Visitor Agreement.
Our 2003 Forester XS automatic has occasionally run VERY rough right after starting. Engine stumbles and starts to stall, black smoke coming out of tailpipe. Shut the engine off, restart it and everything is fine, like nothing ever happened. This has happened twice. Any thoughts?
snap back to the windshield and/or hit the fender
and/or hood with my palm--the Horn beeps 1-2 times..Is it part of the alarm system or a short somewhere ??
Any of you have the same prob. ???
Tks. Deadeye
Ed
Turn the key to the On position, but wait about 3 seconds before starting her. You'll hear a "whirr".
My guess is you have either air in the fuel lines, or condensation.
-juice
Another question... There is an AWFUL squeak coming from my steering column...any solutions? Anyone go to the dealer for this?
Seriously, no idea - our FXT does not squeak - but sounds like you should get it checked.
JP
was different than the other. I looked and the very bottom of the driver's seat
(the last few inches) is not leather, but rather a carpet material while the
passenger seat is leather there. It's where the rear passenger would put
their foot if they put it on the seat in front of them rather than on the floor or
under the seat. Can you guys check to see if yours is like that too or tell
me if mine is missing a little leather piece?
Steve
My daughter once untucked the fabric on my head rest.
-juice
-Frank
Would a Forester with stock tires fill the bill ? He's just looking to go off-road to go fishin' in the surf without getting stuck in the sand.
-Frank
Do the rear seats on the Forester fold flat? As an example - I know on the Honda CRV that the seats do not make a flat surface when folded however they can be folded up against the back of the front seat.
So - can someone please tell me how the rear seats in the Forester fold?
Thanks so much!
A skilled driver will do just fine. Mine's been all over the beach and never once got stuck.
-juice
I get an annual permit for Island Beach State Park.
http://www.imagestation.com/picture/sraid124/p61028f389707c46f2414eec231e7508b/f80f1a68.jp- - - - g
With stock tires, I did ok last summer airing down to about 12-14 psi's. On some of the very hot and dry summer days there were a lot of trucks in the sand, and it was pretty deep.
Towards the end of the summer I went with a 17" Michelin Pilot Sport A/S in 225/55/17.
http://www.imagestation.com/picture/sraid143/p05902ea1ef062ef99ea2cd97135203b7/f6970f8c.jp- g
It gives a wider footprint and slightly more ground clearance. I only went on the beach once with that set up (aired down to 18 psi's.), but I had a lot more confidence than I did the OEM's.
I didn't have traction problems with the OEM's, only that the sand would hit the bottom of the car when it was deep. I saw a stock pre-'03 Forester with an annual pass last summer on the beach as well. I did not get stuck at all last summer, although I was stuck there a couple of times a few years back with my Outback Sport. I was only airing down to 25 psi's at the time (lower car, smaller tires).
I have one of these too:
http://www.azpinstalls.com/rallyarmor/index.html
There are also a couple of lift kits for the Forester if he's interested.
-Dennis
Any problems with changing oil or jacking points with this kit for an '03 Forester? I probably need one of these as I drive regularly in orchards and vineyards and often get branches wacking my underside.
John
-juice
Putting it back on took some time getting used to. I just make sure that I have my head light (the one I wear on my head) on. :-)
-Dennis
To put the seat back in place, simply push the seat in the upright position with a little force. The tab should automatically lock back in place.
I asked the dealer if he could order the wiper de-icer windshield to replace the stock one I cracked. He was cool with it (for an extra 170 dollars). Just want to know if anyone has tried to wire this into a 2005 X. Also...where are the connectors located; can they be accessed after the glass is installed ?
Finally, is the de-icer's performance worth the effort.
Marco
Chuck
-Frank
Also, occasionally on a hard turn I hear a crunchy kind of squeak on the right rear. I asked my mechanic to grease the suspension but it didn't go away. He said that sometimes the gas tank can rub against the inside of the body. Anyone ever hear of this?
My dealer quoted me 300 bucks to replace the glass. I called a few other places and found them to be not much cheaper than the dealer quote. Some were even higher.
No one - including the dealer - is offering a genuine, made-in-Japan, windshield. The dealer says they just don't ship 'em here.
