Ford Escape Transmission Problems
My 2006 Escape has a pinging noise after the vehicle moves anywhere from ten to one hundred feet down the road. I am at low speed at the time. It could be in the front drive train area. It is not very loud, but you can here it. Sounds like a hammer hitting a rail road track. Any clue?
Thanks is advance.
6- Speed Auto
I am afraid I am out of warranty so am I SOL if it is problem with the transmission.
I would like to address the shifting concerns you mentioned with your 2008 Escape. Have you had it looked at by a Ford dealership yet to be diagnosed? If you send me your VIN in a private message, I can document the concern and see if there is anything I can do to help.
Cory
Ford Customer Service Division
SUVs and Smart Shopper
Is it possible to put the transmission of a 04 Escape 4x4 to a 05 AWD Escape? The transmission of the 05 Escape is gone...
The answers I've got so far varied, mostly they said "No". Any ideas?
I've already read about the differences between them I just want to get the opinion of an experienced mechanic or any member that had similar predicament.
I would be grateful for any comments soon as I need to make a decision this week on this issue.
I took this vehicle to two Ford dealerships and a trusted auto repair shop. No one could seem to determine the true cause of the problems. I had the grounds cleaned, spark plugs replaced, spark plug wires replaced, and alternator replaced.
At the urging of a friend, I finally brought my Escape to Midas. They correctly diagnosed and corrected the problem. Apparently, the person owning the Escape before me installed an after-warranty alarm system. The brand was Code Alarm. The alarm system was not compatible with my Escape's computer and was causing severe malfunctions. The alarm has since been removed and my car has not had problems since.
I'm finding that if I have the cruise control set to a given speed, come to a stop and then resume it, the transmission stays in the current gear until I again reach the set speed. Then the transmission starts to run up the gears, and the RPM's start to come down. What this means is that the engine can wind up going all the way up to around 5,000 RPM before the transmission shifts bring the RPM's down. Has anyone else noticed this? I would have thought that the transmission would shift normally as the speed increases to the preset point.
In those conditions the FE conscious method is to run the car back up to speed "manually" and then hit resume.
This is Seni with Ford Customer Service. I am sorry your Escape is not performing to your expectation. We recommend that your vehicle be inspected by a Ford dealership to determine the cause of any symptoms it may be experiencing. If there is no coverage under applicable warranties, recalls, or ESPs, repairs and services would be your responsibility. Your next step is to make an appointment with your servicing dealership to have your vehicle diagnosed. Please contact the Customer Relations Center at 800-392-3673, if further assistance is needed. Thank you.
Seni
Are you really suggesting that Anton's Ford Escape CC is not operating as designed..? Or are you simply "drumming up" income for some Ford dealer.
Every CC I have encountered has acted EXACTLY as Anton described.
I apologize if my reply came off as a sales pitch of some sort. My intention is to make sure that all vehicles are properly diagnosed and that any issues that need to be looked into further, would be.
Seni
My parents' 2008 Ford Escape transmission lost gears 2 and 4 in their automatic. They took it to a dealership who said "your transmission fluids are dirty, need a flush and fill which might fix the problem" to the tune of $280. My parents paid, and shocking but did zip. The fluids were cleaned and checked the week before, ethics here please.
I don't care what the warranty is, but 70,000 miles and the trasmission goes is definitely a manufacturer defect.
We were a family of Ford owners and looking to buy an F350 and Ford Five Hundred, but we'll go foreign before we spend money on another Ford. 12 cars in our family, all were Fords, and they won't stand behind their own transmission?
Good-bye Ford.
But, if you're going to expect Ford to guarantee their cars for life, buy a
Toyota. They don't either, but they are quite reliable and long lasting.
I currently have 4 Escapes, and have owned 8 of them from 06 to 10s. Never had a bad one yet, and I run them all to 100,000 miles. I would recommend them to anyone.
***200,000 miles with no problems on the average.
That complaint is currently common to the ENTIRE industry. In an attempt to most closely match the FE of the CVT transmissions these new 6(10) speed automatic transmission ECU control systems are constantly on the hunt for the most optimal gear ratio. With 10 to choose from that results in a lot of HUNTING.
SOP, state of the art.
My Mitsubishi Lancer has a CVT (which I hate, BTW), and never hunts, but also never changes a gear. Instead, the engine winds up like a sewing machine and stays wound up high until you reach downhill, or cruising speed. Very unsatisfying, but apparently, efficient.
Back to the issue, GM, Ford and some Japanese manufacturers use the same transmission made by Aisin now. Joint venture between them. I'm not sure the Tribute/Escape has one of these, but Ford warranties the power train for 5/70 do they not? The new Escape has the same transmission as the Fusion, that I'm sure of. And it sounds like you just aren't used to the way it runs to me.
