Lost? Ask a Host for Help!
1235755
  • d1aned1ane Member Posts: 6
    I've read some threads stating that increase the amount on your down payment for a lease is not a smart move...any opinions??
  • patpat Member Posts: 10,421
    The place you started would be a great place for this question in addition to your other one. Here's the link: General Questions about Leasing Vehicles.
  • dedadeda Member Posts: 2
    Is there some kind of secret latch for the rear seat of the Honda Odyssey to unfold? I have a 1999 and I have folded it down but now it seems stuck. The manual says to leave the strap exposed but somehow mine has fallen down beneath the seat and when you lift up on it its almost like its caught. It will raise a little but not enough to unfold completely to return to the original position. I feel like there is a switch somewhere that I should release. Please help anyone?
    Try asking in the Honda Odyssey 1999 - 2004 discussion.
  • justdadjustdad Member Posts: 1
    I have a Pontiac Sunfire 2002, runs well for the most. The check engine light comes on, when I check it it tells me the gas cap is bad. I have replaced it but the same fault comes back. Any ideas. :confuse:
    Take a look through the Pontiac Sunfire group for a good place to post your question.
  • wmemorriswmemorris Member Posts: 1
    I have a 90 Mazda Protege that is loosing power at times. Happens at freeway speeds and if the key is cycled off and back on the problem goes away for a little while. This morning I kept it running and the check engine light came on and lots of black smoke out tail pipe when idling. The distributor, fuel pump and fuel pump relay have been replaced. I am not sure how to retrieve the DTC when this occurs again. Any thoughs?
    Check the Mazda Protege group for suitable topics.
  • jimodysseyjimodyssey Member Posts: 1
    When I come to a stop sign occasionally the engine will rev up as I brake. I apply the brake hard and put it in neutral and the revving stops. The dealer pretty much tells me the car can't do this and maybe I'm applying the gas instead of the brake. "NO WAY" is this the case. Anyone else experience these symptoms?
    Give Honda Odyssey: Engine Problems a try. Also, be sure to check the Honda Odyssey group for other related discussions.
  • chipichipi Member Posts: 2
    I have a 2003 RSX Type-S. I live in San Francisco, CA.
    I was shocked in March of 2006 to find that the engine control module (ECM) was stolen out of my RSX. The car was parked in my driveway. What was confusing was that the alarm of the car never alerted me to the theft and there were no visible signs of break in or damage to the exterior of the car. I did not understand how the thieves were able to bypass the alarm system of the RSX. I called Acura Customer Care to express my concern about this apparent vulnerability. There was nothing that they could offer me to assist me in preventing this type of theft from happening again.
    I forgot about this incident until the morning of December 1, 2006 when I discovered that once again the ECM had been stolen from my car while it was parked in my driveway (I have no garage). Once again I turned to Acura Customer Care to try and help me prevent this from happening a third time. And once again I was left with no confidence that this type of theft can be prevented.
    This type of theft has become so common in the San Francisco bay area that the parts department at Acura of Serramonte has now started to stock the ECM. So this problem is not mine alone to bear.
    I have done some research on this problem and I have my hypothesis on how the thieves might be gaining access to the interior of my RSX.
    I believe that the thieves could have a "jiggle" key which allows them to open the car door and bypass the alarm. Alternatively, they could have a master key or perhaps they are able to pick the door lock of the car.
    Lastly, it is conceivable (but less likely to me) that they have intercepted and stolen the RF code from my keyless entry fob and then programmed this code into a fob of their own.
    I am unable to come up with any plausible strategies to counter any of the above methods for bypassing the RSX alarm system.
    So my question to the forum users are this:
    1) Have any of you experienced a similar kind of break in to your RSX?
    2) What are your thoughts on how these thieves may be bypassing the RSX alarm system?
    3) What ideas do you have to prevent this from happening again?
    While I love this car, if this should happen to me a third time I will have no choice but to sell it and get a car that would be less likely to suffer this kind of unwanted attention.
    Thank you for any assistance or expertise you can provide on this most upsetting subject.
    Sincerely,
    Chip Isaac
  • happycooperhappycooper Member Posts: 3
    Hi
    Does anyone know what the price range will start at for base 2007 Mini S automatic?
    Acura RSX (All years/types) would be a good place to start. Also, check the Acura RSX group and consider adding a discussion.
    Find out what kind of deals others are getting in MINI Cooper: Prices Paid & Buying Experience.
  • maestrotwomaestrotwo Member Posts: 1
    I have no brake lights on my Jeep. I have checked the fuse, bulbs, and the pedal switch and all are fine. Any suggestions?
    There are a couple of electrical problems type discussions in the Jeep Cherokee and Jeep Grand Cherokee group or try the Jeep Grand Cherokee: Problems & Solutions discussion.
