Nissan Altima Electrical Issues
99 Nissan Altima GXE. 78K. great car. Not many complaints. Recently, the interior light's been flickering on and off. more specifically, it turns on with hard stops and flickers on bumps occasionally. The light on the dash for open door blinks along with it. I've checked all the doors and the trunk and they all appear to be closed tight (as far as I know). Is there a possibility that one of the door sensors is loose or malfunctioning? What's a good way to troubleshhot this? I think and hope this an easy fix that I can take care of.
About six months ago, a fuse would blow when I tried to start the car. All I had to do was replace them, and the car would start, but my mechanic could not pinpoint where the problem was in the electrical system. This happened three times in two weeks. Since then, I haven't had any problems (until yesterday). Also, I have to replace the battery about every 9 months, as the battery will completely die, and will not hold a recharge. I'm assuming this drain is also related to some electrical problem. Any help or suggestions on what the problem might be? :confuse: :sick:
wiring ,a tune-up,new battery,new computer, a Nissian serviceman has worked with them on it , still doing it. they have had it a month. Has ANYONE else had this problem???
Has anyone had this problem and how did you get it fixed?
I just recently gave back my Infiniti G35 due to getting older and getting engaged so saving money right now is a smart thing to do so I picked up an 06 altima special addition from someone on craigslist.
The car runs great and only has 33k miles on it and I just got a new battery and tires which I already new before I got the car.
Anyway, the owner advised me about the driver side window not closing automatically due to a security glitch all nissans and infiniti has. I had the same problem with my Infiniti but the fix was different than it is with the altima.
Basically when i close my window with the "one touch up " push of the button the window goes all the way to the top and then back down about 4 inches as a security measure as if there is something in the window. I believe there is a switch to turn that off under the door panel but I want to make sure before I do this myself. The car is no longet under the warranty and the dealership will prob charge me 50bucks or so so I fiugre I can just do it myself. If anyone here knows the fix please let me know . Thanks!
I observed that its happening with dashboard too.. Headlights and dashboard lights suddenly going dark and light.. I changed my headlights 3 times!Sometimes while i'm driving "Brake", "Open door" and other lights flashing.
IS IT BECAUSE OF ALTERNATOR??? Because mechanic checked fuses, battery and other electrical things and said they are ok..
Thank you for responds..
Akmal
Just happened to me the other day; a small wiring glitch and a fuse fixed me right up.
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?f- romSearchPage=true&pageId=0996b43f80381f41&partName=Horn&partId=0996b43f80381f41-
So my mechanic checks it out and tells me that the alternator needs to be fixed or replaced and needs a new computer because the alternator wore it down, I guess? So end result, when I get the car, he tells me he's replaced the computer and rewired the alternator into the computer. I replaced my alternator last about 4 years ago in 2006 at a Sears tire shop.
He charged me $500 for parts and labor for the replacement computor. I plan to call him to verify if he kept the same alternator in the car. I hope to not have this problem again for a while, yet as I talk to people with older similar vehicles (Pontiac grand prix, et) the samething happens as well.
I just want to know if this is something that I need to anticipate happening every now and again??
