Pontiac Montana Heating / Cooling Problems
ClairesClaires Member Posts: 1,222
1
«13
  • tony17112acsttony17112acst Member Posts: 35
    I bought a new air filter and thought it would take 5 minutes to change, just like all other normal automobiles.
    But when I couldn't separate the housing far apart enough to get the old on out (much less get the new one in), it turned into an HOUR AND A HALF!!! GOD, I am angry!
    How does ANYONE change this air filter, including mechanics? I am a very strong 38 year old man and I simply could not separate the housing apart far enough to take out the old filter. I ended up completely destroying the old filter just to get it out. I also had to remove the coolant overflow tank, the thick round brace which holds the tank, and several wire harneses just to get some leverage! Then as I was pulling as hard as I could the whole cover popped off the mass air flow sensor and shattered part of the housing. :cry:
    I even own the shop manual and it says so innocently and simply to just separate the housing at the top and replace the air filter. It doesn't say that this simply cannot be done. There isn't any room for it to separate!
    I just sold my Chevey Venture (same car) and I had no problems chaging the air filter.
    Does anyone know a trick to change this thing? I had to use every ounce of strength I had working on this so much so that I had to actually take breaks because of muscle fatigue. I have used less energy in a weight session, it was so bad.
  • bratmadleybratmadley Member Posts: 1
    We own a 2001 Pontiac Montana mini van. We took the van in to have a/c checked as it was only blowing out warm air. The dealership said it was a condenser problem and would cost about $800 to fix. My parents also have the same year montana and their condenser also went in their van. I called the GM toll free number and asked if there was a recall and she said no. She did say that all complaints are reviewed and if many are being reported, recalls may be done. When you call this number, they do give you a claim number just in case. Anyone that has a pontiac minivan that has/or had this problem, please call the number I am about to give so that the problem can be reported. The dealership has said there are many problems with the montana a/c condensers. I am definitely seeing many problems with the condensers when seeing all the message boards from people on the internet.
    GM can be contacted M-F from 8:00 a.m. to 11:00 p.m., Eastern Time. Have the following info available:
    Your name, address, and home and daytime telephone numbers.
    Your vehicle Identification Number (VIN), which can be found on your registration
    Dealership name and location
    Vehicle delivery date and current mileage
    Nature of your concern Customer Assistance Center
    Inside the U.S.: 1-800-762-2737
    Inside Canada: 1-800-263-3777
    I got the number off of the GM internet site under contact information.
    Hopefully, a recall will occur if enough people call and report that they have or have had the problem. It only takes a couple of minutes to report the problem.
    Thanks!! Hope this helps!!
  • montanalemonmontanalemon Member Posts: 1
    I also own a 2001 Montana and have had ongoing problems with the van. In 2003 we replaced the condenser and the compressor @ $2000.00. This past Friday July 28,06 we brought it in again to the dealer for what was diagnosed as a cracked condensor, again! Cost to fix $1100.00. We didn't have it done. It was not a pretty seen at the dealership. They told us we needed to talk to GM about the problem. I did contact GM back in 2003 and got know where with the problem.
    I will call again on Monday.
    I am amazed how many people have had problems with this model.
    We also had to have new brakes, Head Gasket, Wiper motor and ongoing items I can't reemember off the top of my head. The worst part of the whole thing is I still am making payments on the loan I took out for this van!
    Montanalemon
  • ncjackncjack Member Posts: 1
    I have 2002 Pontiac Montana with approx.76K. Just replaced compressor & condensor. Mechanic says everything checks out ok like Freon, etc. The left (2) of the (5) vents in dash are blowing very warm, humid air while the remaining (3) vents in center & right feel cool not cold but dry. Any clues to this problem?? I just spent $1400 & we're still very hot with no A/C. Any help will be greatly appreciated!!
  • tanjotanjo Member Posts: 6
    I am having a problem with the AC in my 2000 Pontiac Montana Van. Even with the air conditioning on high, it blows hot air. I had it in to the mechanic and he couldn't find a problem, but suggested we put dye in it to see if they could find a leak. They couldn't. He had recharge it and it worked for a couple of days. A few days later, it was blowing hot air again. After looking at it, he suggested that we bring it to a dealer to have them look at it (as he couldn't see anything), and let him know what they said. We paid for an hour tabour at the dealer for them to tell us that we needed a new condenser and that they were not sure if that would fix the problem or not, and they again suggested the dye. We brought it back to our mechanic with the news, and he said that he had checked the condenser, but didn't see a problem. We decided to have our mechanic put in a condenser, it cost less than half than the dealership quoted. Well, here we are a few days later, and we are getting hot air again...
    What should our next step be?
