Visitor Agreement.
I was shocked in March of 2006 to find that the engine control module (ECM) was stolen out of my RSX. The car was parked in my driveway. What was confusing was that the alarm of the car never alerted me to the theft and there were no visible signs of break in or damage to the exterior of the car. I did not understand how the thieves were able to bypass the alarm system of the RSX. I called Acura Customer Care to express my concern about this apparent vulnerability. There was nothing that they could offer me to assist me in preventing this type of theft from happening again.
I forgot about this incident until the morning of December 1, 2006 when I discovered that once again the ECM had been stolen from my car while it was parked in my driveway (I have no garage). Once again I turned to Acura Customer Care to try and help me prevent this from happening a third time. And once again I was left with no confidence that this type of theft can be prevented.
This type of theft has become so common in the San Francisco bay area that the parts department at Acura of Serramonte has now started to stock the ECM. So this problem is not mine alone to bear.
I have done some research on this problem and I have my hypothesis on how the thieves might be gaining access to the interior of my RSX.
I believe that the thieves could have a "jiggle" key which allows them to open the car door and bypass the alarm. Alternatively, they could have a master key or perhaps they are able to pick the door lock of the car.
Lastly, it is conceivable (but less likely to me) that they have intercepted and stolen the RF code from my keyless entry fob and then programmed this code into a fob of their own.
I am unable to come up with any plausible strategies to counter any of the above methods for bypassing the RSX alarm system.
So my question to the forum users are this:
1) Have any of you experienced a similar kind of break in to your RSX?
2) What are your thoughts on how these thieves may be bypassing the RSX alarm system?
3) What ideas do you have to prevent this from happening again?
While I love this car, if this should happen to me a third time I will have no choice but to sell it and get a car that would be less likely to suffer this kind of unwanted attention.
Thank you for any assistance or expertise you can provide on this most upsetting subject.
Sincerely,
Chip Isaac
Does anyone know what the price range will start at for base 2007 Mini S automatic?
Is this possible? What are the repercussions if - 1. nothing is done (needs to pass TX state inspection in a few weeks) 2. Replace valve but don't repair computer circuit if or when diagnosed bad.
What is the best plan of action for option 1 & 2 above.
Suggestions and comments welcome!
-O. :confuse:
doors on 2006 Highlander toyota
Schertz
I did get hit from behind while I was stopped at a light with a replacement of the back end and all body parts.
I've taken it to multiple places including the dealer and no resolve. The shake occurs at 65 - 70 MPH. I have had an alignment done, rear shocks replaced, tire rotate and balancing, 4 replacement tires, and the front brakes replaced.
All mechanics have said that the front suspension parts are fine.
I have read that maybe there is a special balancing for the factory wheels for some Toyotas. the lug centric.
Is this one of them?
Also, I have read the thread about the problem being characteristic on 06 model but this is a 00.
I have a 2WD 4 cylinder. I had Cooper Tires now I have winterforce tires. Both have the same problem. A smooth ride til i hit 65 MPH.
Could it be a drive shaft?
I am feeling it in the steering wheel and the gas pedal. It's not intense but it's bumpy and unpleasant. My passengers also feel it though not as strong.
any one with any insight, please advise.
thank you.
Also, check the Toyota 4Runner group.
MODERATOR /ADMINISTRATOR
Review your vehicle
Any ideas to the remedy would be appriciated.
Any thoughts?
Thanks Jim
Bob
That's a sporadic problem that hits a couple of members once in a while and our techs are still chasing it down. One thing that seems to work is to click "back" in your browser and click on the sign in link again, it will usually log you in.
We don't appear to have a CLS-Class discussion for purchasing, but I would recommend reading through Mercedes-Benz CLS-Class: Lease Questions - that should give you a starting place, and I'm sure Car_man will be able to point you in the right direction if you have more questions.
