Are automobiles a major cause of global warming?
Not sure if this is precisely what you're looking for, but you may find something:
http://www.arb.ca.gov/adam/cgi-bin/db2www/polltrendsb.d2w/start#
That site indeed shows that the air in the San Bernadino area is FAR cleaner today than in the mid 1980s.
So, what can we conclude from that?
1. That CARB has done it's job pretty darn well.
2. Visitors to Raging Waters probably will not be coughing from smog.
What we CANNOT conclude from that data:
1. The huge increase in the number of cars on the road in California in the last 20+ years has made the air considerably dirtier.
1984 total registrations in CA: 20,276,000 (approx)
2005 total registrations in CA: 33,164,000 (approx)
The total of vehicles almost doubled, but the air is much much cleaner. So where is the vehicle effect data?
Check again. It was actually the exact opposite in regards to the Supreme Court. They ruled that the EPA has the right to declare CO2 a harmful substance and limit its emissions. The Federal Government is a different story, as they're too entrenched in special interests to ever get anything done. 19 states and numerous municipalities have taken steps to combat global warming. It's real, we must slow it and "believing" otherwise is like "believing" Earth is at the center of the universe in the 16th Century because a few "scientists" say so.
LA is all alone as the worst.
San Bernadino is the dirtiest county in the country.
See this page:
Clean and Dirty cities and counties
That is probably a much more difficult metric to establish conclusively. However, I would believe that you are seeing the actual effects of more and more stringent pollution controls on newer cars gradually replacing the non-existent or ineffective controls as older cars are removed from service.
In other words, the pollution control technology works. The general California population was able to 'enjoy' more and more automobiles clogging their roads while AT THE SAME TIME reducing the levels of harmful pollutants going into the atmosphere.
So, in the face of this scenario, what was the typical anti-car environmentalist to do? Afterall, the mantra for decades was 'reduced pollution through reduced consumption' when technology (apparently) has shown us another way.
Answer? Redefine the pollutants. Now, the pollutant is CO2, which is unaffected by the pollution controls, and the ONLY way to reduced CO2 as a 'pollutant' IS to reduce consumption.
You can ride around in a Yugo while these so called experts are riding in private jets, Limos & yachts, don't count on me to join your circus parade.
Not so much in 2007.
As Ahnold said in 2005, "The debate is Ovah."
There are vastly more studies and credentialed scientists now who have data supporting AlGore's view than there were a few years ago.
If CO2 is a greenhouse gas (most everyone believes it is) and cars and manufacturing operations which are geared toward creating things which humans use create CO2 and it adversely affects the global climate, then cars DO contribute to the problem.
How muchso is the question.
I don't see any plan laid out that will not be economically disruptive. No country that has signed on to Kyoto has lived up to the treaty. That should tell you something. Japan is trying and is way behind their goal. Kyoto was ill conceived and a political tool, nothing more.
Yep, CO2 is a greenhouse gas. So is water vapor. And water vapor contributes FAR more to the 'greenhouse effect' than does CO2.
Which begs the question: why the heated debate over man-made CO2 emissions? Why no debate over man-made water vapor? Has the amount of WATER VAPOR in the atmosphere changed perhaps?
You know it has. Melting snow produces water vapor. More snow melts because the temps are hotter.
Are autos a considerable cause?
Very good. But, if WATER VAPOR is a much greater component of the greenhouse effect, is it POSSIBLE that NATURAL processes leading to additional water vapor in the atmosphere has a GREATER impact on global warming than manmade CO2 (which has a much lesser effect in the greenhouse effect).
In other words, could a NATURAL PROCESS (perhaps, increased solar radiation) lead to increased evaporation rates, leading to increased water vapor, leading to a greater greenhouse effect?
And, if water vapor is a BIGGER COMPONENT of the greenhouse effect, and if we feel than man is at least partially responsible for water vapor, why not concentrate efforts on reducing man-made water vapor?
BTW, what is the tailpipe emissions from a hydrogen powered automobile?
Um, water vapor.......
Those we CAN control and those we CANNOT control?
