2006 Grand Vitara vibration problem
                    This new discussion is for owners of 2006 Grand Vitara 4x4 SUV with the automatic transmission.
If you are experiencing a vibration while accelerating between 45-60 MPH, then please post your comments here.
This is an on-going problem for many of us and we need to make sure that Suzuki of America hears us loud and clear, and developes a solution.
This is in line with the speed mentioned and in 4th gear.
It's definitely there while driving also and gets stronger if the engine is under load.
I have no idea though what they could do about it after the fact sort of re-designing the engine...
I am what you would call a Suzuki enthusiast...I purchased my first tin-top Samurai new in 1986 and traded it in w/ 110,000 on the clock on a new 1992 4-door Sidekick, and imagine that, it never came close to rolling over the sami!
I currently own a 1991 Samurai that is significantly modified for off-road use and haven't rolled that one either, on-road or off. That roll over crap was just to kill its sales over here (jeep sales were suffering in 87 & 88).
Anyway, back on topic... I hope that someone posts up what Suzuki determines as the cause for this. I know about driveline vibrations, and this didn't feel like wheels or driveshafts to me. However, the theory on the fuel delivery that someone posted earlier is a very possible cause.
Early production 2006 GV's had some issues with vibration that was taken care of with the addition of a dynamic damper (there is a TSB on this with the VIN break, but it was basically any GV built before Aug 2005). Later 2006 and 2007 GV's have had no issues with vibration at speed.
TSB No. TS 04 10255
Division: Automotive Section Title: Driveline/Axle
Category: Technical
SUBJECT: FRONT DIFFERENTIAL REAR MOUNTING BRACKET AND/OR REAR DIFFERENTIAL DYNAMIC DAMPER INSTALLATION
MODEL(S): GRAND VITARA (JB627) 4WD ONLY
YEAR: 2006
AFFECTED VIN(S):SEE BELOW
CONDITION: Slight harmonic vibration from the front and rear differentials between 55 and 70 MPH.
CAUSE: Some early production 4WD vehicles may not be equipped with the improved Front Differential Rear Mounting Bracket and the Rear Differential Dynamic Damper.
CORRECTION: 1. Vehicles with VIN numbers that fall within the VIN ranges shown below may need a rear Dynamic Damper (27475-66J01) installed. Please inspect your dealership’s inventory and any 06 model year Grand Vitara that comes into your dealership for any reason. If the rear Dynamic Damper (27475-66J01) is not installed perform this correction. If it is a customer vehicle, please be sure to notify the owner before performing this correction.
I know it is the driveshaft(s?) that is at fault because the dealer had eliminated the vibration almost completely after one of the mods, which unfortunately returned after a transmission leak repair.
My take in this is that the way the driveshafts are installed is very critical requiring a specific procedure that Suzuki has not perfected yet. The fix is possible because it was vibration free at one point. Except for this, it is a terrific vehicle, a pleasure to drive and great dealer service.
I have read your Issues with vibration,mine Is also at 70-80..At 80 on up It is gone. I also feel It around 50 or so but not as bad. The other thing Is If I hold the steering wheel firm with pressure at the vibration speeds I can almost stop it..but let go of the wheel and It bounces like crazy..Are you getting the same result? My car Is not shaking..just the steering wheel.(p.s went and had my tires balanced at 3 different shops with the same results)
The head tech is also going to drop the trans a little bit to change the driveshaft angle.
Regards, Vitara4me.........
They told me to go to a dealer so I will. But if the one nearby dealer tells me that all is well despite the contrary what am I to do?
So I am back to square one again. I don't think Suzuki gives a crap about the vibration issue. If they did they would be bending over backwards to fix it. It seems that Suzuki is hoping that I will just "go away".
I had to buy an air filter recently. I called every parts store in the area; Pep Boys, AutoZone, Kragens, NAPA...no one has an air filter for this vehicle.
I had to drive to Santa Ana, California (a one hour drive) to find a dealer that was still in business. The dealer (Suzuki Depot in Santa Ana), told me that I had to drive to a different location 3 miles away to buy a filter. I drive to the other building and order the filter. 20 minutes later, I am told that the filter is not at that location. I have to drive back to the dealer to get the filter. So in other words, the dealer had me drive to another location, just to PAY FOR THE FILTER, then go to another building to get the filter. What kind of customer service is this???
It took me a total of 3 hours to get a #!%& air filter for my Grand Vitara.
Maybe I will wake up tomorrow and all of this will just be a bad dream. :lemon:
Regards.......... :mad:
With this vehicle, it seems there is a trend starting. I've had the front seat replaced due to the leather wearing at 12,000 miles...that's another issue. I want to stay with Suzuki since this is my 3rd vehicle in the past 4 years (2 XL7's). With my driving, I purchase a car every two years. I guess I'm a little more anal when it comes to vehicles since I practically live in it.
I'll let Suzuki know about the ECM re-program but the some of the droning noise is while your sitting still and around 2,500 rpm's. Will the reprogramming fix it?
Thanks for your reponse.
You mentioned wear on the leather seats. Was this from failed seams, wear of the material itself, or the "baggy" leather problem?
I was standing outside of my vehicle using my laptop in the drivers seat and happened to notice these vertical lines. There were around 8 or 9 of these lines on the area in an open area on the left bottom. It almost seemed like the leather was spreading apart. We figured it was wearing from me getting out of the vehicle, but at 12,000 miles? The dealer did replace the seat cover but it took a couple of times for them to get it right. They actually had to take it to an upholstery place and use steam to flatten the leather out.
I haven't checked the insulation on the doors yet but I don't know if that's necessary at this point. Installing insulation would be a very timely task.
I have a feeling that Suzuki isn't going to take responsibility for the "design issues". I actually enjoy driving this car locally, but this vehicle isn't designed for the highway driver. It's making me sick that I have to address these issues.
Went for a short holiday over Christmas, drove around 600km return trip, mostly freeway, the GV was very comfortable & sure footed.
The seats looked like crap for a brand new car, but since it's a year old now, they seem more acceptable. I noticed other cars with leather seats have the material installed such that there is provision for the material to "expand" when sat upon, while the GV's seats are simple flat panels. I'm even wondering if the leather seats are so firm because then the leather panels don't have to stretch so much.
We also find that the rear headrests leave depressions in the rear seat bottoms when the seatback is folded forward.
But, hey, it didn't cost as much as a Lexus.
