Honda Accord Hybrid Transmission Questions
Having an issue with your transmission? Discuss the problem and work out a soultion here.
Is my electric ATF pump busted or is this a design problem? The dealership says it's normal. I have a hard time believing that.
It is disconcerting nonetheless!
At 1,600 rpm in fourth and fifth gears (sometimes third and sometimes at 800 rpm when coasting to a stop) a loud noise arises. It sounds like someone installed an 800-watt subwoofer in my car. It seems to come from every direction and it's deafening.
It only does it after the car has warmed up and it only does it around from about 1,550 to 1,650 rpm (sometimes at 800 but rarely). It only does it when in ECO mode but not sure if that's related because the car is cruising anyway.
I took two amateur mechanics for a spin and they were stumped. It's not the rear brakes as they were cool to the touch after the ride. It's difficult to say if we feel any vibrations as the sound floods the senses and it's impossible to pinpoint where the sound originates.:dunno:
Other than that, no issues with the car.
This was a well known problem with the Active Noise Cancellation module; mine was not covered under warranty; involves a new ANC unit, new door speakers and they have to remove the head unit to get at the ANC..... kind of traumatic repair ( dash ripped open, doors ripped apart ) if you ask me.
Today, a solenoid in the tranny went out at 120K. Other than that, phenomenal car with none of this surging everyone is talking about. Knock wood.
