Ford Explorer Air Conditioner and Heater Problems
15791011
  • clusterbusterclusterbuster Member Posts: 24
    Depend on what temperature control arm you are referring to. The blend door actuator arm is located under the dash and is accessed by dropping the glove box door and locating it. Usually tricky to find, but I don't know exactly where it is on the 96. It is vacuun operated, and by moving it manually under the dash, you can usually control the heat and cold just like using the rotary dial for temperature control on the outside dash panel.
  • tealstontealston Member Posts: 5
    I completed the blend door replacement and it successfully fixed the problem. It took a little longer than the instructions indicated, but the end result was worth it. The extra time I needed was mostly used trying to remove the old blend door because the vertical axis top was only halfway broken and not completed severed. I would recommend it. It is important to watch the online instructional video and read the paper instructions so you know exactly what to look for when you complete the installation. Several steps are done by touch and feel inside the blower box as opposed to being able to visually see a certain part to be removed or cut. The flexible attachment for the rotary tool is also absolutely necessary. I don't think I could have done it without that attachment due to the tight working space on the passenger side floorboard. The entire replacement kit is an excellent engineering concept.
  • knrjosephknrjoseph Member Posts: 1
    A couple of weekends ago my husband and I replaced the blend door in our 2003 Ford Explorer. Now I have another problem my heater barely blows out luke warm air. With winter coming I am getting nerves that it will not heat up enough to even defrost my windshield. Any help would be greatly appreciated.
    Kim
    Even if/when you turn the system up to MAXIMUM heating (temperature)..??
  • ronkeyronkey Member Posts: 11
    Check and make sure there is enough coolant in the radiator and that the
    air is bled out of the coolant system and a new thermostat ,(195
    degree),make sure the heater control valve is working also,the heater hoses
    should get really warm to touch ,or hot.
    Possibly the blend door is not all the way open. Drop the glove box door and reach to the left and you should feel a metal dash brace. Just below the brace is a lever that must be all the way down to produce maximum heat. It is not easy to find the lever, but don't give up trying to find it. Good luck.
  • agilesalsaagilesalsa Member Posts: 1
    A mechanic told me it would be over $500 in labor for a $30 part to replace the "oscilator" in my heating / cooling system for which the motor was no longer working. Living in New England we had our first frost last night and I don't have any heat. We had my dash pulled apart last night and a repair manual in hand with no luck in finding the "oscilator" to manually change to heat from air. Any suggestions? Help???? Anything is REALLY appreciated!
    If you have the repair manual and you're still looking for an "oscilator" there's no one out here that can be of help.
  • hthornleyhthornley Member Posts: 7
    Never heard of an "oscilator"--think he made that up!
    Did you change the heater door as in "heater-treater"--I did --now have heat and cool. It was quite a job! Look for "heater-treater" on internet. When door breaks you will have all cool air or all hot air.
  • deaddirt321deaddirt321 Member Posts: 1
    i have a 2004 Ford Explorer Eddie Bauer AWD 4dr SUV (4.6L 8cyl . , and my my ac only blows cold air on the passenger side, and warm air on driver side . can anybody help. im trying to find out if its the blend door or motor.
  • jrampellojrampello Member Posts: 1
    I have a huge problem with the heater in my 2002 explorer. I have replaced the theromostat, heater control valve and the blend door in my dual control system with the heater treater door. The door works fine opens and closes as should. The problem is I get very hot heat out of the low vent on the floor, ice cold air out of the vent near knees and luke warm air out of the vent on the dashboard. The car seems to not want to make heat at all when the AC compressor is on such as when defrosting. Temperature of coolant through heater core is 154. The car engine warms up to normal temperature. The heat is there but can't get it to come into the cabin of the vehicle. I have looked under the dash at all of the vacuum controled doors and all seem to be working as to where the air comes out. Just can't figure out why it is not hot. Any ideas? I'm open to all.
    Jim
    Welcome to the modern day world of horribly FLAWED automatic climate control systems complements of NipponDenso, Denso US.
    What you describe is SOP for one of their designs.
