GMC Yukon Small Problems and Aggravations
Radio knob missing? Glove compartment door stuck? Paint peeling? This is the place to discuss those problems and irritations that don't impact safety and operation of your Yukon.
-- Gregg
Boston, Mass
Dustin Harvey
Anyway, there must be something wrong with the computer's "run-down" protection, because it doesn't preserve the battery very well. Also, once a battery (starter type, not deep cycle) has been run down, it's reserve and life cycle is reduced greatly.
I have a feeling that the BOSE system, with AMP's is just too much for the battery system. It must draw a ton of juice.
I've now had 3 dead batteries, and 2 near failures. I used the GM roadside for one incident, while camping.
Dealer would not do anything about it. Also, it said the battery was not damaged enough for replacement. But its weak.
Dave
Does anyone have similar experience?
Oh BTW, the batteries that are in our cars are generally not Deep Cycle batteries, so, a few discharge and recharge cycles will decrease a battery life by a huge percentage.
Whenever the car "dies" and we jump start it to get it back going, the check engine light, transmission, and tire pressure monitoring system all show failures. One of the times this happened, we did an OnStar remote diagnostics by pressing our blue OnStar button. They saw all of the problems the car was reporting to me, and more. When we took the car to the dealer the next day, the failure lights eventually turned off. Luckily OnStar sent the dealer a report of what was going wrong with the car (because the car was now reporting no issues). The dealer, however, was not able to find anything wrong with the vehicle, even with the OnStar report. When we were supposed to pick the car up at 4:00 PM that day, they went to start the car and could not get it to start. They then replaced the battery, which seemed promising, but we still have the same problem.
The people at the dealership right now are doing all they can do. The service person I work with told me that this may be an issue with using remote start (because he said that drains the battery). -- My kind response to that is - 1. we rarely ever use remote start, and 2. remote start is something that is built into the car by GM, so it should be serviced by them. If there is a problem with the remote start system in the cars they put it in, they need to fix the problem and recall all of the cars that have it.
The remote start was not an add on, it came directly from the factory. Blaming the problem on remote start is almost like blaming something on cruse control. I mean, you can drive with your foot on the peddle as much as you can turn on your car with the key in the ignition -- but why not put cruse control on, or start the car remotely from your key chain? These were all installed by the manufacturer, so they should support any and all issues with it.
If anybody from GM is reading this, why not address any and all major issues with your 2007 Yukon, Suburban, Escalade, and Tahoe now before they are even bigger issues in the 2008 and later models.
We have 3 newer GM SUV's right now, but because of the experiences we have had with the 2007 Yukon (in customer service at our original dealership- which we have now left, our new dealer is ok - and with the vehicle itself), this will be our last one until some issues are resolved.
Below is the exact description of the fix on my recall service receipt (just found it in my folder last night...):
PERFORM CAMPAIGN #07007
PROGRAM BCM, RCDLR & RKE MODULES PER RECALL
VERIFY BATTERY VOLTAGE AND CONDITION.
Not sure if you are a registered member of the "My GMLink". If you register (totally free) then enter your Yukon VIN number, it will tell you about any existing recall for your particular vehicle. The register, visit:
https://www.mygmlink.com/main/US/en/gm/home
K. Johnson
I have an 02 Yukon with a very similar problem.. Did you ever get yours fixed? If so, can you tell me what they/you found and how you fixed it?
I had the same exact problem and took it to the dealer and got the same answers. I fixed the problem though. I replaced the stock battery with a DieHard SUV battery that has twice the amps as the stock battery. I have yet to have this problem arise again. Also if you really want to beef up you battery problem, the 2007 yukon is set up to carry 2 batteries, an addition area is the flat metal battery plate on the drivers side. You can purchse a cable kit which is around $50 which runs the batteries in paralles. This space was put her because gmc has plans to place a diesel engine which require more amps to start. I havn't put this on mine but my neighbor is a fire chief with the same vehicle and was outfitted with the second battery. He has been able to run the stereo and all of the emergency lights for over 4 hours with the engine off.