    Thanks in advance for your help! :)
  • layoriclayoric Member Posts: 1
    Hey, we have a wiper motor problem too! Does someone program these things with specific life spans or something?! Just ordered one from NAPA and picking up on way home. Also just got new brakes a month ago. Ours is an 04 model though. I guess with the new models they're getting worse and not better...
  • rnjhuntrnjhunt Member Posts: 2
    I fixed a wiper motor problem by running a separate ground wire from the motor to a screw on the frame. It seems these motors are not grounded very well. No problems for 80,000 miles since the fix.
    Found out mine was the control on the dash - when I put it to cold, it would blow warm - would never go all the way to cold. There was nothing wrong with the A/C, just the mixer. Get a manual and dig into the dash to loosen up the linkage or check the vacuum that runs it.
  • ssullivanssullivan Member Posts: 3
    On my sons 99 montana, no heat control. a/c, air flow, etc. works great but no heat... any suggestions would be greatly appreciated. daughter in-law and 4 grand kids are gonna freeze to death this winter.
    Thanks, Mark
  • mlhilemlhile Member Posts: 1
    Our 2003 Pontiac Montana will only blow warm air from the heater when the vehicle is moving. Vehicle blows only cold air when stopped. The higher the speed, the warmer the air temp. Can feel the temp cool as you slow and stop. Recently took to mechanic who couldn't find a problem but cleaned heater core which did allow for warmer temp while driving. Have a newborn and live in a cold climate so it's very important that we are able to warm up the van and maintain a warm temp when stuck in traffic. Any ideas?
  • 99transportonr99transportonr Member Posts: 5
    Hi the mechanic obviasly check the coolant level, that being ok. I would replace the thermostat. If your in a cold climate you can also block part the the rad, BUT YOU MUST HAVE A GAUGE TO KEEP AN EYE ON ENGINE TEMPERATURE!
    PS anyone have any info on my transmission
  • teytey Member Posts: 2
    I just bought a 2002 montana and notice that my engine temp. rises more than half the gauge but not reaching the red portion. I went back to the dealer and he told me that it is normal for montana's to have this temp. I just want to know from you guys if it is really normal to have this engine temp.or theres somthing wrong with my engine or gauge.
    thanks and hoping for reply
  • farooq1farooq1 Member Posts: 1
    I have the same issue with my 2002 Montana, Just started on the weekend. Do you have any updates on the issue?
    i went to GM dealer to have my key duplicated and programed and i asked one of mechanics if it is normal to have this temp. fortunately he also owned a 2003 montana and he told me it is really normal coz he is also having this kind of temp.
  • rsarnolrsarnol Member Posts: 7
    We have a 2000 Montana and have the same thing with the temp gauge. It usually is caused by a slow leaking lower intake manifold. Common in GM 3.1 and 3.4 V6's Just keep a check on the coolant level.
  • akelloakello Member Posts: 1
    My husband and I have the same problem but ours eventually overheated on the interstate one evening. We then had to replace the water pump and then the temp. gage never went up. It just started today but the low coolant light comes on and the heat gets cold like the AC is on. When the coolant light goes off the heat gets warm. We have put coolant in and there is still the same amount in. When the light comes on the temp gage will go up really high and when it goes off the temp gage will go down. We have been told to replace the thermostat. Does anyone have a suggestion??
  • sherrylisesherrylise Member Posts: 1
    Hi I have a 97 Transport/Montana and I am having the same problem I live in Manitoba and it get's to like -40 and I have no heat have you gotten the answer to your question, I have two kids and we freeze in the darn thing, we tried adding excellent coolant but still nothing. It totally suck if you have any suggestions can you let me know
    Thanks, Sherry
    :cry:
  • jegjcjegjc Member Posts: 2
    May be you need to clean the whole heating system (may be the little heating rad is plugged). Is your thermostat in good shape or had been changed. If the coolant is dirty... change and have a good flushing and cleaning.