    Google for:
    wwest denso "two-layer" -dfg
  • gunner0331gunner0331 Member Posts: 2
    edited November 2010
    I have a 2005 Explorer and my heat will not work. When it first started it would only blow out on defrost no matter what setting it was on. I didn't have the funds to fix it and now its escalated where the heat wont turn on at all. It makes a repetitive clicking noise when turned on and will blow nothing but cold air out. I was hoping someone could tell me what I could do to fix it. Heating/AC isn't my thing. It's almost winter and I'm stressing since I have a 7 month old that will have to drive 12 hours back to Ohio with me when I get out of the Marine Corps in December. The guy at the shop said it would be at least $700 to fix and I definately don't have that. Especially after putting $700 into the transmission. I will never buy Ford again. Any help would be appreciated
  • elvoolzelvoolz Member Posts: 5
    Hi Gunner,
    I had the same exact problem and I have the same exact care as you! Someone on this forum actually told me exactly what to do and it works. It may take you a short while to find it, but once you do it will be very easy! You need to open your glove compartment and squeeze the two sides so that it will drop down and give you access to inside the dashboard. Place your hand inside and to the left side and a little bit down until you feel a lever. You will need to push that lever down (towards you). The heat dial needs to be turned almost all the way to the hot side in order for the lever to stay down. If it doesn't stay down, shimmy that dial just a little either way until it does. You may need to do this each time you restart your car. Sometimes it stays, other times it pops out each time you turn off the car. Below I am pasting the exact wording that the guy that helped me posted, because I think it was a very good description. I know how terrible it was having this problem last year. I'm sure your heat will work like this as well. Here was the guy's wordage:
    "Just found the lever an hour ago.......I have a 2003 explorer. you have to release the glove box ( not all the way out) and put your right hand inside toward the a/c heat controls right inside and toward the bottom of the left side of the glove box....you can feel a small lever vibrating slightly.......its about 4 inches down....i pushed the lever down and my heat started working..........(had the car running and the heater turned on)...............hope this helps. Have to figure out some way of tying a string on it though as the lever wants to move back to the shut position. "
  • hash_pennihash_penni Member Posts: 13
    ok i figured out what the prob was in my 2002 ford explorer. we thought that our blend door was the problem, but turns out it wasnt. the knocking noise you are all hearing, or at least what i was hearing, was the gears in the blend door actuator, which is connected to the heater controls, which makes the blend door move. we took out the box, which in my truck, was located on the drivers side
    dash.http://www.p71interceptor.com/eatcswap/blenddooractuator/Photo0029.jpg
    It is really kinda hard to get to, but if you can manage to get to all the screws loose great! we only had to take off the panel near the floor to get to it, but when you get the screws loose, and take out the box, you have to open it up and look at the teeth of the gears, if they are not broken off or chipped then thats not your prob. my gears were broken. you can do 1 of 2 things. if the gears are broken, you can go to an auto store and order a new actuator, which is around 40 some dollars, and then just put the new box in, replace the screws, and your finished....lol i actually have a quick fix solution while your waiting on the part to come in. when you open up the box, there is a piece that sticks out of the box, that fits into a slot in the dash that connects to the blend door. if you take that piece out of the actuator, just that one piece....and stick it back in the hole in the dash, you can manually turn the heat on by flipping the piece either forward or backward, but the blower will have to be turned on for it to stay on. but this is a quick fix and it will give you heat, until you get that box replaced. if you have any questions, or this doesn't make sense let me know...
    I posted this last year sometime and I hope this will help you, this problem has not come back for now...they have the part I am talking about above at any auto parts store for 40 or 50 bucks, which def beats the $700 your talking about...I also put in there a quick fix to help you until your part comes in, or if you just don't have the cash. Please email if you have any questions :)
    Thank You,
    Kasey
    hash, elv thanks a lot! I'll give it a try as soon as I get a chance and let you know the outcome. This is a huge help. Any questions i'll shoot you a message. have a good one fellas
    Hi Gunner, Elvoolz is exactly right, in fact I probably told the person what to do when his was out. Be sure to have your Ford running, parking brake on,and the temp control all the way to hot so it will continue clicking or thumping. The clicking helps you locate the lever, as it's a bit hard to find. Don't give up. Another tip is the lever is very close to the verticle dash brace that you will feel under there.Let us know how you make out. Clusterbuster.