  • wartownewartowne Member Posts: 3
    There is no entry area for POSTING in the Suburban Topic list.... WHAT am I doing WRONG?
    It looks like you found it! wartowne, "Chevy Suburban: Problems & Solutions" #175, 3 Dec 2006 7:42 am!keywords=
  • davul1turedavul1ture Member Posts: 3
    Check engine light came on...mechanic says we need to change egr valve ($250-$300) per computer diagnosis. Also, suggested that this is no guarantee that the check engine light will not come back on once the valve is replaced and computer alert is reset; Worst case scenario could mean the circuit connected to the computer could be bad or burned-out because of the bad valve and could cost over $1000!
    Is this possible? What are the repercussions if - 1. nothing is done (needs to pass TX state inspection in a few weeks) 2. Replace valve but don't repair computer circuit if or when diagnosed bad.
    What is the best plan of action for option 1 & 2 above.
    Suggestions and comments welcome!
    -O. :confuse:
  • schertzschertz Member Posts: 1
    Anyone know where to find chrome trim for side
    doors on 2006 Highlander toyota
    Schertz
    Try asking in one of the Toyota Camry discussions.
    Someone in the Toyota Highlander: Accessories & Modifications discussion may have a suggestion or two Schertz.
  • driverodrivero Member Posts: 2
    How does one post a new topic on here? I can't seem to find that.
    Go to the Pontiac Grand Prix group and check whether any of the topics match your issue. If not, then click the "Add a Discussion" link on that page and follow the directions.
  • clevineclevine Member Posts: 1
    I'm considering buying a 2002 Accord V6. It has a sunroof, and I've never owned a car that has one. It is possible and safe to use a roof rack or a "clamshell"-type car-top carrier atop a car with a sunroof (with the sunroof closed, obviously)? Thanks for any guidance.
    Some sunroofs may interfere with accessories placed between the crossbars of a roofrack. Check with the other owners in one of the Accord discussions to see if this is a problem with the '02's. The Honda Accord: Accessories may be a good one to start in; check the Accord Group for others.
  • oboogieoboogie Member Posts: 1
    I purchased a used Outback with 85000 miles. The transmission started slipping in forward gear( automatic transmission). I had to have the transmission rebuilt. After the rebuild, it still did the same slipping and so it was rebuilt again. It worked great for about one month and then it blew the mail seal in the transmission...so that was replaced today and when the mechanic took it for a test drive, it blew the main seal again and lost all the transmission fluid. Anybody had similiar problems or any advice. Pam
    Check the Subaru Legacy & Outback group. Use the "Add a Discussion" link if none of the existing topics fit your needs.
  • bbydolly13bbydolly13 Member Posts: 2
    Can anyone tell me why my temperature gauge would shoot way up into the red then return to normal within a few seconds? It doesn't seem to matter if the truck is warmed up or cold, and I have already flushed and filled the radiator and replaced the thermostat.
    Check out the Chevrolet Silverado & GMC Sierra group. Use the "Add a Discussion" link on that page if none of the existing topics fit your needs.
  • sshifrinsshifrin Member Posts: 3
    I get a Shimmy/Shake/Vibration on my 2000 4 runner that is a 1 year old problem. When I purchased it, it was fine.
    I did get hit from behind while I was stopped at a light with a replacement of the back end and all body parts.
    I've taken it to multiple places including the dealer and no resolve. The shake occurs at 65 - 70 MPH. I have had an alignment done, rear shocks replaced, tire rotate and balancing, 4 replacement tires, and the front brakes replaced.
    All mechanics have said that the front suspension parts are fine.
    I have read that maybe there is a special balancing for the factory wheels for some Toyotas. the lug centric.
    Is this one of them?
    Also, I have read the thread about the problem being characteristic on 06 model but this is a 00.
    I have a 2WD 4 cylinder. I had Cooper Tires now I have winterforce tires. Both have the same problem. A smooth ride til i hit 65 MPH.
    Could it be a drive shaft?
    I am feeling it in the steering wheel and the gas pedal. It's not intense but it's bumpy and unpleasant. My passengers also feel it though not as strong.
    any one with any insight, please advise.
    thank you.
  • stormbirdstormbird Member Posts: 1
    I've got a 2001 Focus LX. It keeps blowing the fuse that operates the blower motor. Any suggestions?
    I believe others are discussing similar issues in Toyota 4Runner.
    Also, check the Toyota 4Runner group.
    I recommend joining the Ford Focus: Electrical Problems discussion.
