Toyota Sienna Interior and Trim
I notice all 3 head rests in 3rd row are hard to pull out.
Especially after unfolding from the floor. There is no way a normal person can pull the head rest in and out.
I am not sure if WD-40 will help?
Fabric covered seats do have adjustable arm rests as always.
According to Toyota Customer Care this new arm rest design was directed by the Executive Committee and will not be corrected by Toyota even though the arm rest can be replaced with the 2006 leather covered arm rest to regain usability.
Please check your new XLE and Limited vans before accepting delivery. If the new negative angle position is acceptable then no problem. If that is uncomfortable then your problems begin if you accept delivery because the problem will not be fixed according to Toyota Customer Care representatives.
We have taken pictures if you would like to see what we are talking about.
Our research has discovered that our 2007 Sienna Limited has the only negative angle arm rest out of over 100 vehicles checked. All other arm rests in our van are set to level or positive rest angles.
Jim
I'd look into trading in your car for an '04 or newer Sienna with the features you want first.
can you send me the photos showing the arm rest issues on the Sienna XLE that you described in your email msg?? I too am considering the Sienna XLE with leather and was unaware of this issue....thanks
jackmot00@yahoo.com
http://www.trdparts4u.com/ME-CEIC.aspx
That's the OE stuff. There is also MacNeil, if you want to comparison shop. They have those multi-page ads in Car & Driver magazine.
Seems they are $45 + shipping
Anyone know if they protect form stone damage and does not
yellow or if they diffuse light?
First check all the storage bins, maybe empty them to make sure the noise is still present.
To be honest if they crack the whole dash open to fix one rattle, you may end up with two. :sick:
Haven't asked the dealer if any adjustments can be made to the armrests, so does anyone know if this is possible???
I'm not sure why they did that. You may want to ask your dealer if an 04-06 arm rest will fit in the same place.
I towed the car to a local dealer and found out the clever, P/N 3305508011, was broken. I believe the clever is made from aluminum casting and failed very clean a straight across its cross section (I have a photo at the broken aluminum casting part while the clever was in its place and still attached to the assembly). Instead of replacing the clever, the dealer has asked me to replace with the whole steering column assembly for $819.00 as a used part and warranty for 6 months. I requested the dealer to give me estimate to replace the broken clever. The dealer gave me an estimate for $619 for replacing the clever P/N 3305508011 ($98.12) and shaft P/N 3350108011 ($101.51) with the labor hours of 3.7 hours. However, the dealer said that if replacing the clever and the shaft, the problem cannot fix and I cannot even drive the car.
I have the following questions and would like to seek your advises:
1.) Why can't my car fix after replacing the broken clever and the shaft? Why it takes 3.7 hours to replace the broken clever that is visible from outside and appears it does not need a lot of effort and it is readily to remove and replace the broken clever?
2.) Why do I need to replace the whole column assembly with a used assembly for $819 (= $350 for the used column asssembly and 4 labor hours)? How reliable is the used steering column? Why it takes 4 hours to replace the column assembly?
3.) What can I do?