  • dhunt2dhunt2 Member Posts: 1
    Wow! I've got a 2006 EB that is doing exactly what you are all talking about. Haven't seen anything that addresses the problem until I stumbled on this forum tonight. Mine is doing just about everything that everyone has talked about here. I've located the general area of the problem and the method to choose either hot or cold... but not a happy medium. I can get hot or cold when I manually switch... but no in between. Lots of clicking and thumping.
    So... there's this "blend box" were the amount of cold air and hot at is controlled with a motor and some kind of interior door.? I have located the blend door actuator on the drivers side and decided not to tackle that monster until I have more information. Very difficult to remove. I've also located a lever directly across from the motor on the other side of the blend box on the passenger side. It is accessible a lot lower than behind the glove box. Mine is a little higher than just behind the middle console cover that is removed next to the passenger floorboard. Its hard to find. It basically sticks Up when the temp control knob is in the cold position and can be moved, towards you and down, when the engine is running, in park and the as other have described for heat. This will control the hot and cold so at least I can get it to work.
    I've known that this problem is going to cost me a fortune since it happened. and I'm pretty good Mr. fix-it. I think I'll look at the blend door fix from heatertreater.net and also talk to the part dept about the blend door actuator replacement and see if the problems I am having are symptomatic of what they might see regularly. I'm also going to see if I have simply missed a lever or vacuum hose that is broken. It sounds to me that Ford has multiple problems here and I want to make sure I get the right one. I'll keep you posted as I find out more.
  • mike504mike504 Member Posts: 1
    Hi Jim,
    I have a 2003 Explorer XLT and currently having the exact same problems. I started with the blend door fix from Heater Treater, last March. I recently started snooping around for the reason that the heat doesn't make it to the dash. Here's what I found.
    If you pull the instrument cluster,(speedo and and fuel guage and things) out of the way. To the far right there will be a little hole. Shine a flashlight in the hole and move the selector for the hvac controls to defrost clicking one at a time work your way to off. There is a vaccuum actuator there that connects to a door,(similar to the blend door), mine is broken off. If you see a lot of movement in and out as it moves front to back, I bet you have the same problem.
    I am working right now to see how involved this will be to change. It looks like you have to remove the whole dash. I will let you know what I find.
  • jrfowler1jrfowler1 Member Posts: 1
    I too have a 2006 EB, but my heater does not work at all. My air conditioning works awesome and gets real cold. However, when i change the temperature off cold (anywhere off the blue), the console sounds like it's knocking or clicking. i tried running the heat with the knocks to see if it works, and it doesn't. i called my warranty people, and this part isn't covered (shocker...). I'm sure it'd be at least $1,000 to replace a $40 part, and i'd rather be bold and do this myself. Does anyone have a step-by-step instruction on how to change this thing out? I have the Hayes book, and it will only get me as far as taking off the console. Is this the blend door or do I try that heatertreater.net thing i found on youtube?
  • explorensteinexplorenstein Member Posts: 2
    I also have an 03 explorer, performed the Heater Treater fix last winter and have had piss poor heat ever since. Have torn it down 3 times now. I get good heat on the floor, cold out the upper vents. Barely good till -10c then unbearable past that. I tried your fix and i cant determine what part you are talking about.
    With the glove box open and looking in to the left there is a steel bar hooked up to a vacuum actuator that points forward towards the rear of the car. This actuator is triggered by the movement to defrost and appears to be working a-ok. Also in that extremely sharp and hard to see space is the exposed hinge of the blend door that has the lever on it that triggers the heater core when in full cooling mode.
    What am i missing? Could someone take a picture - i desperatly want my heat back as its getting cold up north!
    I would HIGHLY suggest against the HeaterTreater fix if you are only getting the clicking problem. Just look on the Explorer Forums for posts about replacing the actuator, its a pain, but only 1/4 the hassle of replacing the blend door. The blend door ultimatly causes the actuator motor to bust, however for the 100$ for the actuator. I'd replace 4 before having the pain of the blend door i've endured. (Others have as well) The problem is that after replacing the door, something happens and nobody seems to know what, but the heat out of the upper vents stops working and if you are in a cold climate this is unacceptable. I had to destroy the old door to get the new heatertreater one in so there's no going back now :(.