    jegjc :)
    québec city canada
  • mrallmrall Member Posts: 1
    I have a 2001 Pontiac Montana with about 130,000 miles. A couple of weeks ago the heat stopped working and the temp guage was running on the high side. I started looking around for some information on this particular issue on the internet to see what could be causing it. Based on what I could find, I decided to start with some of the minor parts first to see if they would fix the problem. I bought a new waterpump (less than $30 at the local auto parts store) and a new thermostat. At the same time I bought a new serpentine belt because you have to take the old one off to fix the waterpump. The waterpump on these cars is actually pretty easy to replace as it is up front at the top left of the engine. I think most mechanically inclined people could tackle it themselves. The thermostat is another story. I bought an AC Delco replacement for $15 at the auto parts store. It is really hard to get to. I think I saw another post mentioning this but it is on the right side of the block behind one of the exhaust manifold pipes/shield. The screw at the back is very difficult to get to. I did manage it but I have small hands and I could bend my arm (very uncomfortably) to get to it. I don't know how they do it at the dealer but I wouldn't be surprised if they take off some parts to get in there. I took off the air filter and the hose that runs from it to the throttle body which helped. While I had that off, I replaced the air filter which is not easy as anyone knows who has these vans. At any rate, so far, the temp guage is running more in the normal range so I'm hopeful it is fixed. I think the thermostat may have been the issue as the waterpump I replaced did not look bad and still turned freely. Now my concern is that I may have a manifold gasket leak. The lower manifold gasket seems to have some seepage. I haven't noticed a large loss of coolant though so if it is leaking, it may be slow. I'm anticpating it going at some point based on the history of these engines. If anyone wants more details on what I did for these repairs, let me know. I'm just a shadetree mechanic so what I know is limited.
  • mlkuttermlkutter Member Posts: 4
    The rear air blows hot air.
    The front air works but doesn't seen to blow at full force on high anymore.
    Any suggestions? :sick: :lemon:
  • richardp2richardp2 Member Posts: 4
    I am having somewhat the same problem with my 1998 Montana. It just started a few days ago not blowing any air of any temp out of the A/C vents. I read another blog here and am thinking a vacuum hose maybe loose or broken that controls the linkage of the blower. I can hear the blower fan blowing it just doesn't come out of the vents properly. If the vacuum trick works I will write back.
  • fixcarfixcar Member Posts: 1
    I have a 2000 Montana that I purchased from a neighbor two years ago. It runs great now, but I am not looking forward to winter, as the so called "heater", puts out such a little amount. Everything in the climate system has been checked/replaced (including the thermostat)and still no heat! I am thinking that there might be an aftermarket electric type auxiliary heater available? These were available years ago, but I think there were fire related problems, so they took them off the market? Are there any new realistic ideas of how to get more heat? What was GM thinking; making a car with no heater?
  • jim639jim639 Member Posts: 1
    Help! My 2002 Montana will not put out any warm/hot air. With the temp control at full cold the air moves just fine. The engine runs just fine and at normal temperature. When I turn the temp to hot the air flow goes to nothing and I hear the fan running just fine. Is there a door directing air over the heater coil? Where is it and how do I get to it to see if it is working? Thank you for your help!!!
  • mailmail Member Posts: 10
    Hi Mrall, your posting was Really helpful for me. I was wondering if you had to drain coolant from the engine in some way in order the change the thermostat? I can't seem to find any information on that and I was really impressed that you were able to replace it with only having to take off the air filter and tubing to the throttle body ! Thanks again !!! K
  • kjwerner01kjwerner01 Member Posts: 1
    We replaced the thermostat in our 2001 Montana. Now it seems even worse! The temp goes up very fast when your driving and you have to turn the car off and release pressure/steam from the bleeder vavle by the thermostat. Is it possible to put the thermostat in wrong? Any suggestions you might have would be greatly appreciated! :confuse:
  • 24randyo24randyo Member Posts: 6
    I have a 1998 Trans Sport Montana. Was having the same problem, it kept losing all of it's refridgerant, over about a two week period, and blowing warm air. Had it recharged with dye, still couldn't see a leak, but it still leaked out in two weeks. When recharged with dye a second time, the mechanic finally found that one of the pipes in the cooling manifold in front of the engine had been rubbing against a part of the transmission and rubbed a hole. The hole was against the transmission and the dye was undetectable as it leaked out because it was such a slow leak. He changed the manifold ($80.00 part, 1 hour labour) and it has worked ever since.
  • MKshjjcarrMKshjjcarr Member Posts: 1
    I'm having the same problem. i have replaced the thermostat and still no heat. I have the same year of van and would like to get this problem fixed as it is quite cold here in canada. Can anyone suggest any ideals or fixes to this problem.
    Mine is a 98 Trans Sport Montana. I live in Canada as well, and have had very little heat when it gets below freezing. I was driving on the highway in December, with very little heat, and my temp guage went way up. I pulled over, shut it off, checked the coolant in the reservoir, seemed OK. I thought it might just be the thermostat. Started it up, temp was back down, drove down the highway a couple miles, and it was right back up again. This time, it didn't want to run very well. Had it towed to a garage, found that one cylinder was full of anti-freeze. Once he tore it apart, found that one cylinder head was cracked. It had never been using anti-freeze in the past, and had never been overheated that I know of, so somehow this head must have cracked as I was driving. It was $1500.00 Canadian to do the repairs (which I have found out since was a pretty goood deal). I thought that this may have solved the lack of warm air problem, but it didn't... it hasn't changed at all. Apparently, the no heat and the cracked heads or blown head gaskets are very common for this type of GM engine (3.4 litre V6). All I can say is, you are either lucky or you're not when it comes to this kind of thing with any vehicle. Always pay attention to your coolant level, and don't just look in the reservoir, take the rad cap off and check there too!
