Subaru Impreza Transmission Problems
2»
  • docwatson1docwatson1 Member Posts: 1
    Have fierce clutch judder when starting from standing start but overcome it by high revs.and clutch slipping is this normal
    I've heard it could be surface rust and a good reverse burn out will wear right through it.
    Try this at your own risk, but it sounds fun. :D
    If you wanted to replace the clutch anyway, you have little to lose.
  • 95subbie95subbie Member Posts: 1
    I have a 95 Subaru Impreza L 2.2 automatic and i need to change my rear output shaft seal and ive looked everywhere online for the steps i need to do this and i have not found anything. ive even been in all my local auto parts stores and cant even find a repair manual. i have full access to a shop therefore im doing this myself along with the help of my buddy. can anyone please give me the steps or give me a link to steps i need to fix this i really love this car and i need it so please i need help
  • ccouplesccouples Member Posts: 1
    (133,000 miles)
    At between 2600 and 3000 rpms, highway speed, moderate to long (although not necessarily steep) grades, it feels like the transmission is shuddering -- most of the time, I can goose and then back off the throttle, and the shudder goes away. I've seen lots of posts about this kind of symptom online, but not any really good suggestions of remedies.
    Has anyone seen this before -- if so what was the solution? This is likely to be the deciding factor between keeping and junking it.
  • clpriceclprice Member Posts: 1
    I have a 93 Impreza L with awd auto trans. It is blowing transmission fluid through the final drive dipstick filler hole. Has any one else had this problem. Which seal is blown and how do I repair it.
  • wrcsube13wrcsube13 Member Posts: 1
    Hey I have a 96 2.2 l impreza 96k miles problem is a slight delay and hard shift between 1 and 2 also shifts a little ruff 2 to 3 any ideas what the problem could be thanks john
  • cerraicerrai Member Posts: 2
    Hello all...hopefully you can help.
    I have an automatic 2006 Subaru Impreza Wagon.
    I was driving home tonight - stopped on the way to run errands - and when I got home, my car wouldn't shift into "park". I tried shifting from drive to reverse, back to drive, back to reverse, and then park, but it still wouldn't budge. I also tried to shift it past drive 3, but it wouldn't go past that either. I finally shifted into neutral and pulled on the e-brake, and turned the engine all the way off. However, since the car was not in park, I could not pull out the key. Also, any attempts to fully restart the engine failed because the car was not in park. So basically, I'm unable to lock my car, and I can't take it anywhere short of towing it.
    My boyfriend says he thinks it's a transmission problem because that's where the shifting happens....which is retarded because it's only four years old and has roughly 40,000 miles on it.
    Does anyone have any ideas?
    :cry: :confuse:
  • xwesxxwesx Member Posts: 18,214
    The car should be able to start in neutral or park. The fact that it does not leads me to believe that there may be a problem with the shift interlock rather than the transmission itself; perhaps a connector came loose or unplugged?
    xwesx:
    Thanks for the info. I tried starting it in neutral, and that worked, so I took it to my mechanic. When I first started it up, the engine was making a horrible noise, but by the time I got there, the problem seemed to have fixed itself...I was able to park it and the engine was all but silent while running.
    The mechanic looked at it and could find nothing wrong with it except for evidence of mice or other small rodents that might have gotten up into the engine (or transmission...I don't remember which) and nibbled a bit on the insulation for the electrical wires. He recommended putting in an additive that cleans the dirt out of the fuel injectors and carbs, but other than that my car has a clean bill of health.
    I think maybe a piece of ice or large rock/dirt clod or something got stuck in the cable and driving around broke it free. I guess that's what I get for living in high altitudes on dirt roads... lol
    In any case, everything is fine now. Thanks for the tip though! :shades:
    I had rodents chew the wiring harness on my Sienna to the tune of $700!
    For me they were chpi munks.
