well after hours and it had gone to my voice mail.
I have honestly never experienced anything like this and feel like a tiny gnat buzzing around a sleeping giant. I'm not sure what else I can do to get anymore from Toyota in terms of help or a simple explanation. We had to spend a good portion of our saved money for our vacation in September to pay for the repair. Stupid things like this always come up at the worst times!
Has anyone else had this emergency brake issue?