Hope this helps.
Steve Miller
The wireless opener failed a long time ago. Then, I could not open any car doors with the key - except the hatch. When I opened the hatch, the alarm would sound but I could start the car with the key and it would turn off. The mechanic fixed the car so that the driver's side door would open with the key but the alarm would sound. This wasn't so bad since I could start the car with the key and disengage the alarm. Over the last month the horn failed. Now I have this problem. A quick response would really help, since I don't want to pay to have the car towed. Thanks.
Maurice
Where'd he find it? Homemade or pre-packaged? etc. Thanks.
I asked at the dealership's service department today about the problem - they agreed that battery use life is short, but the parts department said GM had no auxiliarly battery set-up or adaptor kit.
Arnie.
Sorry to get back to you late on this one. The kits can be purchased online or can easily be fabbed up at most custom car shops. The kits online are usually sold for RV's since they pull a lot of amps. I looked online and had a hard time finding one. Here is how the wiring system went. A second battery is added on the right side where the flat plate is at. The bracket that holds down the stock battery can be made to fit here to hold a second battery which you can purchase the bracket at the dealer.(Even though a kit is not sold for the dual battery you can hold it down here) A red positive cable is run from the second batterys positive terminal to the primary battery (stock one) positive terminal. A black negetive cable is run from the secondary battery's negetive terminal to the primary battery's negetive terminal. The original primary negetive lead cable then is spliced and re-run to connect to the secondary batteries negetive terminal. This type of wiring system can be installed at some car audio stores because some stereos require a lot of power to run everything. Unless you are an electrician I would recommend taking it somewhere to make sure it is wired correctly.
Steve
Haven't decided what to do yet; right now I'm just making sure the lights are off and the key is out.
Thanks again.
Arnie
When you first start the vehicle and you turn it over and then let the ignition key
turn back to the original position the starter is still turning over. Happens at
least twice a week. It will stop and then you can turn the key over again and the engine will start. Can anyone help me with this?
Another issue is when driving up my driveway in icy conditions the headlights again flicker and also when I break and the antilock breaks kick in. I mentioned this to service and the response was, the vehicle is getting hit with a 30 amp surge and this is normal. Come on, I'm sure this is not normal and this would have been figured in as the vehicle was being constructed.
Plus I'd like to know where I can get a replacement knob for the radio.
Hope you can help.
My guess is that you have a short that only comes into play when the vibration, or side force, on the vehicle brings something (probably a wire, probably with worn insulation), into contact with the frame or body (or maybe another wire).
I'd say follow the wire back from headlight (do both flicker, or just one side? on low beams or high?). A wiring diagram in the shop manual will help you find the color of the wire(s) you're looking for. Look for any bare wire. Then tape it.
--- Good luck. Electrical problems can drive you nuts! Arnie
I'm posting this because I looked for a solution on the Internet and found people were not getting help from dealers and they were also adding equipment in order to keep their batteries from going dead. I hope this post helps somebody save a few bucks.
Any ideas?
The entrance door must be opened manually......but once inside, the keyfob will actuate the Keyless Entry system (it'll unlock or lock the doors). When I park the Yukon, the Keyfob will lock the doors as I leave......but will fail to unlock the doors if I'm gone for more than a minute or two. In other words, the system fails if I don't use the Keyfob for a minute or two. So long as I actuate the Keyfob every 15-seconds, it'll keep on working. Anybody got ideas?
1)We have one that covers the floor frame of the seat on the center row (between the seat that folds down behind the passenger side) and the center seat. It kept coming loose and we took it out. Now my kids catch their feet on the exposed bolts.
2) There's a large plastic cover that was on the floor below the seat, (behind the driver) that my kids tripped over everytime they got in and out of the car. The cover looks like it was meant to cover the seat floor bolts. Anyway, now it's thrown in the back of the car with all the other plastic covers that are coming off.
