Visitor Agreement.
-Frank
What I also forgot to mention was that ALL MODELS now get the cabin filter standard. They also say they are 1 inch higher.....than what? Parking my 04 next to an 05, I didn't see any difference in height.
-Frank
How many miles on the car? I did a flush and replace on my previous Outback at 30000 miles, as per the maintenance schedule. Looking at the old coolant afterwards, however, I believe the coolant was fine and could have easily held out to 60000 miles -- it was extremely clean and the color looked good. So next time I will check/test a sample of coolant before undertaking a flush and refill.
Craig
John
It's great that you want to do the flush/fill at home. You will save $60 and learn something new about your car. Very admirable :-) Any repair manual will tell you to do roughly the same procedure, which you can also find great descriptions of by doing a google search for: "do it yourself cooling system drain flush refill". Make sure you have prepared and have a way to bring your old anti-freeze to a recycling center. I use old plastic gallon jugs like you'd get if you bought water or milk in a plastic container. You may have trouble finding a coolant recycling center in your area, you may have to call around a bit to service stations and ask them where you can bring it.
I always have no trouble finding the coolant drain cock on the radiator (looks like a plastic turn-knob at the bottom of the radiator) but have yet to find my coolant drain bolt on the engine. I'd love to hear from anyone who has found that drain bold and can take a photo and send it to me!
Elissa
As for the refill, I don't see a good description on line of "burping" the system during the refill. That involves :
1) with engine off and heat knob turned on and the bleeder bolt on the engine open, fill the radiator with coolant until the fluid coming out of the bleeder bolt runs out with no bubbles.
2) When you've filled it up, run the engine with the radiator cap off until the upper radiator hose gets hot. Squeeze air out by squeezing the upper radiator hose - you will see bubbles come up through the top of the radiator cap opening. Continue to add more coolant while the engine is running and you continue burping it until it's full and no more air bubbles come up.
3) Turn the engine off and allow it to cool. Check for leaks and check the level again just to be sure.
Elissa
Don't forget step #4 - put the radiator cap back on ;-)
-Brian
At the bottom of the radiator you'll see a plastic screw on the passenger side to make it easy, at least on my '98. Make sure it's not hot!
Elissa: I have a pic but it's at work, and I'm off for the next two weeks. Look for the black screw on the passenger side, you should be able to find it.
-juice
So, is it more important to pay attention the length of time or the mileage between flush/fill? Bob L.
I think we had it real bad (at least 2 CEL incidents/year), but I also believe from the number of posts that the early model Foresters were generally bad for CEL and related sensor issues (I was told the coil died because of corrosion, but I cant verify this...). It's an annoyance under warranty that quickly becomes a money pit after warranty, and doesnt seem to ever stop once it starts (at least in my experience in 4 years and 100,000 km of ownership).
Maybe the techies can comment on if there is any good reason why failures may continue to affect indiv cars after sensors have been replaced, and if there is any preventative maintenance we can do.
Of immediate importance to me - any comments on the next gen Foresters (03-), particularly the FXT as I have promised wife that CELs will not happen any more (or this will be the last Sube in our garage).
JP
-Frank
My 2001 Forester S now has about 94K miles. So far, it has had 4 O2 sensors replaced, the coil pack, ignition wires, spark plugs (wires and plugs went bad shortly after I had already replaced them at 60K, due to the bad coil pack, according to the dealer), catalytic converter, wheel bearing and head gasket. The clutch was replaced (due to "judder") 4 times. Some items were replaced under warranty, and some out-of-warranty costs were shared with Subaru as a show of "good faith", which was much appreciated. However, I've laid out the cash for one of the clutches, the wheel bearing and the catalytic converter. Even when the items were covered under warranty, the inconvenience also came at a cost, as you already know.
We also owned a 2002 Outback, which was bought new, and had even worse problems, and was replcaed at 16K miles with an '03 Outback. Except for one clutch replaced at 7K due to "judder", the '03 has been great so far (knock on wood).
We've decided that we'll probably give Subaru one more try for our next new vehicle. However, that will depend on what else goes wrong between now and then.
Len
I have never had a CEL appear (watch me jinx myself on this) in over 4 1/2 years and 67K miles of ownership, nor have I had a knock sensor or coil pack fail. I did have the oxygen sensor replaced under recall notice, but it had not failed.
One of the reasons we are going with the FXT is I assume that it's motor and associated electronic gizmos are very different from the N/A 2.5l....I have not heard anything scary yet about the Sti-derived 2.5T, which should be overengineered for the FXT application.
That's another factor in my choice of a Forester XT, but it's not the primary factor. Honestly I've been pretty happy with my '00; I just want the added oomph from the XT - I can't deny it!
Ed
My 2 cents, Owen
It seems like the Forester has a pretty good reputation overall. Are there any particular issues we should watch out for?
By the way, other vehicles we looked at were the Mitsu Outlander (hard to get safety features, buzzy engine), Pontiac Vibe (A/C doesn't blow cold) and Subaru Impreza (too expensive for what you get). The Forester was the most expensive of all of these, but it's also bigger and has more safety features. Hopefully it will be a little more reliable than our 1995 Windstar GL, which we've had for 10 years, 84,000 miles...and 2 head gasket jobs.