  • sandpmovesandpmove Member Posts: 3
    cruise control with 19,000 miles on it. Prior to the crash the car was in very good condition. Edmunds.com or Kbb.com give the trade-in value of the vehicle to be about 12,000$. The car was financed by toyota financial and the pay off balance is 11804$ as of today. My insurance company is Geico and the fault in the accident is mine. I have the following questions and I would really appreciate advise here: 1) What value should I expect from Geico? Is it the same as I see in Kbb.com? 2) What I owe toyota financial will then be the pay off balance minus the amount geico claims is the fair market value of the car. Correct? 3) Will they pay for title change, sales tax when car was bought etc? 4) Please share with me any pointers to make sure that I get a good deal from Geico - anything I can do to improve my chances here. Thanks very much!
  • Kirstie_HKirstie_H Administrator Posts: 11,254
    You posted in the correct location - check back here: sandpmove, "Replacement Cost by Insurance Company for Totaled Vehicle" #113, 6 Dec 2006 10:28 am for responses!
    MODERATOR /ADMINISTRATOR
    Review your vehicle
  • pjm47pjm47 Member Posts: 1
    I have changed all the bulbs and still have a lot of unusual problems. When i go in reverse the back-up lights on the right side do not light up.When i have the head lights on or drive at night and step on the brakes the signal lights on the dash light up and if i turn on the right signal it will blink fast if i have my foot on the brake and normal when off the brake or when the head lights are off.The left signals are working properly.
    Any ideas to the remedy would be appriciated.
  • rixyrixy Member Posts: 2
    My car lost all power while driving. I have replaced the crankshaft possition sensor,DIS Coil and still no spark Could it be the ignition? The motor tusrns over but no spark. How do I check the ignition and if not the ignition, What else can it be.
    My car lost all power while driving. I have replaced the crankshaft possition sensor,DIS Coil and still no spark Could it be the ignition? The motor tusrns over but no spark. How do I check the ignition and if not the ignition, What else can it be. Lost in Spokane.
    Check the Chevy Venture group and use the "Add a Discussion" link if your problem isn't addressed there.
    The Voyager/Caravan Electrical Problems discussion may be helpful. Also, be sure to check the Chrysler/Plymouth Voyager, Dodge Caravan group.
  • ursula10ursula10 Member Posts: 2
    I don't know how to start a new post. I didn't see a topic with Mercedes CLS500. I am contemplating purchasing a 2006 Mercedes CLS 500. The dealer says he's giving me a good deal, but the 2006 costs just as much as the 2007. Granted the 2006 only has 41 miles and has more features like navigation and electric trunk closer, but the 2007 has more horsepower and is newer model. I'm just wondering what would be a good offer to make. The original price of the 2006 was $76,000 and they will sell it for $67,000. The new 2007 is $67,000. I am young and I look even younger (22), and I am a female and I don't want to be taken advantage of. When I initially entered the dealership everyone was hesitant to wait on me. Finally one person came over but it was easy to see that he didn't have my best interest at hand. Onlyafter checking my credit did he welcome me with open arms and take me seriously. He initially tried to sell me the car at face value. I left and he's called me every day almost for 2 1/2 weeks. On the 3rd day he called and informed me of the new price. I later found out that the lower price was what the car was supposed to have been selling for anyway. I guess if I had jumped on it, he would have sold it to me. Can someone HELPPPP me. :cry:
  • 99jcc99jcc Member Posts: 1
    I have a 99 Cherokee Classic. The Check Engine Light comes on periodically (every 3-4 months) and stays on for a few days, then goes away. It runs fine, oil, temp, and other gages are normal. It doesn't seem to follow a pattern, like after I fill up, etc.
    Any thoughts?
    Give the Jeep Owners: Care and Maintenance discussion a shot. Also look at the "Check Engine light discussion.
  • jimmy18jimmy18 Member Posts: 1
    Does anyone know where the oil sending unit is ? Is it very difficult to change. I'm having the same problem as a few others, gauge going to zero give it gas and it returns to normal. Is it ok to drive to the parts store?
    Thanks Jim
    Jeep GC oil pressure problems seems to be the place to commiserate.
  • marsha7marsha7 Member Posts: 3,703
    About once weekly, the screen comes up asking me to sign in...I check it to "remember me" but it seems that my sign-in is intermittently lost...is it me, my computer, or is something malfunctioning???
    Bob
    Bob,
    That's a sporadic problem that hits a couple of members once in a while and our techs are still chasing it down. One thing that seems to work is to click "back" in your browser and click on the sign in link again, it will usually log you in.
    Hi Ursula and welcome aboard!
    We don't appear to have a CLS-Class discussion for purchasing, but I would recommend reading through Mercedes-Benz CLS-Class: Lease Questions - that should give you a starting place, and I'm sure Car_man will be able to point you in the right direction if you have more questions.
  • memphismanmemphisman Member Posts: 1
    Where is the factory location for the CD changer located in a 2002 Land Rover Discovery II?