    AAAAAAAAAAAAALVIN! :mad:
  • robdog13robdog13 Member Posts: 8
    My daughter has a 95 impreza AWD in which the rear wheels are not driving.The front wheels are doing all the work.Is there a relay module or similar that could be the problem?I will tell you this we towed the car about 350 miles with the back wheels on the ground after we deactivated the AWD per the manual.The manual didn't mention a limit of miles to be towed so i really didn't know about a problem until i noticed the front tires worn but not the back. Any leads would be appeciated, THANKS, Rob
    Didn't mention that the drive shaft isn't turning out of transmission. Thanks
    Manual or automatic?
    It is an automatic. Rob
    Most automatic Subarus can be put in FWD mode with a fuse inserted, but unless you added the fuse specifically that couldn't be it.
    No, but it could be that the clutch pack in the center differential is burned out, and it is certainly possible that this occurred as a result of the towing.
  • articwandererarticwanderer Member Posts: 1
    I was at one of those lube joints and they told me I have flecks in my transmission oil and water in my rear differential - each of which could be solved for just under $500.00 in total. I said no thanks and I have later verified that the transmission oil has little flecks in it. the Tranmission oil reserve tank is mid way cold and the fluid is clean.
    Can not check the rear differential they said water was in it.
    first of all is it possible the rear differential has water in it?
    Flecks in transmission oil is bad sign. I am 1500 kilometers from a dealership and they do not like to hear these kind of things when its on warrantly. How can I diagnos the problem/s if there are any? I mean transmission and rear dif wise?
    thanks for any input
    The rear differential is a simple enough thing to check... just drain the fluid! The water will sit below the oil, so if you just plan on changing out the fluid, pull the top plug FIRST, then the bottom plug. When you pull the bottom plug, you will see water pour out before the oil starts to drain. If you do have water, I would just drain all the fluid, top it off with a high quality 75w-90 gear oil, and check it again next year. If you have water again, you may be looking at replacing seals.
    At this point (unless the car is close to being out of warranty), I would do the same for the transmission - replace the fluid and filter, then watch it to see how it ages.
  • lilrdwgnlilrdwgn Member Posts: 1
    edited January 2011
    Was wondering if "econhonda" (or anyone) ever figured out what was causing the trans to leak...I have a 2000 Impreza RS with a similar problem??? Was it a breather hose??? HELP!!!! :confuse:
  • econhondaeconhonda Member Posts: 2
    Hey there,
    Believe it or not, my gushing leak was fixed by simply replacing the external fluid filter located on the side of the transmission. I was so mad when I found that it was this simple!!! Seriously, spin the old one off, spin the new one on, and bingo. No more leak. I didn't even know my transmission had an external spin-on filter, but it did. Hope this helps.
    Glad to hear you found a simple resolution.
  • w8lftr1w8lftr1 Member Posts: 2
    I have a 07 Impreza with an automatic transmission, the indicator light next to the speedometer says its in 1st gear no matter where the shift lever is. I can move it thru all the position but the light says its still in first gear. Even though the shift lever is in park the car won't start because it thinks its in first. Is this a limit switch problem or a linkage problem or something else in the transmission. Any ideas? Thanks for any help.
    Beyond what I'm familiar with, but is it under warranty? 07 covered for 5 years should go until 2011-2012 or so.
    That would be great if its under warranty, I bought it used and the car is sitting up the street in a church lot and have not had a chance to get to it. We had a foot of snow and the guy that plowed the lot made it impossible to open the doors so I can't get in and get the owners manual.
    It is likely the transmission gear indicator switch. It won't be covered under the powertrain warranty but since it's external it shouldn't be too expensive to diag/fix.
    -mike
    Subaru Guru and Track Instructor
  • jsaf200jsaf200 Member Posts: 1
    I have exactly the same problem... Delay in drive (3-5 sec), reverse no problem, check engine light on, just annoying and kinda scary. My impreza is about 130K and its 2000. I just really hope its not a rebuild trany situation. Very interested how things go for you, let me know what you do to fix it.
  • nltexasnltexas Member Posts: 1
    I had engine work done and had a new clutch installed on my 2002 WRX. About a month after taking the car out of repair, I heard a loud noise and it felt like the engine dropped off the car while I was moving; my transmission got stuck in 2nd gear while I was driving.
