Mark
p.s. before and even during the leak my engine temp stayed in the middle.
p.s. i also know its NOT the thermostat because after i ran the car, the fluid
level depleted like it normally does after u flush it and just start adding more
p.s. i also havent heard the "bubbling" noise nd dont see oil mixed with water
so i dont believe its the head gasket.
I was told that i can get a bigger motor but it's cheaper to go out and buy a GT. I want to keep this one but i want it to rumble!!!!! Is it possible to do this with out making a big problem????
Im having to replace my idle sensor about every three months. The problems I have when it starts to go bad is it wont idle or it will try to idle and just die. If i take a hammer and hit the sensor it will idle for a few more days and go back to not idling. Does anyone know what the problem might be and what I can do t fix it??
Steven
Thanks for any answers
KURT
you put a wrench on a bolt on the tensioner. it should require a fair amount of force to release the tension on the belt.
this is with engine off of course.
thank you.
I got it to the mechanic and he found that one of the cylinders was losing it's spark and at the same time the computer was shutting down the injector for that cylinder. The computer was not able to communicate the problem though. It doesn't seem to know that it's doing it. They've had the car a week and can't find what is causing it.
Anybody have a clue what might be happening?
First you need to fix whatever caused it to overheat or it will happen again.
