Mazda B-Series Engine Problems
If your B-truck engine won't git-r-done, ask about it here
kcram - Pickups Host
Pull one out, throw the other in.
The engine I plan on using is an Isuzu 4LE1.
The problem here is that this engine weighs about 500 lbs.
I'm guessing the 2.2L gas engine that's in my truck weighs about 350 lbs.
I also know that my front suspension is a torsion bar style and that its appearance is very similar to that used by Chrysler / Plymouth / Dodge products of the 1960's and 1970s.
I'm thinking my current front suspension may not be sprung enough to handle the extra weight under normal driving conditions (if at all) and I know that small block Chrysler V8's are about 500-550 lbs.
So can I easily retrofit the torsion bars off, say, a 70's Dodge Dart, onto my truck?
...oh, and before you start making references to the diesel engine that powered Mazda trucks in the 80's, be informed that that engine has been out of production for many years now and parts are next to impossible to find.
In fact almost all the small diesel engines that were either popular in the 70's, or those that the factories used in the trucks in the 80's are no longer made and parts are becoming increasingly harder to find.
The Isuzu engine I listed above is the only one I've found that would fit my needs.
Thanks for any help any of you can provide.
I have a 2001 Mazda B 3000 P/U truck, I filled it up 2 day's ago. It's now at slightly below 3/4 of a tank, (By the way, what size is the "Tank", 19.5 ????)
Today, 11 June 07 it started "Chugging Spitting Coughing every time the Engine gets up to & maybe slightly past "3000" RPM
Is it "Water" in the Gas, or a Fuel Control (F/C) problem ?
Remember, every time it gets up to (or slightly past) 3000 RPM, it starts "Chugging Spitting & Coughing....
Please Help Me .....
Otherwise, best darn truck I've ever owned!
Any ideas?
Thank's,
Sandy!
Sandy!
no worries,
the_bean
Put the # 1 at top dead center. Took timing cover off and saw the mark on crankshaft pulley was in line. As well as the A mark on the cam pulley.
I also took the valve cover off and saw that the #1 springs were uncompressed, but I believe were closed. Cause I put my finger in the spark plug hole and felt compression.
I am at a loss, I don't know what I'm missing. Can anybody help me?
yarrow24@msn.com
7801brian
WORD to the wise.
There are no signs of life. The guy i got it from told me he got in it one day and it was running sluggish and the next day he got to the end of his street and it died and that was that.
I Tried starting fluid and that will not work at all.
Got it for $300.00 nice truck if i can get it running.
This seems like an air intake problem??? Is there some sensor that may need replacing? Or could the problem be in the catalytic converter??? How would one go about testing these?
if all of this lines up and it still wont start then you make have problems in the fuel lines. (filter pump and lines can get clogged over time from a decaying gas tank.)
if you need any more help you can e-mail me directly at brderjumper21@msn.com i'd be happy to help you with what i can.