  • kenniekennie Member Posts: 38
    I have been dealing with the same heat problems. VENT AIR FLOW: If you are having trouble with AIR FLOW from the vents, I had the same problem and it was fixed after the dealership traced one of the vacuum hoses (about 2-3 mm black wire) that runs over the top left hand (pass side) of the engine and found two cracks, one on top of the engine and the other down behind the battery/fuse box. Back to the heat problem now... van heats up to operating temperature but occasionally goes 1-3 ticks higher but does not overheat but when sitting at idle (say at a light) the heat coming from the vents quickly turns from semi-warm to cool. I've had the coolant system flushed (not the heater core thou - they charge separately for that) but no change in heat. I'm tempted to have the core flushed but will hold off until I look at other things first. When I step on the accelerator I get better heat - revving the engine gets good heat (temporarily) until the engine returns to idle. I'm suspect of two things (again i'm no expert), a restriction of some sort is keeping fluid from either getting to the heater core (air lock somewhere) or a heater core blockage/partial blockage. Since I don't know how the heater core is designed i'm not sure what the likely hood of an airlock/blockage. The other thing i'm considering looking at is the auxilary coolant pump installed on 2000+ vans and manually installed on earlier vans in canada (because its cold here). The aux pump is located around the coolant tank (RHS) and is attached to a temperature switch in front of the engine rad. I'm not sure what i'm going to do next but probably fool around with it before taking it to the dealership... $125/hour adds up really fast and want to use a little grey matter and try a few things first. Your comments/suggestions are always welcomed. I think i'm going to try to lift up the front of the vehicle and try to burp the system as discussed on other feeds then possibly pinch off the aux pump, remove and test with a bucket of water to see what it is actually pumping and when (at what temperatures) it is pumping. Went to the dealership and asked about this pump and they said they have never heard of it going.... but then again FORD dealerships won't admit their springs break (when 1000's of people it has happened to) and the GM won't admit to glasket failures in their montana's... oh so many examples. Anyway keep the ideas flowing everyone. Maybe there is someone out there who has removed and tested a aux pump.. what am I going to see/expect? Cheers.
    2000 Pontiac Montana heating problems in the winter time...
    I AM NOT MECHANICAL EXPERT BUT THIS IS MY SOLUTION TO THE HEAT PROBLEMS - USE THIS INFORMATION AT YOUR OWN RISK AS I DO NOT WANT TO BE HELD RESPONSIBLE FOR USE OR MISUSE OF THE INFORMATION PROVIDE HERE !
    I was delighted this weekend to find an unexpected solution over the weekend that may help some readers that have higher mileage Montana vans. My previous post outlines the problems I have been faced around heat in the van when it gets cold outside (being from Alberta). Through the process of elimination I thought and read about the various components of the heating systems that enables heat in the cabin. Fixing the vent was the first step as the air flow was definitely not producing what was needed. The next was the coolant replacement that needed to be done anyway so doing the flush was practical to do. All the hoses appeared hot just from inspection the thermostat was doing it's job in keeping the engine a fairly constant operating temperature regardless of the weather. So it came down to some sort of blockage or air pocket. I eliminated the air lock with the "professional" coolant flush. 2000+ Pontiac Montana vans have a factory installed Auxiliary Coolant Pump (previous years had them installed by the dealer). These pumps enable greater flow of hot coolant to the heater core needed for cold Canadian winters. I was told that these never fail by two separate dealers. In addition, i've looked high and low for information on these pumps but there does not seem to be any.
    So here is what I found... first the pump should only work on temperatures lower than 'around' 0 degrees controlled by a temperature switch near the front of the radiator behind the bumper. Even though it appears to be running and the hoses are hot, this does not guarantee that it is working. After removing and disassembling it, it turns out that the motor actually spins a magnet that in turn spins an internal propeller to move fluid. If the propeller damaged or seized the motor will still spin giving the impression that it is working. Also, if the motor is not running (temperatures above 0 degrees), then a small amount of fluid can still get through thus the hoses remain hot. With the pump not working the symptoms of little or no heat unless the engine is revving makes perfect sense to taking a closer look at the aux pump.