Is that not a logical conclusion?
Control what you can control and the rest is out of your hands.
I am not saying that we should all build bonfires with old tires and dump raw sewage into the streets. I just think the whole issue of "Global Warming" is designed to play on the ignorance of the masses. What these jerk politicians are saying is you little people have to sacrifice so we can maintain our opulent lifestyle undisturbed. When Al & Ahnold bring their tonnage of CO2 down, I'll think about doing the same. Guess what I can add a few hundred tons a year and still be a better example than they are.
Yes. I believe that global warming is caused by several factors.
"Those we CAN control and those we CANNOT control?"
Ask yourself: if water vapor is a much bigger component of the overall greenhouse effect, AND if man's activities lead to more water vapor in the air, then WHY is all the political pressure focused on CO2? Does the pursuit of "alternate" energies/fuels/technologies reduce CO2 yet lead to MORE water vapor?
I think that's a fair question.
Here's another one for you larsb: what is the Earth's "normal" temperature? Just WHAT is the "optimal" temperature for the planet? Why the AUTOMATIC assumption that ANY change in global temperatures (either up or down) is, by definition, bad?
I don't know what people are saying about "lowered temps" but let me comment on "higher temps."
Negative affects of higher temps:
1. More and longer droughts, leading to more wildfires in the West (where I live)
2. Melting polar ice means rise in sea levels, which means coastal areas (expensive homes and beautiful beaches) will be swamped and the coast will move inland, costing you and I (via government spending) billions of dollars to re-work the beach for tourism.
3. Warmer gulf waters means stronger hurricanes.
See tons more info here:
Click here
If you look at the evidence of global temperatures over what time man can scientifically gather information from, you will see that the evidence shows that the earth has and will continue to, undergone temperature changes.
Some fairly severe. And man wasn't around during those times, so what factors do they contribute those to?
As I said before, there are many scientists and data who say it is happening and many who say it is a natural trend of the earth. There are those who will filter the data to read the way they want.
There have been soil samples that show a high CO concentration from times where they calculate the earth's temps were warmer. What was the CO levels from? Us?
We weren't around.
So, we are in for drought, famine and mayhem.
What's new? This has been an ongoing thing since the 70s.
The vehicles today are 100 times more efficient. They produce far less "greenhouse" gases in the last 10 years, than the last 100 years.
If you really want to cut down CO levels, then let's concentrate on one of the largest contributors of CO.
MAN. Not manmade things, but man himself.
What we exhale.
So, why don't we eliminate the problem.
Let's put a limit on kids. 2 per family.
Let's limit how many breaths we take per day, allot each person so many breaths per day and fine them for going over their allotted usage.
Man has over run this planet and we continue to multiply. So, let's limit everything.
Kind of sounds silly, doesn't it?
I don't think a single person that knows anything about the science of GW is not aware that climate changes have occured for billions of years on earth, for many reasons.
There's also absolutely no doubt that man adds carbon to the atmosphere and we know why. The question is, how much is that addition affecting current (and future) climate change.
The reason is that it is both. Climate change is a natural trend. Man's impact, whatever it is, is superimposed on the natural trend.
They've improved, but not even in that time zone. In 1971, the fleet average was about 14 mpg. In 2000, it was about 22. New car averages went from about 15 to about 28. This is about 100% (double) which is perhaps what you meant.
Let's limit how many breaths we take per day...
Our options are not limited to such things. We can find alternative energy sources (non fossil-fuels) and develop carbon sinks. Not to mention other, presently unheard-of technology to stabilize things.
Ignoring the problem is, OTOH, undoubtedly not a good idea for our decendants, if not us.
I was referring to emissions.
I mis-spoke.
I should have typed that the polutants are about 100 times less. Diesels, especially.
One solution, with Ethanol, E-85 and biodiesel, while is theoretically great, all have their short comings.
With the demand for corn, will come rising corn costs. Greater demand will bring higher costs and lower availability.
Biodiesel has problems with gelling and causing filtering problems and until those can be solved, can't be used very efficiently in the winter without additives.
