Visitor Agreement.
Just wondering:
Is it a MT/Auto?
How was the fuel efficiency your car?
And I've had kids and dogs crawling all over the interior the whole time.
-juice
Len
-juice
- Premium gas required for the XT. IF the gas prices really get awful (as if they aren't already), the question is in regard to putting regular into this engine. I have heard that late model cars that specify premium gas will take regular with no damage to the engine and no knocking, just a loss of performance. Any comments re: the Forester turbo engine?
- Short shift kit. Subaru offers SOMETHING; the salesman tells me if I get it (dealer installed) I will experience a better feel especially in regard to feeling less 'rubbery'. In other words, not just less throw, but a more mechanical feel. In reading some of the forums, I get the impression that the dealer installed shift kit may only affect throw, and that to improve feel one must get an aftermarket kit. Any comments?
thanks in advance
Could you please share with the forum, what is the price range? [If you don't mind
I am looking to buy one Forester X or X-Premium... Just wanted to know what kind of prices are there in your part of the country.
-fxter
Could you please share with the forum, what is the price range? [If you don't mind ].
A little below invoice.....which surprised me, but I have heard of good deals on Foresters before.
Also the Subaru short shifter does give a much better feel than the factory setup, but it is expensive. It does provide a shorter throw and tighter feel. Kartboy makes a nice short shifter for the Forester and also has good solid feeling urethane bushings bushings to go along with it. Just my opinion.
Just an observation... AND More octane DOES make a difference when towing with a plain 04 manual Forester in the mountains...
The Forester is a really nice SUV.
Various access “trail-roads” were all combinations of being at-grade, deeply rutted, water cut horizontally, strewn with basketball size stones and various branches and limbs. The short 99-inch wheelbase in combination of walking one wheel at time over the worst obstacles saved the day. Probably longer wheelbase or lower ground clearance vehicles may not have been successful. Once I decided not to proceed over Jeep type obstacles but to carefully backup, one wheel at a time, back over obstacles. The AWD worked seamlessly, just as a wheel would begin to slip you could hardly detect the shift to the other wheels and proceed okay.
Heck these little off-road adventures were fun and definitely kept your attention. I have a couple of new minor scratches to deal with. Any suggestions?
Have fun all.
Funny you should say that - the shifter in my '05 FX premium is better than the one in my old Beemer convertible. (I think the Beemer shift linkage is a bit out of whack.) You'll find that the moonroof in the FX does a great job of mimicing the open feeling of a convertible.
You seem to be in the same situation I was in two years ago when I traded a 10-year old Beemer in on a FX. At that time I was looking for something for the long haul that would be comfortable, reliable, and cheaper to maintain. The FX fits the bill on all counts. And if you're really intent on keeping your next car for a long time, me mum will testify that the FX is an easy vehicle for a 79-year old to enter / exit.
If you're curious about that, I can tell you about it at the chat! Let's just say that after some undertermined age, the body doesn't respond as well to an all-nighter as it used to!
We had NO idea you were THAT old!
I never read warning labels! LOL
Anyway, I think it may be the alternator, I don't know if it really is the alternator, but I have a feeling it could be. We'll be towing it to the mechanics on Monday...a sad sight for sure...can anyone relate to my problem and can it be something else??
JT :sick:
If the power items seem to come up okay, as evidenced by lights, clock, radio etc. then next most likely is some fuel feed problem. Possibly you got some dirty fuel that has clogged the inline filter which is located in the fuel tank.
Getting it to a garage sounds the right idea
Cheers
Graham
Any how, if it choked gradually, the bad fuel explanation is one I'd agree with. If leaded fuel was used, it might have clogged up the catalytic converter, and that would certainly choke the engine.
Other things it could be? Fouled spark plugs, or spark plug wires, or a bad fuel pump. But let a mechanic have a look, hopefully the ECU stored some codes even if you did not get a check-engine light.
-juice
I'm sure there is a topic somewhere on edmunds where people discuss car audio in length...
We're reorganizing the Forums according to make and model and, since you're the first to ask here, you get to post the first message in the all new Subaru Forester: Audio & Entertainment Systems section!
Tests
Engine off, car in gear, handbrake on, everything the way I left it last time I was in it.
-Push in clutch, release handbrake, but leave engine off: car stays put (brakes still on)
-Put car in neutral: car still stays put
-Let clutch out: brakes release, car starts rolling backward
Same initial conditions as above, then
-Push in clutch, start engine, put car in reverse, start backing up using engine power
-Resistance is noticed (yes I hear this thing is adjustable somewhat) to the extent that if
I push the clutch back in, the car quickly comes to rest
-This is repeatable all the way down the slope, whenever I push in the clutch, the car stops rolling backward.
-I.E. unless I have the car in neutral when I let the clutch out, it will be braked to a stop.
Conclusion: unless I change my habits, it would appear that I am wearing out disk pads every time I back down the driveway, have to power against the brakes all the way. Not a big problem, I'll just start popping it out of gear and letting out the clutch, using my foot on the brake to control speed. However.......I would not have designed the Hill Holder to be operative in reverse. And if I had my druthers, I would have it disabled completely. That opinion could change over time - I am very early in my ownership.
HH will only engage 1) if there is an incline, nose pointed up; and 2) the brake pedal gets depressed while the nose is pointed up.
HH will stay engaged only if brake is pressed and released on incline.
HH will disengage only when clutch is released and car goes forward, and of course only if it has been engaged in the first place.