  • messiermessier Member Posts: 1
    I too have a 2002 Exploder, and I'm unable to locate this blend door actuator. I can hear it behind the Center Bezel. Where exactly is it and do I have to remove the Center Bezel and/or Knee Bolster.
    When I replaced the actuator, we had to take off the panel underneath the steering column, as well as the paneling along the console in order to reach the actuator. I have to be honest...it is a really tight fit and really hard to see, but being that I am a woman it was a lot easier for me to squeeze in there haha. You will have to lay on your back on the floor board on the driver side and use a flashlight to look up into the dash, almost next to the radio, and it is a white box, i will put some pictures here to help.
    I really hope this helps you :)
    If not, please feel free to get ahold of me!
    Kasey
  • bobo53bobo53 Member Posts: 1
    my explorer has freon ,, compressor runs,, everything turned off but hot air is coming out ,, no a/c at all any ideas ??
  • zakaharriszakaharris Member Posts: 1
    I have a 2000 ford explorer and for the past two years or so, the heater has refused to blow heat. Apparently it had the same problem before it was given to me, but they took it into the dealership while it was still under warranty and when they got it back it worked again. I had it for about a month, and then all of a sudden it would no longer blow heat. It blows just great and the AC works awesome, and even when the temperature gauge reads that the engine is warm it still refuses to give me some warmth. Any suggestions?
  • newmecnewmec Member Posts: 1
    Thanks guys!!!! It worked just as you stated:) I came to visit my sister who is having the same problem. Pulled the glove box out, stuck my hand in and and pushed down-heat came out the dash. It took about 5 minutes. Just stick your hand where it can fit towards the dash. Thanks again!
  • umd357umd357 Member Posts: 1
    I have a 1997 ford explorer during the summer a/c works only on max high and when set on low a/c it blows hot air.Now I have no heat .A friend of mine said I have no vacumum pressure.What can I do to fix
  • pbr13pbr13 Member Posts: 1
    I have a 96 Ford Explorer (EB) with a heater that will not blow out warm air. The feed and return water hoses are warm to the touch, the vacume lines appear to function correctly, and the damper opens and closes. please help...
  • dbwilson05dbwilson05 Member Posts: 1
    I was wondering if you have figured out what the problem was with your explorer and how much it cost you to fix the heater becuase i have the exact same problem with mine and its start to frost over in the morning and it sucks driving in the morning without a heater.
    Never did fix mine. The temperature actuator motor gears are stripped in the actuator. You should drop the glove box door and reach in to the left and find a lever that opens and closes the blend door. Pull back on the lever toward the rear of the car and it will open the door and provide heat. The temperature knob has to be set all the way hot for this to work. It may take a while to find the lever, but it is there. You may want to have the vehice running and you should hear a ticking sound . The ticking will direct you to the lever. Hope this helps. It would be very expensive to fix at a shop. Remember to not move the temperature control knob after you pull the lever back, or you will have to do it all over again.
  • atat424atat424 Member Posts: 2
    I have a 2004 explorer and the heat works great in the rear and third row, but all that blows out the dash is cold, I read your other listings and located the lever when I dropped out the glove box this fixed the problem for about a week, then I heard the clicking again and once again it was cold, so turned the lever again and nothing still cold, what do I do now?
    edited December 2010
    So the actuator on the driver’s side controls that lever behind the glove box on the passenger side? So if I replace that then that lever will stay down?
    (2004)
    The actuator is a geared unit fastened to the heater unit under the dash. It is quite a job to replace it, requiring removal of the console and other parts.I don't know the cost of the actuator, but imagine it is expensive. I've heard of costs up to a thousand dollars to fix what you are talking about. For me, I keep the lever down, and bear the extra heat by lowering a window a bit. In the summer I keep the temp control on cold for the A/C when I need it. Don' t plan on keeping mine for too many more years.