Oh trust me, I am not saying to ignore the problem, but to say that the sky is falling is reaching a bit.
Take the facts and make your own judgement, but take in ALL the facts, not just the ones that Gore wants you to hear.
Nice sidestep - but you're ignoring my point: just WHAT IS the "optimal" average global temperature? Did that temperature just HAPPEN to be whatever it was in the year 1900?
If global WARMING is "bad", then the flip side (global COOLING) must be "good", correct? No?
Then are you saying that ANY CHANGE to our global temperatures (whether man-made, man-contributed, or completely natural) MUST be bad? Does this even make any sense?
All I'm asking is for you to ask yourself: if this is PURELY a scientific debate, WHY does one NEVER hear about the possible BENEFITS of global warming?
Now, about your 'negative affects':
"1. More and longer droughts, leading to more wildfires in the West (where I live)"
Warmer global temps means more evaporation of surface water to the atmosphere. More water content in the global atmosphere means GLOBALLY more precipitation. Is it possible that weather PATTERNS would be affected leading to LOCAL areas receiving less average rain? Sure. But it's also possible that areas currently receiving little rain may in fact receive MORE desired and needed rain. You can't just look at YOUR little corner of the globe and say "gee, we may get more wildfires so global warming is bad for EVERYBODY" (I also find it mildly suspicious that the geographical areas of this country MOST prone to believing alarmist environmental propaganda ALSO happen to be the areas to suffer the most in a GW scenario.....)
"2. Melting polar ice means rise in sea levels..."
First point of physics: if we (hypothetically speaking) melted every last ounce of SEA ice on this globe, sea levels would not rise by a single mm. Fact. Floating ice ALREADY displaces it's own mass of liquid water; melting it wouldn't do a thing.
Second - the latest updated UN reports on sea level rise, over the next 100 years, is less than 20". That's 20 INCHES. Over 100 years. In fact, it's been difficult to actually measure just how much the global sea levels rise (or fall) due to the simple fact that the land ITSELF rises (and falls) over time. It's called plate tectonics.
"3. Warmer gulf waters means stronger hurricanes."
In simple terms, a hurricane is a heat engine, which depends on a difference between a heat supply and a cold sink for its power. For a hurricane this is the difference between the temperature of the ocean at the storm's bottom and the upper atmosphere at its top.
So yes, warmer water temps would lead to stronger hurricanes IF THE ATMOSPHERIC TEMPERATURE WAS CONSTANT. But, ummmmm, aren't we talking about global warming, in which the ATMOSPHERE gets warmer? And, since the atmosphere tends to warm up MUCH faster than water, one would think that the temperature DIFFERENCE between the water and the air was being REDUCED, leading to (ta daaaaa!) WEAKER hurricanes....
I don't think anyone has shown that to be true.
Why don't we just conclude "NO" as an answer and retire this topic?
That sound you heard was my jaw hitting the floor...... :surprise:
That 56% represents about 20 million people. No wonder California is taking the lead on new standards for greenhouse gas emissions.
I will be interested to see if the EPA changes its stance at all after the anti-science Bush leaves office.
Actually we are not off course. It must be determined if GW is a man made phenomnon or natural, before we can put the blame on the automobile. I am firmly on the side that says GW is a political tool used to gain control over the people.
As was pointed out alternatives to fossil fuel powered automobiles may be even more contributory to GW.
One last question. Where did they measure this temperature that has supposedly gone up? It was not in San Diego or the rest of the US. I believe this Winter is the coldest in the last 150 years or so. It is the coldest winter in my memory. It killed trees in our neighborhood that are at least 50 years old.
How many of those disciples of GW in Hollywood have denounced their opulent CO2 producing lifestyle? It is all elitist propaganda.
PS
56% represents the blue constituents in the state. It further shows how polarized we have become. No science involved just politics at its ugliest.
Whew !! Conspiracy alert !! Conspiracy alert!!
Gary, please enlighten us:
Whom, Praytell, is this mysterious group of people who are attempting to "gain control over us?"