Keep in mind that HH needs an incline for the ball check valve to seal in the master cylinder. It also needs some back pressure to keep it there. Releasing the clutch also releases the back pressure, when car goes forward.
Unfortunately, backing up in reverse, nose pointing up an incline, is the one problem with HH. I solve it by not engaging HH in the first place when I know I will need to reverse out (ie don't use the foot brake on the incline. You can use the parking brake anytime and HH will not engage.)
John
Seriously, I do think I'll have the dealer adjust it to be weaker, but I will wait another week or two before doing that. I just might wind up absolutely falling in love with the HH, like I have everything else about the Forester.
Fred
thanks,
Fred
06's are getting hard to find though from what I've seen searching the web. It's like when someone buys one, they keep it until it comes apart!
HH, why not just back-up into the driveway?
Have Fun.
I have a 2003 Forester, manual transmission, with 72,000+ miles. I am the original owner of the car. Recently, I have noticed an intermittent vibration that only happens at highway speeds. (60 - 70 MPH).
Here's a synopsis of what’s been happening:
I drive the car through city streets to the highway (about 1 mile). I get on the highway and drive for another 2-5 miles. I notice a low vibration that starts out faint and increases to a loud and deep vibration. This happens for about ½ - 1 mile. Noise and vibration seems to come from the whole length of the car, down low. If I increase in speed, the noise and vibration gets a bit louder. If I decrease speed, it decreases but does not completely stop until 10 – 20 mph. I can feel the vibration in the steering wheel, front car seats, pedal, etc. If you are in the passenger seat, you can feel and hear it too.
If I pull over and let the car idle for a minute or two or drive slower through city streets the noise and vibration do not return.
One time I was driving on the highway and couldn't pull over. The noise and vibration continued for a couple of miles -- gradually got louder then gradually decreased and went away. If I shift to neutral at freeway speed, the noise and vibration still continues. It is directly linked to road speed, not rpm’s.
At first, this just happened occasionally. It usually happened around the same spot on the highway. (2 -3 miles on the road at highway speed, then would continue for another couple of miles, then stop) And it only happened once during the day from a cold start. Now it happens every time I drive on the freeway, after the car has sat idle for more than an hour. However, only if I drive a short distance on city roads, and then get on the freeway. If I drive on city roads for awhile, run errands and stop the car, then restart and get back on the highway, it doesn’t happen.
I took it into the dealership. They thought it was the heat shield (as there was another noise that was a rattle). The dealership kept the car for a couple of days and test drove it, but they couldn’t replicate the vibration. They did adjust the heat shield, as it was loose. I have had the car home for a week and have driven on the highway & had no problems. But the last three days, the vibration has been happening every time I drive a short distance on city streets and then get right on the highway. If I pull over and stop, wait a couple of minutes then go again, the noise doesn’t continue.
Any ideas? Has anyone else ever had this happen to their car?
Kyle
1 - check tire balance
2 - check tire pressure (low pressure can cause flat spotting)
3 - check wheel alignement
4 - check tires for bubbles or other damage
5 - rotate the tires front to back
6 - loosen, then retorque all wheel lug nuts using a precision torque wrench
If the tires / wheels are not the culprit, could be the front or rear differential, or even an unbalanced driveshaft.
Hopefully it's something simple.
02 and earlier had some wheel bearing issues, and 01 and earlier we saw some head gasket failures.
03 was also the 2nd generation, so it got a tad more content. About 8-10 items were added as standard, and only 1-2 items were taken away.
03-05 is generally a good bet used.
-juice
What experiences have people had with the front bumber underguard, the differental guard, and the aftermarket skidplate that covers the oil pan? Are these wise to install? Or are they generally not needed on the Forester?
Thanks much -
Slipjig
I absolutely recommend it, sure.
-juice
Of course this means if I break my car, I'm blaming you. :P
Doug
Know also that the OEM diff guard is not your only option - even though it's the one I own. I think Primitive makes one, as well as Rally Armor. "Offroadsubarus" has a forum that is a good source of info on different parts and suppliers.
Doug
In fact the only trade-off is a bit of extra weight!
-juice
1) MPG on first tank. Admittedly I am a conservative driver, but was pleasantly surprised by the first tank's MPG, with about 80% in-town driving, the rest at 65 or so. It came out 25.5 MPG. Tomorrow we take the car on a 200 mile round trip on the superslab, I'll get that number when we fill up upon return.
2) I purchased the Subaru bra/cover for the front end. This is the third car I've gotten a bra for, and this one is the slickest design of all. No holes to be drilled (as I had to do on our Volvo) for snaps: the cover comes with clips built in that match the nooks and cracks of the front end perfectly. Anyone considering a bra for their Forester, I advise investing in the one from Subaru. It is a quality design/product and worth the money. (I think it was $140)
To me this is more significant than the 90-day only IQ study, this looks at models that have been on the roads for a few years.
Baja also took #2 in class.
-juice
But it's not. The vibration has seemed to dimnish, but the low, growl noise, that seems to come from the front (engine area) of the car continues (and gradually gets louder) . Now I am at a loss. Any ideas?
Question: can I use the mudflaps offered for more recent model year Foresters?
I just had to get my right rear wheel bearings replaced (71,000 miles). Now it makes me nervous about replacing my timing chain - this is what killed my previous Honda Civic. When should I do this? Is now too soon?
TIA
don
If you did not have that happen, the new gasket material is much better and I doubt you'll have the same problem again (knock on wood).
-juice