    Anyway, when I removed it (if you have the skill) and carefully took it apart (only if you have the skill) it is possible (not guaranteed) you may find that it is seized. Using some common sense, I remove it from the engine (without draining coolant - use a bucket to hold up and drain the hoses out a bit), tested it and then proceeded to disassemble/clean/re-assemble/re-test it and put back on the vehicle (put the pump on the outlet side then fill the pump and other hose with fluid/water unit at the top then immediately put on the other side quickly so that minimum air gets in). I've got heat now just like I did before.
    I'm trying to teach my son that using your head and moving through things carefully and thoughtfully you can troubleshoot many thing that even a dealership would not catch right away because we have the free time and they don't. If this information helps solve your problem and you don't need to take your vehicle to the expensive dealership then please help me with supporting the Multiple Sclerosis Society of Canada in which I support whole heartedly each year at the link which you can paste in your internet browser - it is the MS Society of Canada Site for which I have a annual team that raises money for those with this terrible illness and I will show him how being mechanically inclined in life helps others:
    https://msofs.mssociety.ca/2009walk/Sponsor.aspx?PID=1072373&L=2
    All for now... and good luck !
  • jdoddjdodd Member Posts: 1
    I have a 1999 Montana. The rear fan shut off the other day and wouldn't come on untill I hit the back driver side panel. I am think a bad connection but want to know what all you guys did to fix this.
  • superman2superman2 Member Posts: 5
    I am looking to buy a 2001 Montana from a private owner. How can I test to make sure that the AC is working. He said that AC will only work when the outside temperature is above 10 degree C. Is this true?
    That seems really strange to me... the air works in the winter time b/c it greatly decreases the time it takes to de/fog the windows when it is turned on. Also, did you know that on some vehicles the air comes on (regardless if the ac button is in) when you put the vehicle vents on defrost? I'm pretty sure that happens to my montana b/c I started it up once (with AC off) and on defrost and felt the ac pipes and they were ice cold. When buying a montana watch out for transmission problems (hard shifting - take it for a long run to make damn certain it is not hard shifting)... also ask if the van is loosing coolant... if it is you could have a upper or lower head gasket leak which may have been seeping coolant into the engine and the bearings will fail needing new engine.... this is VERY COMMON on the montana... I would call the service center to see what work has been done to ensure that coolant levels are stable. Read many feeds on this !!!! ... choose a montana VERY carefullly !!!! Heat in winter is not great in these vehicles too. Good luck.
    Well, it has been about 6 months since my last post regarding my 2000 pontiac montana with heat issues. Today I fixed it - it ended up being a blocked heater core (front one, the one in the rear was ok). Over the past 2 years heat in the front of the van has been minimal, although I was able to improve it by cleaning the auxilary pump (see previous posts) and by attempting to get air out of the heater cores (previous posts) - these two things improved the heat in both the front and rear cores but the front core simply produced less and less heat until the last month it was blowing cold all the time except for maybe once a week it would blow a little warm and then right back to cold again.
    My diagonostic started with the fact of my previous posts - air locks, aux pump restricting flow (yes - this was happening and fixed it). The rear heater was working very well and producing full heat. I inspected and diagrammed the coolant flow of the van as follows: out of the back right of the engine, into the auxilary pump, out of the aux pump (out of the side of it) to a T-split (one going to bottom of front heater core the other goes to the left and down the firewall under the van to the rear heater core. The return pipes from both heater cores come together into a 3-input T (just above the previous input-T) which leads into the cross pipe which feeds to heat the throttle body and then crosses right in front of the engine (metal black pipe) into the coolant pump (big one run by the motor belt on the left of the engine).
    From this diagram I could conclude that the rear and front heater cores are directly connected to one another in a complely separate system - out of the engine and back to the coolant pump. Therefore, the only reason that there is heat in the back and no-heat in the front core is that either the heater core doors are not opening property or the heater core or T section is plugged.
    I opened as much as I could under the dash to see if the doors are opening properly using the heater switch on the dash...once things are removed and you turn the switch from warm to cold you can see an indicator on the left side of the heater box that slowly turns with the turn of the switch. THere are markings on it to show its maximum and miniumum and mine appeared to match up so I know it was turning - plus I could hear and feel changes happening when I turned the switch - air flow change and temp change (slight). Therefore I ruled out vent's not opening propertly - not absolutely but a pretty good idea they were working. The temp vent is not controlled by vacuume like the other switches are so I was not concerned with that... vacuume controls recirculate and fresh air for example.
    One think I noticed is that when there was heat, if I left the air flow on 1 out of 5 the air was warm.. the more I turned up the blower the colder the air got.. therefore I concluded that the front heater core was not keeping up to the air flow therefore leads me to believe coolant flow to it was hamperred to some extent.
