Jaguar X-Type Transmission Questions
Mr_Shiftright
                    Member Posts: 64,481
                                  in Jaguar
                    Any questions or comments about the clutch operation or durability of same in the X-Type...post it here.
For manuals, try www.helminc.com
I have an 02 x-type manual (2.2litre). Sometimes I engage 1st gear to pull away, I get revs and a slight grinding noise and car remains stationary. I try other gears and even turn off engine. There are no warning lights on dash.
I then push car to kerb and retry..it works fine. Has anyone got any idea what the problem may be?
So, is it a normal feature of this car or.....does anyone know what it could be. I am not really worried I guess, but just curious!!
A couple of questions:
1. I hear it could be a shift/gear sensor. Where is that located
2. Where can I check and add transmission oil.
Transmission Fluid Level Check
I think you'll either need an instruction book for this because it's easy to make a bad mistake: Here's what they say about it:
WARNING:
VERIFY PROPER PLUG IS REMOVED FOR LEVEL CHECK.
Because of the similarity to other plugs and fasteners on the transmission, the potential for loosening an incorrect fastener, instead of the level plug, exists. There is a risk for internal transmission damage if the improper fastener is removed.
Removal of the reduction gear brake band bolt can cause total loss of drive or a substantial reduction in the performance of the transmission.
Removal of the parking pawl rod plate retaining bolt (located next to the XYZ switch) will result in problems/gear lever movement restrictions.
