Dodge Ram Warning Lights and Trouble Codes
Check Engine light came on Sunday. The code that came up with it was P0440. Does anyone know what this code means. Tried calling the dealer and left a message. Has anyone had this problem?
I was on my way to get my inspection done and got a ticket for it. As I was driving my engine light came on so I ran to the auto parts store and they read a P1491. So I have done what you guys have said on the replacement of the AC rely - engine light is still on. Took the battery - and + off and then replaced the rely. Still on.
I talked to the dealer and they said it could be anything. Odd?
So, I have noticed that my AC is not running right at all. It does blow air but when at a light it is moist air and then when driving over 25mph it becomes cold again. I thought I might need to recharge the AC and I had it checked it was okay.
What should I do? What else should I check?
PLEASE HELP.
1. on-off-on-off-on = worked for me and told me what was wrong.
2. Checked the fuse #39 - it was broken- replaced it.
(this still didn't get ride of the engine light.)
3. Replace my AC rely.
4. Replace my Rateator rely.
This fixed everything.
In total I sent only 20 dollars to fix my truck.
Thank you! :shades:
http://www.obd-codes.com/trouble_codes/index.php
Basically this code means that the Powertrain Control Module (PCM) has recorded an event where the fuel tank could not be negatively pressurized (vacuum).
This could be caused by refueling with the engine on, or this vehicle has a leak in the evaporative fuel system. On Dodge trucks the first suspect is usually the fuel cap is either not tighten correctly to 1/4 turn, or defective.
Best regards,
Dusty
I have a hard list, but I think Bpeebles has a link to a site that lists the codes.
Best regards,
Dusty
http://autorepair.about.com/library/ts/bl-obd-main.htm
No one sells the part, but dodge and they want $300 to fix it. I don't even know where it is!!
Any help is appreciated!
Larry B.
Check the vacuum hoses that go from the fuel tank to the Evaporative Canister. A leak anywhere in the system can cause the same code as a loose or defective gas cap.
Dusty
Best regards,
Dusty
The cruise control works fine below 60mph. Once i go above 60, if the cruise is set, it shuts off. If i'm traveling over 60 mph, the cruise lamp will not even turn on.
thank you so much..
laura
please comment back and let me know if i have a chance fighting this, this is a 2005 dodge ram still new. 41,000 miles. it has a 70,000 mile power train warranty.
kcram - Pickups Host
where the mileage is. The truck has a different sequence. There is a way to get the numbers without the reader.
You just need to know the sequence ,That’s want I am looking for.