    Front the schematics I determined above, I decided I wanted to flush the heater core rather than remove it because it was going to cost $800+ to do, not including the dealership wanting to diagnostics. The typical way is to remove the hoses from the heater core which is almost impossible - just take a look to see if you can see them ... I looked from below and above and even taking things off it was almost be implossible although rotating the engine forward (not that hard) it would make it easier but still - a frikin crappy job.
    So this is what I did... emptied the rad (from the bottom plug - be careful not to break it) into clean containers since I wanted to re-use any clean fluid. Next, I disconnected the output end of the auxilary pump (making sure not to spill any fluid) and put the pump end pointing into the coolant reservoir. Next disconnected the small hose from the coolant pump (big one) going to the head of the engine (disconnect top of hose not bottom) and then removed the pipe screw on the left side and lifted the pipe out (carefully) and put a piece of hard plastic with a bag on top jimmied between the pipe bottom and the pump hole. What you have now is a loop of input and output to the 2 heater cores. The aux pump end sitting in the resivoir leads directly into the engine and is placed here so that any pressure/air in the engine pushes fluid into the resevoir and not the ground !!!
    Next I wanted to get out any fluid in the heater cores and lines so I hooked up a low presure air compressor to blow air into the outlet (left side hose connected to cross pipe (on left) which pushed fluid out the aux pump hose (hose hanging that was disconnected off the side of the aux pump) - hook up a clear hose to this using precausion that you DO NOT GET ANYTHING INTO THE SYSTEM - no plasic, dirt, rubber, tools, ends, etc.) and run into an empty ccontainer for recycyling. When I ran air though emptied into the container and all kinds of crap came out ... pushing air in this direction is opposite to flow so anything stuck would be pushed out.
    After I got all the fluid out I could, then I hooked up a hose (instead of air) to one side and attached another milk jug to the other end (right side). I put the water on low and ran until the water coming out was clear - it took 2 milk jugs and the second jug I used higher water presure - but not full.
    Now the cores are clear of coolant so I hooked up HOT WATER from the house and turned the presure up slowly until it was fully flowing and left it run for about 10 minutes and letting it drain down the driveway. I am no expert but if you are having any resistance at all DO NOT PUT MORE PRESURE than that is coming out the other end !!!!
    I then disconnected the water and went back to air to push out the water I put into the cores. Once clean I hooked everything up and cleaned out the coolant resevoir (recycled all the crap I got out of it into a container I could take into recycling) and hocked everything up, made sure the drain plug was back in, filled the system, removed air from the system let heat up and to ensure the entire system was filled properly with no air pockets.
    WAMO.... i've got FULL heat in the van again after 2 years or more of slowly decreasing heat due to blockage. Since the back core was producting heat before it was correct for me to assume the from was blocked.
    I would like to comment that I had the van into the dealership twice and both times they blamed my in cabin air filters, vacuume line problems (which they claimed they fixed) and an engine overheat problem that they claim I need to look at... this is not the case.. the engine does not overheat and does not loose coolant and a pressure test was done twice and there are no problems here.
    Anyway, I wanted to pass on what I have done... this summer i've also replaced spark plugs (not for the faint of heart) and completely cleaned out the throttle body.
    It's been a go
    Continued from my previous post.....
    It's been a good year... finally I won't freeze this winter.
    Please please please please be environmental conscience when you are doing such work... I did not drop a single drop of coolant that I could capture to take into the recycling center - it takes very little more effort to be responsible in this manor... please take the time to work carefully and understand what you are doing, the potential concequences and if you do not understand EXACTLY what is happening using these instructions without making assumptions then PLEASE DO NOT USE ANY PART OF THE ABOVE. I AM NOT A PROFESSIONAL BUT I DO HAVE GOOD DIAGNOSTICS AND TROUBLESHOOTING SKILLS THAT HELPS ME UNDERSTAND WHAT I AM DOING. I AM NOT RESPONSIBLE FOR THE ABOVE INFORMATION - USE AT YOUR OWN RISK.
    Take care... Kennie
  • carfixer4ucarfixer4u Member Posts: 3
    Hello Kennie,
    I've a Montana 2000 and got the same problem that yours. I did what you've said and it worked for my van too. So, I canceled my appointment with the dealership and save a lots of money. As suggested from you, I made a donation ($25) to the Canadian Society for Multiple Sclerosis (CSMS).
    So, we are probably three satisfied persons now: you for the usefulness of sharing infos and influencing someone to give a donation; the CSMS for a $25 donation; and me for having probably saved a couple of hundred dollars.
    Yours.
