No need to bleed the system when putting a new filter in (in the engine compartment). Just replace it and fire up the car. You should if it's quiet be able to hear the pump buzz when you put the key into the "on" position.
-mike
Motorsports and Modifications Host
-mike
-mike
-mike
I have 2008 Impreza Wagon and when I start the car in the morning, Engine Coolant Temperature light comes on. After driving for 2 minutes light goes away. I brought car to the dealer but they said it is normal. I think it should be off after 1 - 2 seconds like all other lights. What is your opinion? Thanks.
We've had below zero temps here in the Chicago area, and that light comes on everymorning. Even if the engines is off for at least an hour in freezing temps and you start again, the temp drops enough to turn that light back on.
I believe it simply lets you know that the temp has not reached its ideal value in order to get the best performance/efficiency/mileage/etc from you engine.
Your best bet is to just wait the 2-4 mins it takes to warm up your engine enough to turn the light off.
In short, this operation is normal. I would think your owner manual should explain the normal function.
-mike
Does anyone know where the backup light switch is located on a 1997 Subaru Impreza Wagon with manual transmission?
My car has State inspection coming up next month and I don't want to have to pay a mechanic big $$$ to fix it.
Thanks!!!
-mike
-mike
If interior, is it intermittent and loud or is it consistent and muffled?
Oddly, the only problem I ever had from a heat shield on my '96 was a bent shield due to running over a large rock through a construction zone on my way up to Alaska. The bent shield rubbed against the rear driveshaft and caused it to squeal. Eventually, once we made it home, I put it up on ramps, located the point of contact, and moved it back into shape. Problem fixed.
Not sure about the specific turbo, though.
As for HP and Sound, you can go for a high-flow cat and a cat back exhaust which will increase HP and Sound.
-mike
It's most likely the head gasket or the piston ring. Something is not sealing, basically.
Fuel pump, spark plugs, and fuel lines have no effect whatsoever on the compression.
Instead I'd think the problem is related to the evapo/checkvalve that keeps fuel in the lines. The CEL if it's one for the emissions system will show what's up with it.
Try this next time you start your car, put the key into the "on" position for 5-10 seconds before starting. If it doesn't give you a problem there is a check valve in the fuel system that has failed.
-mike
I have a 2007 subaru impreza 1.5 engine, automatic (1000 miles on it) . It is a great car when it works. If the weather is too warm (above 77 degree Fahrenheit) or cold (below -2.2 degree Fahrenheit), I cannot start the engine. The engine makes very weak sound than usual. The engine light does not behave strangely. (A subaru mechanic said that if something was wrong, the engine light would have been on.) It is like the battery is very low or there is no gas in the gas tank. If the engine catches on, it dies by itself if I do not step on the gas pedal. First, I had the cold weather problem. The subaru service in Turkey replaced oxygen censors and installed a quick start program a couple of months ago. ( I thought that they would run some full checkup to see what the problem was) There is a 2008 subaru impreza in Kars (the city I am living at) and that car does not have these kinds of problems (She is using the same gas, etc.)
Mehmet
Got set up to do the change and I took the new filter out of the box, and just on a whim, compared it to the filter in place, holding it up under the the old one. It was smaller, not as wide in circumference as the one there. So doing this for the first time, I decided to wait. It was a Friday night and I had to work Saturday and could not call the dealer to question if I had been sold the right filter. Is it possible that it is the correct one and it fill work?
Also I have heard that those quick change oil centers use a lower grade oil, hence the lower price for a change? Is this true and is it not a good idea to get oil changes in these places?
-mike
When you first attempt to start, turn the key to the "on" position for a couple seconds before actually trying to crank it. That will give the fuel system time to pressurize. I would not think oxygen sensors to be a possible problem, as I thought they did not provide feedback until after the car reached operating temperature - perhaps someone can correct me if I am wrong.
The one time I had serious issues with cold starting (in any weather conditions), it was a result, I think, of a faulty knock sensor, perhaps in combination with the crank and camshaft sensors. The computer threw a code for the camshaft sensor when that happened, but I replaced all three simultaneously due to some other issues that lead me to suspect the other sensors may be co-conspirators, and all problems were resolved. I am not recommending that you start throwing all those parts at the car, but you might consider having your knock sensor tested and/or replaced.
As yours should be under warranty, it might be more difficult to get the shop to test for these things, but the car is obviously not running right, so keep on it to seek satisfaction. It is frustrating when a shop can only diagnose a car based on the computer or a factory T.S.B.
Good luck!
This is a small city and I am driving my car slowly around 2000RPM. Can this cause these kinds of problems? What would be the appropriate RPM for my 1.5 engine automatic subaru impreza?
After my previous post, the engine did not start at all when it was cold. While turning on the key to start position, I had to step on gas pedal several times to get it started. I took my car to the Subaru service. The mechanic told me that the butterfly valve in the engine got dirty and could not close itself. The angle of the valve should be 0º in closed position. However, it was 0.5º in my car. When I had turned the key to start engine, it had sent a lot of gas and choked the engine. ( I do not understand. If it was sending a lot of gas, why the engine started when I pushed the gas pedal several times and send more gas to the engine) The mechanic changed some part of the valve. He also said that he cleaned the sensors in the engine. The engine works perfectly in warm weather. However, now it is very cold. The engine starts immediately in the mornings and then it quickly stops by itself when I release the ignition key. If I hold the key in start position about 8 seconds (even the engine got started), the engine catches on and continue to work. I do not think that this is a normal behavior for the Subaru engine. I am glad that it is still under warranty and Subaru service is very helpful in Ankara, Turkey. I hope I could express myself clearly. I also hope that no one else is having this kind of problems with their car.
Mehmet
Could by anything, from emissions to fuel system to electrical.
I guess I'll just wait until it happens again, I'm sure it will. I really like the car, I've had Hondas in the past, and no such problem ever happened. I really don't want to go down the legal path.
Thanks again Merogul.
If the winters are not severe in your town you might be okay. I have to get up at 12:00 or 1:00 am and go to the street, start the engine, and drive my car about 15 minutes every night in winter so that my car starts in the morning. Otherwise it won't start. Dealer says that the car is working fine in summer. So it does not have any problem. (Actually, it does not work well in summer either. The RPM of the engine of other cars go to 2000rpm as soon as they start. However, the RPM of my car stays around 0 a couple of seconds before going to 2000rpm in summer when the engine is cold.)Their computer cannot show any errors either. The dealer is having a lot of computer readings and sending them to Japan. I think that those Japanese engineers are trying to figure out SOMETHING. If there is something wrong with some of 2007 Subaru Impreza cars, this respectable company should not torture their customers.
I have not tried the different key yet. The dealer said they called Subaru and they said to try a spare key when the engine does not start. I never noticed the RPM's on the car when I start it, or attempt to start it. I just can't understand why it is so random, and not all the time. I know the mechanic though I was starting it incorrectly. I live in the USA, I kind of wonder about these Subaru mechanics, they sort of look like hoods!!! I even showed them your E-mail messages about the butterfly valve, they said they never heard of it!
My car is not as bad as yours though. I hope you find a good lawyer. Let me know what happens. If it gets worse, I might have to sue. Thanks. /You certainly are being tortured!
