Pontiac Sunfire Emissions
I have a 1998 2.2liter Pontiac Sunfire. We gave it a tune up (new plugs, wires, ignition coils, oil change). It's running better than ever but failed inspection for emissions. It is saying that the 3rd cylinder is misfiring. We have had the codes dumped and the light came back on with the same error. Going to take it to the dealership but was wondering if anyone has any ideas on how to fix this. Wouldn't it run rough if there was a misfire?
I'm not looking forward to spending upwards of $450 to get my NYS inspection sticker (that's their repairs limit) but don't know what else to do for it. The shop that did the inspection told us to leave the car, they would do $450 worth of "work" and we can get the sticker. Sounds like a big scam to me!
Thanks for reading!
Amy
Thanks for reading!
Amy
What do you make of this? Are we getting screwed? I'm afraid we will go to pick up the car (without them tearing the engine apart) and it will be running badly. What do we do? It was running perfectly when we left it there a couple of days ago.
I recently failed the Connecticut Emissions testing due to OBD Communication Failure. The OBD connector is not giving a read and is not producing any voltage. Recently, my horn and cig lighter also gave out (the cig fuse is fine).
I was wondering if there was another fuse that may be connected to all of these (horn, cig lighter, obd connector) somewhere down the line? Or could it be a bad wire in there someplace? I do not want to go to a mechanic, because I know what they'd charge for wiring.. plus, I enjoy the satisfaction of working on my own car
Thanks for your help! - Liz
I found your post from 6 months ago.
I have the same deal.
I hope you may have found an answer you can share.
I have no power at obd2 port but good cig fuse.
Well?? Come on Liz.. be my hero.
I'm sorry, but about a month after this happened I ended up with a split in my breakline and found out my whole frame was rusted to the point I could stick my finger through it.. didn't feel safe driving it anymore. I got rid of the Sunfire (got a whole $300 for her) and got a 2005 Chevy Cobalt.
Sorry, again.. good luck! Hope you find a solution...
Hope maybe it will help someone else out.
I had a good cig lighter but my HORN fuse was blown and thet solved it.
ta-da...got my codes.
