Question is why VW move the most important part out of Germany? Are they completely satisfied with the quality of the engine made in other country? Are they regarded as identical? I guess the quality was acceptible by them. I red on this forum that some kind of ring went off the engine and the mechanic said they have seen a lot of this problem.
The answer, as it almost always is, is money. The pay rate in Hungary is considerably lower than in der Homeland.
I wouldn't sweat it. Now, the electronics, OTOH....
I scheduled "Engine Coolant Temperature Sensor" replacement with independent mechanic on Monday and this Saturday I got a letter from VWoA that beforementioned sensor is now covered by extended warranty (10 years or 100K miles).
I think it is 6th service/recall with this car.
In my car the temperature gauge is capable of dancing from normal to 0 and sometimes back. Warm/hot air comes out but gauge shows 0.
Apparently it can cause even more problems, the biggest one probably is that some states fail emission test because the "Check Engine Light" (MIL[Malfuction Indcator Light] in VW speak) is lit.
Enjoy.
Krzys
PS I will cancel my visit on Monday to have it done for "free" at dealer.
... unless Germany "annexed" Hungary...
Let's put it this way - spark plugs aren't changed one at a time - they're usually changed as an entire set. The same logic should be applied to the coils.
HTH...
The thing glowing is the turbo, if you mean on the passenger side of the engine. I think you are in deep trouble that I can't diagnose over the interwebs, but would suggest you get your car to someone familiar with VW's /Audi's ASAP.
My 98 Passat 1.8L just had the exact same thing happen. The #1 cylinder is not firing but a new coil did not fix the problem. Something wrong with the CPU according to a local shop in NAPLES ITALY who claim to be familiar with this problem. Any recommendations? Thanks.
I found someone with VAG COM software who performed a throttle body adjustment procedure, and all is now well.
Might be worth a try.
But my mechanic said the injector nozzle need servicing or cleaning. Im about doing that