That's really very...........(better button my lip before the hosts whack my mole)
Deny, Deny, Deny all you want. There are some fairly good and reasonable arguments that can be made against it
But there is even more data supporting "GW" as you call it too. That data is not denied by thousands of educated scientists who have done the science.
If GW is not a political tool. Why would a high profile politician such as Robert Kennedy Jr. come out with all these wild claims after Katrina that this disaster could have been avoided if we had signed the Kyoto Treaty? Why has Al Gore made a movie about GW? Could he be trying to get aligned for another shot at the White house? DO you think either of these very wealthy politicians have given up their contribution to GHG?
I am not proclaiming or denying a change in global temperature. I would be interested to know how they came up with that information. When there is a wide disparity in scientific opinion on a subject it cannot be considered fact or a consensus. I have talked to REAL scientists from the University of PA that were studying the upper atmosphere in the Arctic. They do not make any wild claims on the cause of this possible warming trend.
I think I asked this before. Which countries that have signed onto Kyoto have met the goals on cutting GHG?
Well, here's one group for starters:
http://www.carbontax.org/
It looks like a new and different approach to re-distribution of wealth.
Did Robert Kennedy really say Katrina could have been avoided if we had signed onto Kyoto? Or was it something more like, "Katrina is the type of natural calamity that worsens as a result of GW, which is why we ought to be doing something about it, like signing onto Kyoto"? I honestly don't know exactly what he said, but the comment you attributed to him would be very much on the brash side, even for him.
I heard today that Schwarzenegger converted one of his Hummers to run on biodiesel, and the other one to run on hydrogen. ;-)
edit...isn't Carl Sagan dead?!
Boy, are you ever cynical. I'm sure it's just a coincidence that the party most interested in "wealth re-distribution" ALSO happens to be most in favor of "carbon taxes"......
Yep. So is Robert Kennedy......
Thanks Larsb.
And it's RFK, Jr. who's still around - big whitewater kayaker. How can you not like the guy? :P
Oh hell, I missed the Jr. part.
"How can you not like the guy?"
He looks WAY better than I do. Of course, by that logic, I ought to be irritated by 95% of the adult male population....
Next, they will make us buy carbon credits for the CO2 we breath out. Don't worry about not having a car, hell, worry that some gov't bureaucrat will come to your house and stuff a gag in your mouth to "save the planet".
This is the logical conclusion when radical enviromentalism morphs into "Giaism" (worship of mother earth).
Localized pockets of air stagnation that frequents the LA area deserve strict emission standards, but it is not cost effective to inflict those same emission gadgets on new cars operated in sparsely populated regions.
Exactly - euph. Oil fires in Kuwait that burned out of control for a year, also made zero difference in the world's or even the region's climate - It's arrogant for humans to think they actually have that much control over the planet's natural order of things.
electric bill to cool my house in summer: $170/month. Much less.
Cold months cause more coal burning than the hot months do for us northerners.
Gasoline for my houshold to drive for a month: $525 at $2.95/gal
Cost to move closer to job :$20,000. 7% realtor commission, etc.
Cost of a higher efficiency car: $25,000. My 11 yr old 3690 lb. car gets 27 mpg.
My family's monthly gas savings from replacing our worst, 22 mpg car with a 35 mpg car: $24. More could be saved by replacing our Astro van but it can't be replaced by anything more efficient in it's equivalent size. The Astro gets 23 hwy and has 170 cu ft. cargo capacity.
Tax on new car in first month of ownership, including excise for 1st year: $1440
Number of 24's in a 1440: nearly 60. 5 years is a long time just to recoup the day 1 taxes on the efficient car. If you double the 6000 miles a year we drive our least efficient car to 12,000 miles a year, then the taxes are recouped in 30 months.
Savings from driving less since 2004 when gas started going up: $56/mo. Cost to do that: $0. this looks more promising.
