Works good now- you have to stand on your head to do the job!
Took us about 4 hours!
on the blend door and will not respond to the heater,air motor control .
Any ideas?
I have a 2006 Ford Explorer 4x4 Eddie Bauer IV Generation 6cy with rear aux heating and cooling. The A/C is only blowing out the defrosters in the front. Rear AC works fine. Temperature control is working, I have both hot and cold air with no thumping or clicking noise when I turn the control knob. So it doesn't sound like the blend door. I checked the blend door actuator on the lower driver side and its working. I checked the vacuum lines behind the vent control knob and behind the glove box and all connections seem ok. I can reach through the vent and push the door open that blocks the front vents but but it's not opening or staying open on it's own. I also checked the metal arm that attaches to that flap from the vacuum reservoir in the back and it's intact. Seems like maybe a vacuum issue. I'd appreciate any suggestions. Thanks!
Symptoms: AC and heat controls work fine. Fan speeds work fine. But air flows only through front vents. When I attempt to change air flow to floor or defrost, the air continues to flow through the front vents.
Observations: There is a flow control valve located to the upper left of the glove compartment box. When I turn the flow control switch on the front panel from floor to vent to defrost, the valve rod moves in and out as it should. The valve rod though is to be connected to a plastic lever arm that pivots a flow control door or flapper. This plastic lever arm has broken and is not connected to the valve rod. Can anyone tell me how I could replace this plastic door and reconnect it to the valve rod.? Thanks
Willjk
Signed,
Melting in Italy!
