GMC Jimmy Squeaks, Rattles and Noises
                    i have a 2000 gmc jimmy slt 4x4. i get a noise that vibrates the underneath the passenger side more but also feel on the driver side, noise that only happens at about 25-30 mph and get a bit louder when at higher speeds, doesnt happen when at a stop and reving the rms to 2-3000 rpm.
i guess that could rule out exhaust, but it sort of sounds like an exaust leak. i hear could be the transfer case, im not sure what that box is underneath, its flat and has a drain plug...
any ideas???
any ideas???
Sound description: Sounds like a wagon squeak. I can push down on the front end and it squeaks. It's more like a very loud "CREEEEEEEEEK". ??? Hope that helps. Anyway, I'm not to automotive savvy so any help would be greatly appreciated.
Thanks in advance,
whiteink.
jhighland, "Chevy Blazer/GMC Jimmy: Problems & Solutions" #2581, 31 Jul 2006 12:23 pm
Well not 10K goes by with something new, now my battery died on me, fine it was a 2000 GMC jimmy with about 98K on it, so I replace the battery, but there is this humming whirrling sounds coming from the front end, I open the hood, its impossible to pin point due to engine noise, but could it be the ALTERNATOR? When I start it up its running around 12V if i hit the accelerator it shoots up to 14V? as well my odometer digital readout is dims then goes bright when the vehicle is idling, but when im driving with the accelerator pressed its nice and bright, anyone please help, I hate having to pay those GM wrench monkies $80 an hour to tell me everything is fine....
Then this could be dragging brakes - rears will cause shake in the vehicle or out of round rear disc/parking brake drum or rear calipers sticking (common after a brake job - always replace rears as single plastic composite piston) - had them all before. Of course this assumes the tires are properly balanced and get a Force balance that the machine checks tire roundness and weight as well as the rim to rules that out. Then many other areas to look at and even the front end alignment can cause - should have been done after the ball joints! Then theres U-joints to check. Most good aligmnet shops can pinpoint the cause.
I apologize for this one--> but I don't know how to see if my u-joints are bad, so I have not checked this out. Tranny fluid and rear diff fluid is what I'll check next. I'll have one of my friends help me check the rear pinion, and everything else mentioned, and I'll keep this posted and let you know where I stand. THANK YOU!
My only question now is, is replacing the entire hub assemlbly managable or is this gonna be a pain? The bolts are not rusted so I hope this goes well....THANKS!
-Thanks again Repairdog!
2wd removal is same as the posts above except no CV shaft to pull out.
- Thanks
-Furthermore, I've discovered through research that this wheel bearing is the worst design ever made on this vehicle. One of the most common things to go on Blazers, unfortunately. I am so happy it's finally fixed! THANKS AGAIN....
-Lincolnsixecho
One other question for you. Is there anything else I should be ready for to go next that is common?
-2002, 2dr. 2wd. blazer 4.3L 51,900 miles
Thanks, Lincolnsixecho
They have a few problems but handle well, take a crash pretty well with the frame under them, and ABS works well.
We bought one with 77K miles, but looks to have been well maintained. Swapped out the shocks (original) idler pulley and belt, and, of course, the stupid door hinge pins. I have never owned a car or truck where the pins have worn out. I guess oiling them a couple of times a year helps, but every Blazer/Jimmy we looked at had the bushings worn out. Strange. Next will be tranny service and coolant, then probably a muffler/tailpipe. Sounds like a baffle has let go in this one (also original). Engine is smooth, and tranny shifts as it should, so we will see where we go from there.
Once again, thanks for all your posts!
Jim
-Thanks.
2wd or 4wd?
