Lincoln Mark LT Transmission Problems
LT not shifting properly? Check in here
kcram - Pickups Host
Torque converter
Valve body (twice)
Piston
clutches
board
other components I forgot.
I'm now dealing with ford and am supposed to get a call in a couple days from the "next level support" that will "give me a dedicated rep to work on my issue". Issue? The issue is they need to authorize the dealer to replace the F@#$@ transmission!
I love the truck but this is rediculous.
I took it into Ford and they replaced flywheel & starter.
I noticed after that a shudder on the 1-2 shift. I took it back into Ford and they found a bad coil pack on # 5 cyl. Felt better for a day. Start shudder again,
3 More times into Ford ( No problem found )
I had it in for service and I checked the transmission fluid level and found it was 1 qt
low. No leaks, Service center did not have any Mercon 5 , but I knew I had some at home. I added 1 qt. Mercon 5 and shudder is GONE.
I think they lost 1 qt of fluid when they had the trans out to replace flywheel.
In the beginning, it only happened every once in a while but now it happens almost every time I drive it. To top it off, my warranty just lapsed so hopefully it's nothing too serious.
I plan on taking it to a shop this week so hopefully it's something easy and inexpensive. I'll let you know.
I have about 92 k miles on excellent 2006 LT. No prior issues. I am having slight issues on transmission switching between 3rd and od at speeds of about 45 to 50 mph. Had the transmission serviced ( complete oil change, no filter) recently performed at the local Lord Dealer and they found no prolems. Seemed to work better after fluid was changed, but within 500 miles went back to shihfting from od to 3rd when speed was in the stated range. I suspect that possibly something defective of partially plugged in valve body. Anyone have similar issues and remedy? Thanks for all responses. Berniet
