Problems Filling Up My Pacifica
Recently my 2006 Pacifica Touring has developed a very annoying habit. When I fill the gas tank on my car and set the pump handle to automatically shut off, it will frequently shut off before the tank is full. Occasionally it "belches" a bit of fuel out of the filler tube. I invariably end up having to go back and reposition the pump two or three more times before the tank will fill completely. I bought my Pacifica in June and have not had this problem until about the last month or so. I think this might be a venting problem with the fuel tank. Has anyone else had this problem and if so, what's the solution?
Heck, even seasonal changes in the weather can have an effect. You said you got your Pacifica in June, but didn't notice this until the fall. I discovered a loose gas cap last summer because of the hot weather increasing pressure in the tank and causing gas to be forced back up the filler neck and out through the loose seal after I had filled up. The solution was to not fill it to the brim.
Gas station variations, changing weather. This is also your first year with the car, so this is also your first look at how things might change or behave differently at different times of the year.
Also, let me point out a change in the forums here you may not have noticed. I've added a Chrysler Pacific Maintenance & Repair folder for these "problem" type of dicussions. You can find it on the main Chrysler Pacifica Group page about the list of discussions.
I have found that it helps to take the nozzle completely out of the filler, wait a few seconds, and then reinsert it. It will "click off" a little less if you do it that way. Hopefully somebody at Chrysler has been paying attention and will come up with a fix of some kind. :mad:
But then again I know they say NOT to overfill the tank too. :confuse:
I just purchased this vehicle and it has all that I wanted--except the clock.
I can get a complete unit out of a 2005, complete with the bezel intact and am wondering if I will have issues/problems, and if so, what they might be?
Thanks for any assistance.
I appreciate it.
However, I always wonder when I hear statements like "NOT to overfill the tank". I know they say it but how can you overfill the tank? To me it is either full or not full. I guess they probably mean not to fill up to the top of the filler neck, but they could actually say that.
Oh well.
I hope your problem gets solved without additional monies being spent.
Have you gotten the problem resolved? If so, how?
Really, why is a gas tank shrinking?? Is this normal? And if so, why haven't I had this problem with any other car I've owned? How do I know this won't happen to the new gas tank.
This has to be a flaw in the tank????? Help..........this is a $2000.000 plus repair.
Good Luck!
We had the same issue with my 05 Pacifica. The fuel tank has two side and there is a small pump inside the tank that transfers the fuel from one side to the other during use and refueling that has gone bad. The only thing to do is have the whole thing replaced and that is well over $1000 and Chrysler refuses to accept that this was a design flaw. I can only get a half tank in my car and it registers as full but takes about 10 minutes to even get that far.
I have n 06 Pacifica I bought the car and went to fill up and it was a pain in the [non-permissible content removed]. It took me 15 minutes to get 20 worth of gas in it. Come to find out the little metal flap that's usually at the top where you fill from had been knocked down into the tank. And when my fuel level gets to half a tank it is actually on E!