I could order a "Subaru" one with "Subaru" stamped on it. However, the dealer says that even this glass is not made by Subaru, merely made for Subaru here in the 'States.
He said it's a much better idea to use an "aftermarket" windshield, as it is the "same glass", just with a Subaru stamp and a 150-dollar markup.
The questions...
Does the 300-dollar figure sound right for an "aftermarket windshield ?
Is the original factory windshield or the Subaru-stamped one any better than the "aftermarket" I'm getting ?
Is it really not possible to get the "original" here in the US ?
Marco
Glass choices - had many replacement aftermarket windshields - never a problem. Just make sure to go to a good reputable glass place - it's not so much the glass, it's how good a job the installer does. $300 sounds a bit steep, I would call around and see if you can get below $250.
The glass Subaru uses isn't exactly known for its strength/durability so I certainly wouldn't pay extra for it.
Like all manufacturers, Subaru doesn't actually "make" its own glass but uses a 3rd-party. I know of no reason why you couldn't order it in the US. My guess is that it's a hassle for the dealer to order OE glass and he probably has a higher profit margin on the aftermarket glass. Still, considering there's little to be gained by staying OE, I see no reason not to go the aftermarket route.
-Frank
The 2nd year they had blocked the path, so I went to the beach just south of Rodanthe (forget the name) and drove there. That was a longer drive.
Sandy did fine, in fact that's when and where she earned her nickname.
18psi on dry is probably OK at low speeds, but I would not do that for more than a few miles and at under 50mph or so.
Crunchy Squeek - have your wheel bearing inspected.
Marco: your car insurance doesn't cover it? Mine does, in MD it's under the Comprehensive policy.
Subaru uses Carlex for some of its glass, but like Frank I'd just get whatever the vendor recommends, they're more familiar with it than I am.
-juice
I agree that better wipers are a big improvement. Haven't gotten around to changing the FXT's yet, but switching to Bosch when I had a WRX and on my wife's OB made a bid difference. Ice doesn't stick to them as bad as on the OEM.
-Dennis
-juice
-Brian
Michael
-juice
But that would be offset by the lower air pressure and evaporation at higher speeds! ;-)
Edit: Don't get the silicon on the brakes!
DaveM
The problem is your zip code. Move to Florida and you will not longer have that problem. ;-)
Spray or rub some lithium grease on the inside of the wheel well/mud flap. And keep those wheels clean and waxed (they're painted, so wax 'em).
It's not any better or worse than any other vehicle IMHO.
-juice
So, why did you get an XS instead of an XT this time around?
Craig
Problems starting could be a number of things and gas could be one. If the fuel tank is low, there could also be condensation if the weather is wet.
lark6 on here had a problem starting is '05 XT and replaced the battery when it was only a few months old.
-Dennis
Two things I can think of, was it extremely cold? If so, consider the block heater Subaru sells as an accessory. Edit: no, just read your message again, you said it was mild.
Another is condensation in the fuel tank. I think it was Kate that used a bottle of DryGas and it solved her problem.
3rd thought - be sure to pre-pressurize the fuel line, turn the key to the on position but hesitate a few seconds before you actually start it. You will hear the fuel pump "whirr".
The fuel injection has to build up very high pressure (something like 150psi) to operate normally.
-juice
I was thinking on something as I was driving into work today; I figured I'd pass my thoughts on to you all for your opinions.
One of the things I like about my 05 Forester XS is it reminds me (loosely) of my Pop's 80's AMC Jeep Cherokee Lareado (sp?). Roughly similar size, equally capable, etc. Yes, the Jeep looked more trucky (recall I did say LOOSELY). Any how, I was thinking of my satisfaction level in driving my Forester, and indeed the only thing I wish my Subaru had was a 6 Cylinder like my Pop's Jeep.
But then, *drumroll pls.* I got to thinking (uh oh ..). :P
Comparing the engine in a mid 80's 6 cylinder Jeep vs. the 4 cylinder engine in a 05 Forester (non-turbo), which is better? Which would you prefer? Did 1.5 decades of improvements make the Subaru's 4 superior to the Jeep's venerable 6?
Jopopsy
The I6 was very easy to work on for a DIY, at least in my Comanche.
-Brian