    The repair shop claims that the new clutch they installed has nothing to do with this problem of the transmission being stuck in gear and not budging.
    I have heard from others that improper re-installation/mounting of the transmission onto the engine and connection to clutch can cause locking of the gear shift.
    Any thoughts/comments please? Thanks, Nick L
  • kpjiggakpjigga Member Posts: 1
    I have a 1999 Impreza with a crazy transmission light. It is the "at oil temp" light and it comes on at the weirdest times. Hot or cold the light will pop on and when I restart the car, the light is gone. I don't if it is a bad sensor or what. I don't what it means or how to fix it. Any suggestions? Thanks
  • subanoobsubanoob Member Posts: 1
    edited November 2011
    I was driving when suddenly I could no longer shift gears when the engine is running. I can shift through them when the car is idle. I can also start the car in first gear and drive through all the gears, but if I put it into neutral I cannot shift any more. I have been driving a few miles like this for the past two days, and now the clutch pedal is starting to stick. If I try to put it in reverse the gears are grinding. I can start the car in reverse no problem.
    A) Any idea what may be the cause of the problem and how much repair might be?
    B) And am I doing further damage by driving it this way?
    I don't quite understand. Are you rev-matching to shift when you do not put it into neutral, or are you pressing the clutch pedal and shifting as normal, just going directly from one gear to another?
    I'm thinking you have an issue with your clutch fork, linkages, or similar. I suspect the transmission is fine.
  • kyfdxkyfdx Moderator Posts: 275,688
    Yeah... sounds like a clutch issue to me, too..
    I wouldn't drive it that way... If it is just the clutch, and the transmission is okay, you sure don't want to damage the transmission... that would add mega-bucks to the repair...
  • jphanjphan Member Posts: 1
    Were you able to solve this problem? I have same or similar problem. Was wondering what you did to fix.
  • phxmotorphxmotor Member Posts: 9
    This is why I never opened a shop of my own. So many shops just can't tell the truth. It's maddening and sad that so many shops knowingly mislead people just for the fun of it.They just can't help themselves. And why not, it's so easy to do. Heck; half of the driving public (no; it's more like 75%) can't change their own tire and go to bed every night thinking only a "shop" can read a code reader.
    It's fun to diagnose car related things, and it just isn't all that hard to do. I'm at a loss to see how many people are just ripe for the plucking. But after reading one posting like this after another I'm going to have to start avoiding this activity. It's not fun anymore. It just convinces me how lame and guilable many people are. Kinda like our legisltive uberclass. They sure act like they are worthy of respect and trust, but in reality...
  • sboice1sboice1 Member Posts: 1
    how hard is it to rebuild a auotmatic transmission for a 05 subaru impreza rs 2.5
  • stuck9stuck9 Member Posts: 1
    took car out today on a long trip, noticed abs light on at traffic light, shut car off and restarted light was out, 30-40 miles down the road it started vibrating then stopped then did it again then stopped. I pulled of off the highway and the trans started to slip pretty good. Pulled into a lot and noticed the A/T trans light was on, the ABS light was on, the cruise control light was flashing. I checked the trans fluid and it seems to be dark and a little foamy but the level isn't low. Let the car sit and cool down completely. It slipped as I backed out of the spot but other wise seemed ok going back home till I got back of the highway and to my first traffic light. The trans slipped bad in first gear and just a little in 2nd gear. Then the lights came back on and the engine revs but car will not move. anyone experience this? its an 09 Impreza with 98k on it, never changed the fluid and I dont think it will help now
    Don't sell your car short.... a flush is a LOT cheaper than a new transmission! While it is possible that irreparable damage is done, try cleaning out the badly sheared fluid, remove the varnish on the clutch plates and other channels and surfaces, and just see what you see in terms of results. I had some luck with Lucas transmission oil in a badly worn AT a while back.
    It's been nearly a month since your post, though. How are things now and what have you done in the interim?