    Carfixer4u
    Hi Carfixer4u,
    Just wanted to send a sincere thank you for your donation. You are the first person to donate and it will be a good story to share with my family tonight and especially my son. I certainly feel greteful that I was able to help in some way - even though i'm not an expert in this area. Much much appreciated but not at all expected. Take care and good luck with your van.
    An unfortunate story with my van as of late... the head gasket blew and cost me $2000 to fix at a engine rebuild shop (was going to be $2600+ at the dealership). When they took things appart the gasket was so bad that it corroded the heads and 3/1000th needed to be taken off the heads to make them true to put back on. The dexcool becomes acidic and eats away at the poor quality of gasket GM used at that time - that is why you hear so many vans having this problem but mostly the manifold gaskets, not so much the head gasket. Lucky I was not on vacation somewhere. Best to keep an eye on the oil color and the coolant color to ensure you catch it early if it should happen to you. The proceedure for cleaning the heater core I described had nothing to do with the head gasket failing... it was just time for it and I think the problem was coming for a long time from what they told me.. he could tell the multiple locations of leak on both front/rear head banks.
    Kennie
  • 2009sv62009sv6 Member Posts: 1
    we own a 09 montana sv6 we bought in sept of 08 in nov of 08 we come to find out that our van has no heat at a idle it can run for hours and never clear frost off the windshield now living in sask this does create a problem for one why have comand start if the vehicle dont warm up that is a $300 dollar option thats a waste of money now they have done all kinda of things to this van proping the van on one end in the air for several hours (thinking theres a airlock) to now putting foam pipe insulation on the heating line which last weekend driving in the slush on the hiway it all got ripped off (imagine that ) now after a year and a couple of months of fighting with gm the problem is still not fixed and i was told thats just the way the van is now ive tried several times to trade this reject van off but apparently montana vans are not worth nothing anymore and gm does not seem to care they have my money and with threats of stopping payment there responce was it wont bother us it will just ruen your credit rating and if you turn the van in then its called a volintary repo so its your loss so here we go through another winter going to hockey games hauling our kids around a praire winter with no heat in our van if in sept of 08 id have known this brand new van had no heat i would have not bought it will i buy another gm product that im not sure of by the way i have been treated after all i have been very paicent (till now ) if i do buy another one it wont be in the summer thats for sure it will be in the heart of the winter for sure but for now i guess to warm it up at -40 i will fire it up and throw a brick on the peddle to clear the window off i guess my options have run out
    p.s if anone has plans of how to mount a wood burning stove in one of these van please drop me a line
    Just wanted to provide a few comments which may or may not help. Reading my post regarding heat (the one that describes the process to flush your own heater core) would provide a fair amount of information regarding heat in these vehicles. The van being so new I am immediately going to suspect one item (if your van has rear heater core) is that the auxilary pump is impeeding the floor of coolant to your heater cores in some way, or one of your t-values between the output of the engine coolant and into the aux pump and back to the black crossover pipe (that crosses across the front of our motor along the spark plugs) is somehow blocked. I can't see how your heater core is plugged but flushing it and actually watching what volume of coolant you can get through it would certainly help eliminate anything to do with the path of circulation. If you are not getting coolant out of your motor it would immediately overheat. So if you are not getting ANY heat in the van (front or back) then other things could be that your heater core doors are stuck closes bypassing your heater core completely... since this door is MOTOR driven (not vacuum driven like the other heater controls) it is possible that the motor is burned out to the closed position OR the flaps (valves or doors) are stuck. Are you getting any air flow throu the vents? When you turn the heater from cold to hot do you actually hear a change in air flow inside the dash?... look at my other posts for more info... if I can help in some way I will. I am sorry that if you have tried and investigated all this already... don't know how far you have gone with the dealership but my experience is that you can not trust their diagnosis... I had my van in 3 times they always seem to have another reason why I was not getting heat. Finnally I had to test, troubleshoot and fix myself as you may have read in earlier posts.... which is quite frustrating. Your van may not be an extended van with rear heater core like mine so the short version maybe a little different... and mine was 2000, yours is 2008 so again, maybe it is different but the way GM saves money it is likely exactly the same systems.
  • chamkakechamkake Member Posts: 2
    After a short trip today, i noticed a rattle sound coming from the engine compartment. Upon arriving home, I opened the hood and found the rattle appeared to come from the compressor. If I turn on the air, the noise stops. Any ideas ? Could it be a clutch on the compressor with bad bearings ?
  • spike99spike99 Member Posts: 239
    As a suggestion, take your GM vehicle to your trusted auto shop and ask them to confirm your vehicle's "sound making" part. Sometimes, sound travels across attached items - which makes it hard to confirm the "core root" of the problem.