  • mo_mechanicmo_mechanic Member Posts: 1
    Thanks to all contributors on the heating problem. I finally found the lever to open the blend door on my daughter's 2003 Explorer. It was right behind the medal brace on the left side of the glove box with my hand just below the small bend on the brace. I realize that this is a temporary fix but at least my daughter will not have to drive 300 miles without heat. Thanks to all!!!
  • ridernlridernl Member Posts: 6
  • jennifer04jennifer04 Member Posts: 1
    ok i have checked the blend door it works but there is no heat all the hoses get hot the heater core is getting hott what else could cause the heat not to work oh yea the blower motor works to
  • wells75976wells75976 Member Posts: 1
    If everything is working properly, hoses are getting hot, temperature actuator is working, blower etc, then flush the heater core. More then likely it has build up from minerals in the water and is clogged up. Remove the hoses and flush the core from both ends for several mins until you have clean and adequate water flow.
  • guysfordguysford Member Posts: 2
    I too have a 2000 Explorer and in addition to the NO issue I do not have a fan which
    compounds the problem I believe it is in the switch as it works on only High and next lowest
    speed for the summer. Now with winter and the need to defrost or de-ice it is critical.
    Could it be a fuse or loose connection?
    I have a 2000 exployer and I cannot locate the lever for the blend door
    is it in a different position than the other model years? Next I have no fan movement
    In the front of the vehical . Only in the rear. I had high and next high speed up to
    a week ago. Has a fuse blown? when inside the dash I wiggled the wires to the switch
    but did not get the fan to work. Are these problems related? This is now critical for
    de-icing and defogging let alone heat.
    Sounds like your front fan motor is burned out. Could be a fuse, but more likely the motor is gone. This is independent from the rear air, which has its own fan motor. Your front one is easily replaced from under the hood. About 4 screws will open it up, you pop in a new one. Good luck!!
  • jclinganjclingan Member Posts: 1
    Did you find a solution to your heater problems?
    Your description of the problem is identical to my issue.
    I have a 2004 Ford Explorer 4.6l Eddie Bauer with Dual Climate Control.
    I purchased the HeaterTreater Blend door thinking it would correct the problem, however after I took out the actuator motors (the dual climate control system has TWO), I discovered the BLEND Door was find and both actuators were working properly also.
    I want to know how you were able to fix your problem.
  • explorerx4explorerx4 Member Posts: 21,306
    edited January 2011
    Try Flatratetech dot com. You can do a search or post your issue if you can't find anything that explains it.
  • vitahawkvitahawk Member Posts: 14
    Hi. I have a 95 4x4 explorer with v6 engine. I have owned this car since new and it has provided me with excellent service. Recently, I was bringing it home from my mountain cabin, outside air temp was 9 F. If the defrost was on, the engine temp gauge would shoot way to the right, near the red zone. If the defrost was turned off, temp dropped down within seconds to normal. I cycled this several times and got the same results. If I ran the air conditioner alone, it would not do this. Coolant level is normal. New heater core, about 1 year old. Any ideas??
    Bill
  • generallee73generallee73 Member Posts: 1
    I'm having this issue right now with my 2003 explorer. thank you for posting this fix. I will try it today.... hope it works
  • mtruxfanmtruxfan Member Posts: 1
    I have a 98 Explorer, I have heat coming out of the vent near my feet when all the climate controls are off. This works fine in the winter but its starting to get warm and I no longer need cold feet. Any help would be greatly appreciated by me and my right foot/shoe.
    Put your climate control in recirculate position and then turn it off.
  • 98sportred98sportred Member Posts: 1
    my heat stays on, no matter what position the knobs are in. Constantly blowing warm out.
    Also when I purchased the vehicle, the dealership said they needed to add refrigerant. It lasted only two weeks at minimal useage. I added 2 more cans and no cold at all. HELP Im hot all the time!!
  • ronieconroniecon Member Posts: 2
    the temp door actuator motor is most likely the problem,look behind glove box(allow glove box door to open beyond the stopping point)let the door swing down,the actuator motor is located on top of the blower box toward the middle of the vehicle.It has a single plug in(small)with multi0wires on the plug in,the actuator motor is flat,and is held in with three hex head screws,the rear one is the hardest to get to,this motor is not moving and changing the temp,to cold,it is staying in one spot on the hot side.
