Ford Explorer Keypad Questions
in Ford
I just bought a 2003 Sport and i cant find the keyless entry code i have looked many places but i can't find it if any one knows where it is specifically for this modle please tell me!!!
Mark
Kaimond
The computer module is located behind the right passenger door. you will need to remove the plastic covering for the seat belt, this is held in place by two clips on the door side (no special tools required), pull out the the plastic covering, then look inside the lower plastic covering after you would have popped it open (pull lightly) the five bold digits on the sticker is the factory set code.
. I just bought a 2004 explorer and I have no clue???
Where the code can be found
This code is located on the owner's wallet card in the glove box
Is available from your authorized dealer via scan code
Is marked on the computer module
Computer Module location
2002 thru 2007 is in the right panel behind the middle row window. It is below the seat belt mechanism. You have to pull out the top plastic panel off, then loosen the lower panel to be able to see the face of the computer module. The code is on a sticker on the face of the module.
