Toyota Sequoia Transmission Problems
hi, I have a 2005 sequoia limited 4x4, on stop & go condition, everytime I release the brake, car jerks on first gear, especially when going down hill or with air conditioning on and driving with low gears are pretty rough. I took the car to the dealer with this problem and the dealer said everythings ok, but I believe it has some type of problem either on transmission, or brake or somewhere... so if anybody is experiencing the same problem, or if anyone has any idea what is the problem, please help.
Thank you for any help in advance.
Nothing unusual to mine and a lot of others based on what I heard!
When they took the car back 1year9 months later it still had problems with the trans it had rear bearings bad. The sequoia is a very nice ride, I loved the car but hated the problems. I now own a Nissan Armada. The only complaint I have is it rattles. Between the 2 suv the sequoia body int and ext are a much better design.
I'd appreciate any info that can be shared.
Th, KDK
Anyhow, the Russell Auto in Manchester fixed my car and I got to tell you they are bunch wonderful people and very experience in transmission. The mechanic told me that it was a small piece of metal broke down inside the transmission and over the last year and half it messed up the transmission! The mechanic said the metal is inside the case and it's impossible to detect without taking out the entire transmission. I had the car checked before and no one was able to tell me the problem. In fact, we were driving it for over a year and half!
I contacted TOYOTA and guess what they said to me...Sorry it's out of warranty! I am fuming. It cost me $3,600 and another $1,000 in hotel and rental car. I have 5 Toyota cars in the last 25 years and it really made me sick!
Best luck on your car.
Bad news was the transmission was shot but the good news was that Toyota was going to install a new transmission at no cost to me whatsoever. Pretty amazing given that the truck was out of warranty. Still with only 60K miles on it I'd expect a lot better life.
Toyota must know more about these transmissions and their problems if they are willing to replace them, free!
Otherwise, my truck has been fabulous for over 5 years.
By the way, it's a TRD Sequoia, supercharged with all the TRD goodies.
Hope that this may help others with sick transmissions.
Jon Wilson
Jack
What you described in you e-mail is exactly what is happening to our Sequoia. Except, the hardware under the steering column cover actually broke. Did you ever find out if parts can be ordered to fix this or am I stuck having to have the whole column replaced.
I appreciate your response!
ours started with the lurch at stop lights etc. we also were told it was our air conditioner! the problem continued to get worse. it proceeded to a roaring when we were about 65mph, and the transmission started slipping then slamming into gear.
we had to have to the transmission replaced in the first one. when the same problem started to happen on the second sequoia, we took it to freeman toyota in hurst, tx. the service manager knew exactly what it was. i cannot remember the part, but they replaced ours and we have been fine since.
good luck!
driving down I75 pulling a yard trailer (low weight, just kids bikes) the tranny total died and rolled over to the shoulder on a very busy spring break vacation >>> of course it's raining like crazy so we waited outside for the wrecker to take us to toyota, nice poeple but hey for 3600 bucks they should be nice
I am going with the toyota tranny as opposed to the AAmco one, my guess is that there is some value in them doing it going forward
anyone have any thoughts??
When there is hard braking the front of the vehicle goes down and the rear goes up. This action stretches the drive line causes the rear shaft to slide out of the front shaft according to design. When the brake is released this causes the shafts to contract,sliding back into place. This sometimes causes it to go beyond the normal contact area upon the rust spot.
To remedy that we would use emery cloth/sand paper to clean the area and apply some grease. So when I feel it when driving my 03 I just ignore it not a problem.
I am very disappointed with the quality of Toyota. I have experienced two separate occasions where the coil packs had to be replaced. Now the transmission on a 2002. I am tired of hearing that this is not the norm for Toyota.
Every forum I go on I find at least 8-10 owners with this same problem. So one has to wonder why Toyota has not had a recall. My dealer is telling me it's going to cost about $5k to replace.
I just filed a complaint with the National Highway Traffic and Safety. I would suggest more of us do the same. Since Toyota is refusing to acknowledge they have a problem.
Many people are citing that debris from other mechanical parts that have failed such as the a/c housings got into the transmission and caused it to fail.
Recalls/Defects | National Highway Traffic Safety Administration(NHTSA) | U.S. Department of Transportation
thoughts?
1. When I brake in low speed in parking lot, from time to time, I felt the car "jump" forward a little bit. It seems like I wrongfully step on the gas instead of the brake, of course, I am sure I stepped ed the brake. The problem, however, is not repeatable.
2. If I push down the gas pedal very gentle, the transmission gear shifts, the rpm stays around 2000 and the speed goes up. If I push down the gas pedal in medium hard steadily, the gear shifts to the second or third, and will not shift to upper gears. What I see are: the rpm goes up higher and higher to 3500-4000 and the speed goes up to 50+ miles/hour. (I didn't try longer and/or harder.)
However, if I release the gas pedal and push the gas pedal again, the gear shifts, and rpm goes down to 2000.
Are these problems? Many thanks,
Now 11-20-09 My overdrive is used to eliminate noise from engine while on the road, it sounds like as if stick shift gear is in high gear at low speed. pushing od button kills the sound and run normal and it happens during 30~75 miles.
Google search refers ths issue to Transmission problems. Feed Back Please!
Thanx.
We have a 2002 Sequoia with 122K miles. Our transmission went costing us approx. $4600.00. I have been researching this issue online and found others have the same issue as me/we do. Now this truck cost between 42k to 48k or so and 8 years later I am changing the freakin trans. How the HACK(used lightly), does Toyota or any other auto maker get away with this stuff. I also have been researching to see how we could get Toyota held responsible for this piece of SH@T trans.
I will continue to research and blog here until I am satisfied with an response from the CEO. If you can do the same in addition to telling everyone who you come across who has the same problem and tell them to go to EVERY website and complain like us. If you want to discuss further please contact me.
Possible solution: Check your transmission fluid level. If you’re looking for a dipstick, it’s not there. The Sequoia has a sealed transmission and the fill cap needs to be removed (24 MM socket) in order to add fluid. The fill plug is located on the passenger side of the transmission toward the rear of the transmission. Basically the transmission fluid is low and when you come to a stop or take a sharp turn the fluid sloshes to the side and as the filter is trying to suck fluid it loses pressure. After a few seconds you feel the “kick” and the pressure is restored.
At this time you may want to drain the fluid, drop the pan and change the filter. You should have 3.2 quarts drain from the pan, if you don’t then you know it was low. Replace the filter, put on a new gasket, torque the pan back into place along with the drain plug and fill with 3.2 quarts of the correct transmission fluid. Please give it a try and let me know if it helps.
Did you get this resolved? I'm on vacation right now, and am having the identical problem. Any help would be greatly appreciated. email me directly michael.horton@ge.com - Thanks
My vehicle would experience an after-stop sound that seems like a thud as if somebody rear ended you.
It seems that what ever is happening is inside the transmission.
My understanding is that auto Transmissions have friction plates that drop into place automatically as you accelerate while driving.
As you come to a stop all these plates do not make a smooth turn by turn---last in --- first out.....sequence but wait for some god foresaken reason to return to their usual stop position all together after hesitating initially.
I think Toyota needs to analyze this thoroughly and see if the use of a certain transmission oil is contributing to this phenomenon.
I have a strong urge to use ordinary cooking oil to replenish the transmission oil as i did with my washing machine 2 years ago and it seems to perfporm better now and is also very quiet