-Andrew L
Oh my gosh! That's a load of work done on one car! My '01 Forester S also had a decent amount of warranty work: first gear and syncho, rear diff, axle seals, water pump, oil pump, leaking piston seals... I sold it at 54K because I had bad feelings about the 5/60 warranty expiration approaching. Everything had been covered up to that point.
Your catalytic converter - when did that go? You know it's covered up to 80K right? The EPA mandates that the cat and other "major emissions components" be warranteed by the factory for 80K miles.
Either way, you are more patient then me at still buying Subarus, that's a world of bad experience! I've had one wonderful Subaru - '84 GL that I sold when it hit 200K miles and one dink - the '01 Forester S that I dumped at 54K. Just hoping my '04 Forester XT turns out to be more like the first one!
elissa
My catalytic converter was replaced a few months ago at about 90K miles, and cost me nearly $600.00. Despite the troubles I've had with this car, I hate to admit that I still love it. It has the best balance of what I need in a vehicle. With all the problems it HAS had, it has never left me stranded (unlike our '02 Outback did on several occasions). I just wish it was nearly as trouble free as my '92 Sentra. 240K trouble free miles and counting.
I figure that I've made up for all those Subaru owners that have had zero problems with their vehicles, and that the law of averages has to be on my side when I buy my next Subaru.
Len
My $.02
-Frank
Sounds like you got the car I expected to purchase, also!
Len
...best, ez
The catch? In MD, at least, you'll fail the biannual emissions inspection.
Andrew: welcome, nice to see a familiar face from another thread. Remember the alloy wheel thread from a while back?
Guess they'll love the steel wheels, I know you prefer those.
34.2 mpg?! Down hill the whole way? WOW!
While no vehicle is perfect, what I can say for Subaru is that they have stepped up to the plate with each issue I've seen reported here since I joined in 1999.
Clutch chatter? Many have new clutches, even though the issue didn't seem to affect longevity.
Head gaskets? 8/100 warranty extension plus they treat it for free, can't complain about that.
Wheel bearings? Again, covered under warranty plus they changed the design in 2003 and the problem is now rare.
Check engine lights? O2 sensors replaced for free, plus make sure you had that recall performed if yours was affected, that made them less sensitive.
You read the past 20 posts and might get scared but IMO Subaru does stand behind their product.
-juice
Sorry I couldn't give you much in the way of good news.
-Frank
With all that said, however, I'll still likely buy another Subaru, since I feel that their vehicles offer the best combination of the features I want and need in a vehicle.
Len
Also, I have drained and refilled the radiator several times in the last couple weeks but have not drained the engine of coolant (I have trouble finding and accessing the drain bolt). Anyone know how much the coolant circulates between the radiator and the engine? I'm wondering if I still need to drain the engine of coolant or if it's cycled through enough that it's all clean-ish.
Elissa
-Frank
*sigh*
elissa
Wheels: Yes, ours has the steel wheels. The full-face design makes them look a lot like alloys...I can't imagine why anyone would want to pay extra for the alloys on this car, which look basically the same.
We have the car now and we haven't found any initial defects, so that's a good start (better than either of our last two new cars). The build quality seems pretty good. Also, I was surprised to see that the engine is fairly accessible and not covered up by a big plastic thing -- I hate it when they make it hard to get at anything under the hood.
-Andrew L
JP
My wife's 03 OBW dog grate lets her keep the cargo cover, which is a good thing. On the other hand, I think the Forester's will take more of an impact since its firmly anchored in the cargo cover's receivers.
I like having it in the back when I'm hauling stuff with the seat backs up, since it will take a good hit before anything comes sailing at the back of my head.
HTH
Larry
How far down do the new roof brackets protude as the old ones if left in place with the barrier removed restricted cargo capacity, when loading large items with the seats down.
I have to say between 1998 and 2005 they could have come up with a quick release design that allows the barrier and cargo cover to work together. How many Sube wagon owners have dogs, must be a large %.....
You would be able to leave a dog inside with the engine running and A/C on while you make a quick errand without locking your keys inside or worrying about theft.
Len
However, after driving a few American cars in the past, i guess there are some small features that could be improved - one, the power buttons could be slicker, two, automatic door locks - while in motion it would be nicer to have the car doors automatically locked and three,(I guess a minor thing but those who spend some time sitting idle in a parking lot while waiting for their partners (who are shopping for example) will understand)the radio turns off along with the ignition.
Other than these, I am loving every moment behind the wheel, a little tough at times, since my wife loves to drive it as well
Craig
Luvmuh - In the Edmunds Subaru Crew section there is a thread for Suggestions for Subaru that Subaru of America montiors, fyi.
-Dennis
You did get my point about the radio power and you are also quite correct about turning the key to ACC to keep the radio on. However, I drove a Chevy Malibu for a month and it had this nice feature - the radio was on even if I turned off the ignition - I guess I just got used to it.
Happy driving!
I found myself in a hire car recently that allowed the radio to be switched bak on for one hour with the ignition off. A sensible compromise preventing the battery going flat. Any longer than that and you relaly should have found a motel!
Cheers
Graham
Len