3)I had one under my driver seat that came loose, and would get stuck whenever I moved the seat forward/reverse.. i finally took that out too.
Anyone else have this problem??
Anyway....the voice that comes on when you put it in reverse just stopped working one day. About once every 2 months it comes on now for no apparent reason.
Then last week, it beeps exactly 20 times when I first start it in the morning. Not the same as when the door is open, but a loud BEEP coming from around the cluster area. Does this every morning now. ??? Ideas?
http://www.car-stuff.com/store/?D=molding&Ntt=molding&Dx=mode+matchallpartial&Nt- k=Main&Ntx=mode+matchallpartial&N=1623+4294967263+10570&Nty=1
The problems I am having are:
1) The CD/Nav disk motor constantly runs. No matter how long the vehicle has been off, the disk motor can be heard running or reading the disk. Dealers says this is normal. But wouldn't that run the battery down?
2) I have a home office, so I do not drive the truck every day. It would not be out of ordinary to have the truck sit for two or three days without being driven. Now keep in mind that I unplug all cell phone chargers, radar detectors etc, so there is nothing drawing current except for the CD motor. After just one day, the battery will die.
3) The battery meter in the dash is all over the place. A correct reading should be just about 14. Mine will read down around 7, then jump up to 12, then back down to 3 or 4 and abck up to 14 or 15.
While the vehicle was in for normal maintance last year, they replaced the battery under a recall. I did not know this until yesterday when I dropped the truck off at the GMC dealer. The advisor told me that they already replaced the battery, so there shouldn't be any issues. After working on the truck all day, all they could do was replace the battery again. Guess what? Went out this morning, battery was nearly drained already. The CD motor is still running of course. There is no DVD/CD in, just the NAV disk.
Carl Black GMC in Sarasota has no idea what could be wrong. They have tested everything and get normal readings.
Anyone experiencing this problem and has anyone figured out why?
And I see someone posted about the cig plug covers. Yes, mine broke off the first week I had the truck. Never bothered to get new ones since I'm sure they will just break off too. Plus it's a lease, so if they want to replace them when I return the vehicle, fine.
The engine-off electrical system is pathetic. I've had to jump my 2007 Yukon four times because of doors left open, radio played, ice chest pluged in - all for absurdly short lengths of time. I always check at the dealer's service department, and GM still has no remedy, though they're apparently beginning to notice the problem.
However - mine does not go dead just sitting (like 2 weeks at the airport). Yours is not right. I'm sure they'd like to fix it if you ask nicely (or threaten to terminate the lease.).
BTW, has your Yukon been through the recall service called "BCM Reprogramming for Battery Drain"? When I had mine done just more than a year ago, my service department also reprogrammed the the RCDLR and RKE Modules...
I called them back and they said they were not instructed to repro the RCDLR on the Yukons. They didn't understand what it would have to do with the battery run-down issue. But from what I'm reading, it's more of a software issue. Do you think I should make them do this?
I was under the impression we have run-down protection anyway, so if something such as the disk motor is running, why isn't the run-down protection kicking in?
#10 of 50 What's the noise I hear when I open the door? by 10mikeymike Jul 25, 2007 (3:46 pm) Save | Reply
I just took delivery of a new 07 Yukon Denali. It has the navigation system and every time I open the door, I hear a faint sound like an autofocus camera focusing. The only thing I can think it is would be the navigation system rreading the disc, but the vehicle isn't running. Has anyone else noticed this?
Replies to this message:
valvestud (Jul 25, 2007 7:25 pm)
mikestgerm (Dec 08, 2007 2:59 pm)
gaserup (Feb 22, 2008 9:06 pm)
#11 of 50 Re: What's the noise I hear when I open the door? [10mikeymike] by valvestud Jul 25, 2007 (6:25 pm) Save | Reply
Replying to: 10mikeymike (Jul 25, 2007 4:46 pm)
Anytime you open a door on the vehicle when it's been sitting for some time, the NAV unit spins up and gets ready to do it's thing. It will also run for a while after shutdown.