    Assuming the noise is from a "worn out" AC clutch, I'd get it fixed ASAP. We had a 2001 Sunfire that blew its AC clutch. While getting repaired, the auto tech showed me 3 other broken (worn out) GM AC clutches in their garbage can. Thus, proving that GM AC clutches are under built. Getting the vehicle's AC clutch fixed ensures "better" main belt alignment. Thus, lowering its risk of blowing a main belt. Especially if you travel in locations that lack road-side auto shops. Also... If replacing AC clutch, do get its main belt inspected / replaced (if needed) as well. Many auto techs like to replace both at the same time. Especially on older GM vehicles. Thus, do proactively "budget" for both critial item replacements.
    Hope this helps...
    thanks for your feedback.
    i read somewhere to spray some wd 40 on the clutch.
    i did so and the sound / rattle was gone.
    problem appears to be solved, should i still be concerned ?
    it's winter now, won't need the ac for 6 months.
  • lolak70lolak70 Member Posts: 2
    Last week, the heater stopped blowing in my 1998 Pontiac Transport van when I start it using the (ProStart) remote control starter. The van starts fine with the remote, but the headlights and heater don't work until I actually go in the van and turn the key to on. The heater is left turned on the mddle blower setting all the time, so it isn't a problem that it got turned off previously. Any ideas what would cause this? Thanks for any help!
  • montana999montana999 Member Posts: 5
    What did you use to access the lower thermostat housing bolt ?
    It is down behind the exhaust manifold pipe on my V6 3.4l.
    If you are not taking off the black crosspipe (that connects just over the thermostat into the throttle body) then it's a [non-permissible content removed]. I can't remember now but I think I took off the throttle body (because I was going to clean it anyway and replace the gasket - for fun) so it made it easier for me. Some places on the internet say that you can
    get a wrench in there... but I can't see how, it would be quite hard to do and I tried and couldn't. Even with the throttle body off and the cross pipe pulled out of the way its not a fun housing to get back on... Hope this helps !
  • mbettsmbetts Member Posts: 1
    I know it is cold outside (0 F),but after driving 30 min. it isn't getting very warm inside cabin .I ran van with heat on & it got a little warm & then the windows began to frost, so I turned it to defrost & it worked & then we were cold, so I had to keep going back & forth---we recently traveled 1000 miles to higher elevation & have returned,& noticed this problem.Any ideas before heading to a shop & hopefully not getting ripped off?? Oh, we have kept up with scheduled care & it has 109,000 miles on it.Thanks for the help
    If you read through my previous posts/solutions my bet is that your heater core is blocked. If you have rear heat and it works but the front does not produce heat then it is almost certain that is what is wrong. If you don't have rear heat to test then a heater core flush is the only way to know forsure... you may have a manifold gasket leak getting air into the coolant resulting in low coolant and thus low volume flow through the heater core... i'm no expert but these are my observations owning the van myself (2000) with rear heat. Good luck !
    This is very simple. If you have heat for your passengers seated back and cold air in front, try this: 1) disconnect the auxiliaire pump; 2) disconnct the small pipe on the other side of the motor (approximately over the belt); 3) flush in both direction with your garden hose. When the water will be clear, replug both hoses, fill it up with antifreeze and VERY IMPORTANT open the two bloods to evacuate any air that have penetrated in the system, OTHERWISE the motor will overheat while the air in the defrost will still be cold. So, check very carefully the heating temperature in your dash.
    Last point: when blooding the systems (remember there are two blooders to open), it could take you from 5 to 15 minutes to have a final result i.e. only antifreeze comes out without any bubbling.
    Think environment, use a garbage can to keep liquid off the ground. The best way to do it is to first wet the floor. While doing this any antifreeze would be very easy to wash with water, otherwise your asphalt will keep good memories of your work...
    If this help you why not consider making a donation at one of your favorite caritative organization? It can only cost you a fraction of what a garage bill is able to do...
    Ciao!
    Denis
  • jjallen07jjallen07 Member Posts: 7
    I have a 2004 Pontiac Montana that I am experiencing air flow problems when you move the Climate Control to HEAT. When it is on COLD, the air flow is fine, but when you move the controller to the heat setting, you hear the air deflecting and the air flow from any of the vents up front go to almost nothing. I am not sure what is wrong. The dealership wants almost $800.00 to take it apart.
  • chicagocartoyschicagocartoys Member Posts: 1
    The issue is with the remote starter and not your vehicle. Your car has two accessory wires and both need to be connected for the accessories to function properly. Most remote starters have 2 ignition and 1 accessory outputs and if they are not connected properly your heater will not work properly. If the remote starter used to activate the heater before, check the fuses for the remote starter itself and make sure none of them have blown.
