Axiom 6-CD Changer
Is it possoble to add the stock 2002 ISUZU AXIOM 6-CD CHANGER to a pioneer avic n1 player.
I now recall, it seems like it originally stopped working after a previous lights-on-jump-start incident.
Perhaps there is some fuse set reset going on. I just have to be careful to turn off the lights from now on.
So I turned my computer on and follow your direction pull the fuse out (No 2 - 15A - Audio B+) , so reset the circuit. As soon I put this fuse back on, CD changer start working and plays CD.
Thanks for advice
The reason it was so important that I found this post is that I would have probably not fixed the problem otherwise. He is what I did:
1. Went to the car and did not put the key in the ignition.
2. Pulled fuse "Audio +B 15A" and checked to see if it was burnt.
3. It was not burnt so I replaced it.
4. Put the key in and turned the ignition just enough to get the radio going.
5. Push the Eject on the changer, and then the CD button on the radio... nothing.
6. Against my better judgment, I pulled the same fuse again while it was powered on.
7. I replaced the fuse and cringed at the huge blue spark that it caused.
8. The CD changer immediately started shuffling.
9. I pressed the eject button and got my CDs out.
10. I verified that the CD player is working like new.
It's all good in the neighborhood. Thank you community. Thank you Google.
Interesting variation - I'll add that trick to the Stuck CD guide. Sweet (although the big blue spark would scare the crap out of me)!
Anyway the dealer wants $465.00 to replace and another $150.00 for labor. The court has awarded judgement for the driver that hip me to pay for it, still waiting for the check. The accident was Nov 07 its now Sept 08 and I'm still waiting fro the check.
I'll try this fuse thing and let you all know. Then I could use the check if I ever get it for a cold air intake.
both times i removed the console around it and unplugged cd changer under console. replugged in and it worked
Incredible good luck. Thinking my 02 Axiom's 6 CD Clarion Changer had died, I was attempting to buy another one, only to find out that there was nothing wrong with it in the first place. I read the tip in this section about removing the B+ fuse and it reset my CD changer and it is NOW WORKING FINE!
I think the whole lockup/freezeup/no response problem was caused by my battery running dead a few weeks ago, when the interior light was left on, so this could happen to anyone.
Here are the exact steps to correct the problem, in case your Axiom CD changers freezes up:
Remove the Axiom's interior fuse panel cover at the left hand side of the dashboard by the driver's side door. Look for the B+ Audio Acc fuse, a 15 amp fuse (blue). It is the 2nd fuse from the top and is labeled for Audio Accessories.
With the car turned off, unplug the B+ 15 amp fuse using a small pair of needle nose pliars. With the fuse removed, start up the Axiom. The amber MID display will now be completely blank. Shut off the car and reinstall the same 15 A fuse (unless its blown, of course, in which case you need a new one instead). This sequence appears to reset the MID Control Panel/CD connection somehow.
When you restart the car with the fuse in place, the CD changer on your 02 Axiom should come back to life and eject the CD cartridge. All should work again, or else the CD changer is defective or jammed.
Thank you to rbronosky for his original post on this elsewhere in this forum. I did the same steps, only without making a big spark, as I reinserted the fuse with the car turned off. But, I would have never even guessed this was possible without his post. THANK YOU, RBRONOSKY!
Now, for the bad news. This is my 2nd CD changer, which I bought on Ebay from a junkyard for about $75. I replaced the original CD changer, because it had jammed up, too, JUST LIKE THIS ONE, and I tossed it out, thinking it was dead. It even had a CD cartridge still stuck in it. That unit may well have had nothing wrong with it in the 1st place!!
Final comment: Some folks could easily get suckered into paying $600 for a new CD player from their dealer just because their CD locked up like mine. Isuzu sure has done a terrible job communicating problems with their vehicles. We should not have to learn how to fix these kinds of problems thru the grapevine, and Isuzu deserves to no longer be in the US car market!