Does a new high efficiency car really help the planet? Gas consumed for workers to earn $18,000 which is the value of the efficient replacement car? I figure the avgerage contributor to the car makes $18/hr, so 1000 hours of work is required. that's half a year. Avg energy consumed by 1/2 year for an American worker? I assume they live just to make the car. I guess 6 months electric bill at $1200 and 6 months gas at $1200. It takes energy to make food and water too but I'll leave that out. That $2400 of energy, which if converted to all gas at $2.50/gal is 960 gallons burned. How many miles does the new car have to drive at 35 mpg instead of the old car at 22 mpg to save these 960 gallons? It saves 169 gallons/10k miles. So it takes 56,800 miles to hit the break even point for the planet for gas consumed. How many people keep their car more than 56,800 miles? Both cars don't have equal emissions, but the driver of the 35 mpg car probably drives a bunch of extra miles because it's so efficient. Then consider the manufacturing and houshold waste products of everything that goes into making the new car and someone living to make the new car. Way more landfill for that stuff than the car itself will ever need.
Luckily, the US greenhouse gasses are only 10% attributable to personal vehicles. The Airplanes, Trains, ships, semi's, busses, power plants, nascar, and all the other things make the other 90%. The US is a tiny piece of the Earth's population, maybe 5% of it. A reduction in US private auto emissions or an increase in US car mileage would not be noticable on a global scale. In how many months does the world's population grow by the population of the US? Maybe 30?
So I see the best moves as keeping your car as efficient as possible, driving efficiently, consolidating trips, and buying new only when necessary. I'm not always doing these things myself. Strangling our American industries with emissions or CAFE regulations can't help much and might end up increasing imports that can be made in China where they don't care at all about pollution and a new coal burning power plant comes online every day. Why should they (US industry) have to act much better than we do? Their health enables them to provide us the jobs we can't survive without.
Oh well it could be worse as we might be forced to walk...... :sick:
Rocky
Every once in a while we are subjected to myths. Before GW it was the Millenium/Computer problem and today most people still think the new millenium began in the year 2000.
I wonder if by some miracle he was elevated to the Presidency, how he would approach our energy needs and "GW"?
Latest report from ski resort Whistler/Blackcomb is they have had over 42 feet of snow fall on them this season.
Just as sure as there are more airplanes in the bottom of the oceans than submarines in the sky GW is a political myth.
I was shocked to find out he drives a car like mine (Lexus LS430), not a Prius!! What a hyprocrite! I'm glad to see virtually everyone here isn't buying this junk, but has a brain sufficient to see through the desperate attempt to be relevant. But the media would have you believe that it's a foregone conclusion.
Has anyone defined "major" here? After all, the topical question requires a definition, presumably some percentage to qualify as "major". Unless one assumes that a) there is no global warming going on and/or b) the emissions that cars are adding to the atmosphere is zero, the question is not whether cars are contributing but rather what % contribution they represent.
Further, has anyone offered a % to prove the case either way?
I also asked which countries that signed onto the Kyoto treaty had met the goals set forth. Same lack of response. So at this point in the thread I would say the automobiles have little affect on our changes in climate.
Quite frankly I am more concerned about the 60% reduction in the bee population than global warming. I doubt that cars have had much affect on the bees. We have plants and trees that need the bees for pollination.
I've read that the amount of CO2 in the atmosphere that is directly attributed to man's industrial activities is roughly 5%. Of this amount, the CO2 from burning fossil fuels for private transportation is less than 20%.
Meaning that ALL private transportation, around the globe, contributes roughly 1% of the CO2 in the atmosphere. So, if we WERE to reduce the amount of CO2 released from vehicles (globally) by 10%, then we would be reducing the amount of C02 going into the atmosphere by 0.1%.
I'm not even going to go into how much less CO2 we in America would have to cut just to offset the INCREASES of CO2 production in India and China.......
Climate Change 2007: The Physical Science Basis. Summary for Policymakers (pdf file)
One factoid says that heavy precip events are more likely because of human contributions. Any Nor'westers here? Or is the ~7" of rain in NYC this last weekend just weather?
Regardless of your own opinion, it is nice to read a report drafted by (presumably) Ph.D. types instead of actors or politicians.
It'll make good train reading tonite. Should be a good basis for addressing this topic.
Yes, that was a threat
