Toyota Tacoma Oil and other Fluid Questions
I changed my oil the other day and put in 5 quarts of Castrol 5-30. Does this seem a little low? I figured I would need about 6. Also, does anyone have an oil they would recommend over the Castrol? What about filters? I'm using the Toyota filters. Anything better?
See Also: Stop Changing Your Oil
What say You???
kcram - Pickups Host
If you put fully synthetic (which is recommended) in you won't need to change the oil but every 6k miles. With regular oil, 6k might be the max for the oil life but 5k is a good and safe number of miles to go on regular oil, especially if you are not driving the car in harsh conditions or doing a lot of performance things with it.
By the way, his recommendation was made after I blew the engine in a '91 F-150 (gas) and he opened it up, said it was really gunked up, and asked what kind of oil I had been using (I had been running Havoline 10-40W).
If anybody knows any reason NOT to use Shell's Rotella 5-30W in a Tacoma, I'd like to hear about it.
Also, I've read and heard negative comments about Castrol...any opinions on that?
1. Put key in ignition, turn to the "on" position, but do not start vehicle.
2. Push in trip odometer reset button until actual mileage of vehicle is showing.
3. Turn off ignition
4. With ignition off, push in trip odometer (actual mileage should be showing)
5. Turn key to "on" position while continuing to hold in trip reset.
6. You will see several dashes appear in the odometer. When they disappear, maintenance required light will disappear.
Jack
This is making me crazy - help will be appreciated. Thanks.
Manual transmission has issues too. I'll start another thread on that.
BEWARE!
It takes a talented reach to grip it but after the first time, it's all downhill 5K miles later at the next change.
One of the V6 Tacoma quirks is that the actual engine oil pan is cast alum., while the trans. pan is stamped steel.
Not to be rude, but folks that can't distinguish the engine oil pan from the transmission fluid pan, don't need to be under their truck draining fluids.
