Subaru Forester (up to 2005)
Ken
I too had a REAR wheel bearing failure. I keep my tires inflaced to 33 pounds all around. Why not? The owner's manual says to use 36 pounds with full load in the rear. It recommends 29 pounds in front regardless of load. So, if higher inflation was the cause of the wheel bearing failure, the FRONT bearing should have failed.
Blaming the customer is an art form that is practiced by many dealers. "You must not know how to drive a stick, that's why the clutch failed." Believe that and you are out $750. If they can make the customer feel gulity, she or he may just go away and not stick the dealership with the less profitable business of warranty repair where the manufacturer sets rates well below what they can charge the customer for other work.
I didn't experience that ploy, but I have had my share of "sunshine treatments" and stalls:
"Well, leave it for the day and we'll see what we can do." LATER: "Sorry, we can't duplicate the problem [of course, we didn't even start the engine since you left it]."
"It's really not much of a problem, but if it still does it in a month, bring it back and we'll see what we can do [which is tell you that you still have 12,000 miles under the warranty, so don't worry -- we don't since we think you will forget about it and then you will have to pay]."
"They ALL have it." [It's a design problem and you were so stupid, you didn't notice it during your ten minute test drive -- of course, our engineers didn't notice it in hundreds of hours of pre-production testing.]"
If you are dealing with an intermitant problem, make note of how/when it happens - cold vs. warm, hills, etc. Then, advise the dealership of your findings and ask them to arrange a test drive during those circumstances.
Always call us at 1-800-SUBARU3 if you are unhappy with the results. We can at least keep track of the complaint and look for trends.
And - - -if you are told "they all do that", ask for a ride in a comparable vehicle to feel more assured about that response.
Have a great Sunday!
Patti
My wife is a gravel truck groupie!
Alan G.
Fact is that the Forester is the only Subaru I could own because I need the headroom... and I don't have a bouffant hairdo.
Frank, a Massachusetts MAN
As others have reported, the glass on Subarus seems to be quite soft. My windshield has a sandblasted appearance at 55,000 miles, not unlike that of my son's car's at 150,000. I don't drive off-road, and rarely on dirt roads. Also, an ice scraper that I used on 2 other vehicles without problem, scratched several of the windows on the Forester. So, protection seems like a good idea.
I have never used a hood bra, but I hear that if you have one, you MUST remove it periodically and thoroughly clean underneath. Otherwise mildew may form and cause problems. The only negative of the plastic deflector has been a little extra effort cleaning the front of the hood.
I'd say neither is very good for windshield protection. The Forester's windshield is very upright so any stones that are big enough to cause damage end up hitting it anyway. I had a front hood deflector and noticed that all it did was send stones on a higher trajectory than without it.
The great visibility is a trade off for more windshield chips.
Ken
I've noticed that the Forester's nice upright windshield is a bug magnet! When I drove to South Dakota last May, I had to make extra stops about once an hour to scrape off the casualties.
So, for those who've tried the plastic hood deflector - do you find that it reduces insect impacts?
Cheers,
Scott
Yes, the hood deflector does reduce the number of insect impacts. The impacts that do occur seem to happen higher up on the windshield.
I don't know if Subaru has redesigned the hood deflector, but the one I bought for my 98 Forester caused the side mirrors to vibrate when I hit speeds of 80mph.
That, combined with the need to remove it whenever I detailed my vehicle led me to just take it off permanently.
Ken
--Susan
If you have the option, you might want to wait to take a look at the '03 Forester. Personally, I never buy a model at the end of its product cycle because it drives me crazy to make payments on an "outdated" model. That said, the current Forester has been around for a few years and has most of the bugs worked out of it. It's a seasoned veteran and very popular with owners.
I'm going to be buying a new car next year and the Forester is on my short list. I'm curious to see what improvements will be made in the redesign. I would wait so you know your options.
As to what's going to be new? Not sure yet; my assumption is that it will be a tad larger, with increased rear passenger room. You can also count on a host of new upgrades and detail improvements.
I'd certainly wait. If, once you see the new vehicle, and you don't like the changes, I'm sure there will be some '01 leftovers that can be had at an excellent price.
Patti, our Edmunds/SOA rep, has indicated some info on the new Forester will be coming shortly. So I'd stay turned...
Bob
Greg
BTW - notice I said "most".
Ideally, you would check your oil periodically by having an oil analysis done but for most people that's overkill. One quick way to determine if it's time to change oil is to look at the color of the oil on the dipstick. When the oil begins to loose it's translucent apperance, it's probably time to change.
Ken
Ross
The only catch is weight, which they've been gaining. That's about it, so I'd wait and then choose from a 2003 or a left over 2002.
I'm male and love my Forester. If it attracts attention from females rather than males, better still!
Mike: I would change the differential oil to check it. It takes a 1/2" drive and lots of torque, but get it loose and drain the oil. The drain plug is magnetic, so look for metal shavings on it. If so, your LSD is probably toast, so get it fixed under warranty. If not, it was not the differential.
-juice
Leo
Ross
Thanks for the reply. I can't find the tire size for the Forester. Do you know what the tire size the L and S models? Thanks.
Leo
I agree - get all four aligned. Subies are tricky to get right even when you do all four.
-juice
Bob
-juice
Leo
-mike
The auto is different. It starts with most power being sent to the front axle, 90/10 or 80/20 depending on who you ask. Any how, it has sensors in the pedals and g-force sensors to predict when slip will occur, and can proactively adjust that split. So when you hit the gas, it'll send more power to the rear, to prevent wheel spin. It's really only 90/10 when you are cruising.
S models and above add a limited slip rear differential, which acts in the same way the VC does, but from side to side on the rear axle.
In practice, both are very effective in the snow and in light off road situations. The rear LSD is even better, but my 5 speed Forester L is great even without it. The manual tranny, IMO, feels more neutral, while my dad's automatic feels a little more like a FWD car does.
The major controls are relatively light, including the clutch. It's very easy to drive; I actually have to adjust my habits when I drive my wife's 626, which has a stiffer clutch pedal. My Miata is closer to the Forester than it is to the 626.
-juice
Leo
-mike
I prefer the manual because of the "feel". I prefer RWD vs. FWD.
But you could argue that the auto system is more sophisticated, and I'd agree.
I'd say pick the tranny depending upon which transmission style better suits your needs, not based on the type of AWD system, since both are effective.
-juice
Leo
OTOH, if gas mileage is a high priority, as is purchase price, and you like the control manual gear selection gives you, plus the sporty feel, then get a 5 speed all the way.
-juice
BTW, I seen mentioned here about Foresters having trouble with their rear wheel bearings? What signs would that give you if you're having a problem?
Leo
-juice
We are going to the mountains in several weeks and it may be snowing.What is the correct procedure regarding tire chains? Front,rear all four?
My other question is, can the moonroof be partially open in the rain (we are smokers)?
Great site,great car.
Steve/Gini
Bob
Patti posted a while back that the AT never locks in at 50/50 but it does make some sense. My XT6 chirps the front wheels on startoff, but my dad's legacy L never does, similar power, my dad has smaller tires so he should be able to chirp em before the XT6 does.
-mike
Steve/Gini: use cable chains instead of the thick chains. Clearance is limited to the strut towers. I would use them on all four, and only when there is snow on the ground.
I'm not sure if there are rain gutters in the moonroof, but probably.
-juice
But if you're going down a steep hill and only have traction on the front tires, you'll spin out quicker than you can say "oops!"
-juice
Leo
Ross
Thanks for the info. Also for the info on chains - they (or true snow tires) are required at times where I live.
Bob
