Chevy TrailBlazer Keyless System
I have a 2005 trailblazer that the keyless system keeps failing. Of course it works when I take it into the dealer. However, when it fails, I cannot open up the back hatch, nor with the rear wiper work. The dealer keeps telling us there is nothing wrong, but it keeps happening. I am at wits end. Any suggestions? e-mail me with help cencoastsurfer@yahoo.com
TJ
TJ
It's best to keep the discussion here so that everyone can benefit from any solutions offered.
I repaired like this for .10 $
Look at the backdoor
inside you have a motor ( black )with a little white arm
at the end of this arm, a part like a black pill
slide out of his case, this is why the keyless fail.
I did a little hole
and place an aluminium plate over this black part
to keep it in
buy a bold size 2 or 3
with a lock nut
excuse my poor english
So that arm comes out of the motor where it should nomally be connected, and then won't unlock the latch mechanism? That arm goes over to the latch that's operated by the outside handle?
all this system goes with outside handle
it's there to move some pins to stop the handle
and windows's button to move !
now !
if you look inside the car ( lift the backdoor )
remove the little round plastic cover at the bottom
of the backdoor
you will see the white part of the motor
( electric connexions )
at the right end of the white arm you have this little black piece how is pushing to do rotate (x - y axe )a grey part
usualy it stay well, but sometime the white arm
can't because the black piece slide so easily.
to repair
remove a bolt under the belt how close the door
remove the inside cover of the backdoor
and 4 bolts under the door as shown in first image
do a little hole .... red ......in the yellow part
you have the place to do a hole whitout touching at the arm
do a aluminium plate..........green
with same holes
buy a little bolt ( sz 2 or 3 ) with lock nut
and install like before the last image
excuse my english
and I hope you will understand
but the garage asked me 400.oo$ to repair the keyless system
with perseverance it's costed me a bolt and nut
and free time
Consider writing up a Guide
SUVs and Smart Shopper
yes, It's easy when you know a bit ' Sketchup '
soft for make 3d drawing
http://sketchup.google.com/
Have 3 questions:
1- When I engage the Cruise control, it works fine but NO LIGHT on the panel appears that can tell me it is engaged. The cruise works but the status light is not there. Is it common?
2- I heard of Stabilitrack system. Not sure where is the button to disengage it. Please help.
3- My TB doesnt have a DIC (Driver Info Centre). Means doesnt have the buttons on steering wheel. I heard I can adjust some parameters (Auto Headlamps Off time etc.) Can someone advise me how can I make this customization without having DIC in my TB? Can I do it with a computer or a diagnostic tool?
4- I dont know what is my Gear Ratio to let me find out what load I can tow. Can someone help me how can I find it?
5- I got only One key with the car. Can I simply duplicate it? does it have any chip inside?
By the way, I drove it first time today and got a good gas mileage. Made a 424km trip in 43 Litres.
