Toyota RAV4 Audio Nav Sat DVD iPod Bluetooth
                    im installing a sound system and need to drill a hole in the firewall near the diver side....but i cannot judge a good spot to drill....anyone know?
It seems the base antenna they give you in the car kit for the MyFi is crap. They say the cable is so whimpy that if you crimp it, even slightly, it ruins the whole run!
Has ANYONE had XM installed on their new Rav4 in a way that actually receives decent reception?
Where do I run the cable? Antenna placement?
Help!
Thanks in advance,
Does anyone know what to do for the in-dash cd player- whether to leave it in (is it good enough) or replace it.
My main question is what does an aftermarket cd player look like once installed because of the curved shape of the dash.
Antenna - mounted on the roof at the back of the car - center of roof at the rear cargo door. The cable runs around the opening for the rear door on the outside of the weatherstripping until it gets to the bottom of the door, then it crosses into the inside of the vehicle. This is important for preventing leaks. I just used tape to secure the wire at points around the door frame - can't be seen unless the door is opened. When the wire comes inside it goes under the floor of the cargo area, between the right (passenger side) rear seat and the door - tucked in under the plastic molding around the rear passenger side door. Then the cable goes under the front seat and across to the center console - then around the back of the center console (tucked under the housing) and then it comes out of the console on the driver's side right about where the cup holders are, then it goes up to the place where I have my bracket mounted, following the "seam" where the dash meets the console. There is just enough length to the cable to do this on my 2006 rav4.
Bracket - I use the bracket that came with the unit, and the mounting tape that came with it. I mounted it on the brushed aluminum part of the center dash - to the left and just below the radio - beside the AC controls. When the unit is in the bracket the screen is a little obscured by the wiper control, but I can lean over a bit and see it - and I can easily reach the controls. There is a little swivel action to the mount, so you can adjust the angle. It's not really in the way of anything else in that spot and the tape has been on since Feb with no signs of coming up (now Oct) - not even in our code red 100+ degree days this summer.
Power - I use the outlet in front of the cup holders but you could also use the one inside the console. Keep the extra cable tied up with a twistie or run it around under something if needed.
You might be able to mount the whole thing inside the console but you'd have to open it and look down to see the controls or change stations (unless you use the remote). That's where I had my prior XM (roady) installed in my prior vehicle. I liked the fact that it was concealed and there weren't wires running around everywhere but It was a pain to have to open the armrest to view/change - and sometimes the presets would get pushed when I closed the top.
HTH -
C
The best response I have found regarding this issue in these threads was post by gmarshall56 on Oct 10, 2006. Here is the content of his post, any update/[non-permissible content removed]/success story on this subject is greatly appreciated:
"Heres a heads up concerning the Sirius satellite radio:
I've got a RAV4 Sport due in later this week. I asked my dealer rep about the sat. radio option. Here is his email response (take note of the "complication"):
The JBL system is satellite ready and the cost is about $400 to install the antenna and receiver. I believe this may also come with a one year paid subscription. There is a complication. Toyota has released a technical service Bulletin or TSB indicating that there are problems with the Sirius radios. They have asked us not to install any more in the RAV4 or the Landcruiser until they rectify the situation. After delivery of your vehicle to you, we need to keep in close contact to make you aware of when this can be installed.
.... thought you might want to know this....
g"
If you look up under the dash, you will find a large gromet with a bundle of wires about the size of a quarter. It is very high under the dash on the driver's side and "outboard."
If you look closely at the gromet you will see a "dimple" on the outside ring of the gromet. That dimple actually seems to be an extra hole. I was able to pass a probe through the hole, attach the power wire and pull it back through.
I used a mechanical "grabber" as the probe. You might be able to do the same with a coat hanger. Probe must go from inside to outside. The "exit wound" is hidden in the engine compartment.
Of course, YMMV.
Good Luck. Let us know if you found the path.
Just Curious. What part of your stereo requires a wire that big?
I'm shopping for a new small SUV. I like the RAV4 but it doesn't have an integrated navigation system as an option (it does have bluetooth).
Does anyone know of aftermarket navigation options. I found a Pioneer system (bluetooth integration, MP3 server, back-up camera) that looks promising but it is difficult to know whether it will "fit".
I would be willing to spend up to about $2500.
Bill
Bill
You can visit people's CarSpace pages by clicking on their member name in a post title and hitting the link there, or just type in www.carspace.com/membername.
Well, seems I need to load my own photos which I can't do. Hopefully some one can guide me pictureless?
Then you wind up at a form screen that lets you browse your hard disk for jpg photos (the file extension must be .jpg).
When you see the one you want to upload, you click the Add Photos button. Rinse and repeat. :shades:
I'm also shopping for a 2007 Rav4 V6 Sport and got a deal of $500 over "invoice", as they say. The salesman is a friend of mine, also. I think they have their limits. Is there anything that I should look for or avoid, of course I like the performance of the V6. I test drove it in the rain and it handled very well and it was the 2WD model. If any of you can give me a heads up on it, I would appreciate it.
I like the 4WD much better than the 2WD. If you really test it out at its limits, it handles so much better.
Right now I'm favoring the Acura RDX which is slightly more expensive (with "technology package"), but it has better gadgets and handles considerably better IMO.
:confuse:
They have message boards and their own stores where you can look at brackets and mounts to get installation ideas.
I'm very interested in this subject as what vehicles have this option will affect what I buy.
I am looking to buy a 2007 RAV4 4WD LTD and am also considering navigation products. Here in Toronto Toyota offers something called Toyota Navigation System as an accessory, no idea exactly what they build in or if it's available on the RAV4, I still have to check with the dealership, but I suppose I would want something on the high-end side and AVIC-Z2 looks real nice.
From what I read on AVIC forums, it seems there are kits available for installing double DIN navigation systems. Has anyone actually done it and can you tell me if you did it through your Toyota dealership or some other shop?
The RAV4 system searches for devices with the pairing PIN displayed but never recognizes the phone. Any suggestions?
I find the RAV's bluetooth system so much better than the one that I have with my phone. I can't believe how clear it is. Very convenient, no fumbling around.
Hope you are successful.
She has a Samsung A437, and we are having the same problem. It simply will not pair automatically. Luckily, she has only had the phone for about 2 weeks. I plan to take it back and exchange it for another phone.
Incidentally, I have a Samsung A727 that works perfectly with the hands free system.
http://rav4world.com/forums/album_personal.php?user_id=1358
Elliot
Elliot
Summer
open to suggestions
Any ideas whats wrong ??
