Subaru Forester (up to 2005)
-Frank P.
Maybe Patti will tell us they are easily available, although it is strange they don't appear in "our" accessory listings or brochures.
It would seem logical that the U.K. Foresters have the exact same basic roof shape, but I have been fooled before. Does anyone know?
Frank
Just curious...
~~~Pat
Given that UK spec and US spec vehicles both come from same factory in Japan, I would be very surprised if there is any difference to them
Cheers
Graham
Frank
We may(?) get that engine. However, there have been persistent rumors of a 2.5L turbo in the works. My guess, if we get a turbo, it will be a 2.5, and not the 2.0.
Bob
Any comments about Forester vs. WRX wagon would be appreciated. Trying to decide between these and perhaps even an A4.
I test drove both transmissions, and the 5 speed was noticeably more responsive, in my opinion. Overall, I really like this vehicle, and I don't regret getting the stick shift.
Len
TIA
Tried contacting our patti, sugar and SOA. SOA was the only one to respond and they waved me off stating they only know about stuff for American sold Foresters.
I tried to work the UK site and even tried to contact dealers over there...no can do. Enquires looks for stuff from me but then shuts me off when I try to mail.
I guess the only option left is to call long distance and I have mixed felings on that.
Disappointed in SOA wave off cause they made it sound like tke UK Forester and the American one were entirely different machines. I thought both were made in Japan for export and the same basic "frame/body"...
Dud duh duh..thats all folks!
I recently got a Kartboy short throw shifter for my Forester and it's firmed up the shifting feel quite a bit. One major reason why the Forester's shifter feels a little mushy is that it's been designed for comfort over performance. The shift arm is not a single metal piece, but two. The top and bottom ends are joined together by rubber to help isolate vibration and transmission noise. Most short throw shifters (including Subaru's own STi shifter) are made with a single piece of metal which noticeably firms up shift feel.
Ken
Varig- What's more important to you? 0-60 times and handling or the ability to haul stuff and traverse the occasional rutted trail? Answer that and you'll know whether the Forester or WRX is best suited for your needs.
-Frank P.
I concur with what you both say and knew that...I fogot to include an all inclusive statement in my thread and left the door open for the inputs...my bad!
www.subaru.co.nz/range_models/forester_2000_accessories.html
Did you not get an answer from Patti at all?
Frank
I was hoping to get some positive leads for the visors but am going nowhere.
Thanks again ...my pursuit of tweeking my Forester will continue. I have already done mods to it that have improved it IMHO, and I will continue to watch both this site and i-club for things I consider to be worthwile adds.
Bob
30 and 60 k service. What is the legality? If, for example, I merely get an oil change and
air filter at 30 k does that negate the warranty (or extended warranty)? or are these merely
recommendations. I have tended to ignore these with most of my cars since often what is done is the dealership squeezing the water hoses or something else somewhat inane. I am somewhat religious about oil changes and am pretty meticulous about maintenance. But??. , Do I continue my lax ways or am I facing the possibility of a negated warranty(or extended warantee) if I dont follow the recommendations to the letter?
Paul
-Frank P.
I asked SUBARU at the MYSUBARU website and they told me that the maintenance can be done by the owner or any auto repair shop - just keep your receipts.
BTW here is the 30K maintenance list from the MYSUBARU website:
Maintenance Schedule Details
Service Name: 30000miles / 30 month service Action Description
Inspect Drive belt(s) [Except camshaft]
Inspect Camshaft drive belt
Replace Engine oil
Replace Engine oil filter
Perform Replace engine coolant and inspect cooling system, hoses and connections
Recommended Performance Replace fuel filter and inspect fuel system, hoses and connections
Replace Air cleaner element
Replace Spark plugs
Inspect Transmission/Differential (Front & Rear) lubricants (Gear oil)
Inspect Automatic transmission fluid
Replace Brake fluid
Inspect Disc brake pads and discs, front and rear axle boots and axle shaft joint portions
Inspect Brake linings and drums
Perform Inspect brake lines and check operation of parking and service brake system
Inspect Clutch operation
Inspect Steering and suspension
Cellmates
Leather and performance driving don't mix. ;-)
Ken
BTW, fuel economy improving on second tankful after Amsoil - up from 14.1 to low twenties.
Ed
I have to admit to wondering why you bother even getting the oil changed if you believe the 30k and 60k services are nothing more than squeezing hoses. All physical assets require maintenance and you have to spend to protect.
You really have to figure in your own mind whether you want to spend the money to maintain an asset in good working order, both for your benefit and to increase its resale value.
In the alternative, you save money in the short term but blow it on increased repair bills and reduced sale value later.
If you choose the latter course, don't bother whining about any costs which come your way.
For my money, preventative maintenance is vastly more effective than finding yourself stuck on the roadside with a busted cambelt which has shot the valves through your pistons because you have been too mean to have it routinely checked.
Cheers
Graham
I am checking out visors and I'll post a response as soon as I get it.
Patti
Thanks again
So far, the biggest issue that I have heard about the visors relates to a "noise" they can produce. They can whistle in the wind?
Anyway, the noise became apparent on the visors we put on Outbacks a year or two ago and the customers in the U. S. did not like it at all. Sales were very light and it could not justify the cost of supplying them in the U. S.
I'm trying to find out why the same product is more palatable overseas. I'll post more as I learn more.
Patti
Thaks for the feedback. I would like to hear about the noise. This is a new twist on the visors given that they seem to be quite popular overseas.
Thanks again!
has anyone in product design/planning thought of designing a visor into the body?
No seams/openings, smooth line hence no noise/whistle.
You might want to have your service tech readjust the rubber moulding around the window. This often eliminates the problem and it only takes a few minutes.
Don
I am not sure that I have actually seen a door visor on Foresters or Outbacks here in Melbourne. Admittedly, Melbourne is at the cooler end of the country but it seems odd that I have never seen any.
I would express a note of caution on the noise effects. The Outback is certainly noisy around any interruptions to airflow near the doors. For example, if the mirror adjustment is slightly incorrect. Accordingly, I would tread carefully on fitting a door visor if you travel at anything near highway speeds.
Cheers
Graham
Thanks in advance for the help!
bit
If the roughest terrain your Forester drives through is dirt road, then consider choosing an all-season passenger car tire. You'll get better road handling, a quieter ride and a wider selection of tires in this category. Also, if they're all-season (M+S rated), CHP considers them to be "snow tires" so you won't have any problems with chain controls either.
Try checking out the Tire Rack to see what's available: www.tirerack.com
Ken
The engine sometimes wait for about .5 second before it response if I want to accelerate suddenly while driving (this doesn't happen every time though).
Is this normal behavior?
bit
Ken
VN.
I read from another board sometime back (last century) an owner had a similar oddity but he has a '00 Outback MT though. He experimented with the acceleration and noted a void, like the rpm will built as he is depressing the accelerator then a void (no change in rpm) and then a jump in rpm.
I'll try to find this owner, maybe y'all could compare notes and find a resolution with SoA.
This happens when I turn or hit a bump in the road. The dealer thought it was a strut on the hatch but it still does it. It sounds like something is loose and hits something when a turn is made.
If it's the S model one then it will replace your Panasonic radio/cassette. If it's strictly a CD changer and it has a Subaru label then it would almost have to be compatible with your existing setup since it was intended to be offered as an upgrade option. But I guess it depends on whether the Legacy, Forester and Impreza lines share the same radio setups. If they don't and you have a CD changer for one of the other models then you might have a problem. However, I would think that Subaru designs their models with compatible components to keep down their costs.
-Frank P.
