Honda CR-V Timing Belt
I have recently bought Pre-Owned a 1998 Honda CR-V EX from a dealer in Cleveland. The vehicle has 85000 Miles onto it. I have read in the owner manual the recommendation to change the timing belt on 105000 Miles or 84 months/7 years which-ever is earlier.
Can somebody guide me if the timing belt change is necessary now since there are about 20000 miles possible on this vehicle. I requested the dealer to trace through the history of the service record and he confirmed that the timing belt has not been replaced earlier. The vehicle is owned and driven in Cleveland since 1998.
If the belt needs to be replaced what should be the estimate for the cost?
I don't think their listing is foolproof (I think they are wrong about my minivan), so usual disclaimers.
2000 Honda CR-V SE. 116,000 miles, appears well cared for, runs great, no service records available.
Charles
The same procedure doesn't seem like it would apply with a timing belt. :confuse:
It it does, where do you check for this play?
Charles
I'll leave that for someone who has specific experience with the CR-V. Anyone?
Is it a rip-off?
The timing belt service at the dealer should be about $550 - $600 alone. It is recommended to replace the water pump at this time. Most of the charge is from labor. The belt itself is a $20-$30 part, but the tearing of the engine apart adds up. While you have it torn up, might as well replace the pump, which is driven by the timing belt. They should also replace the tensioner at this time as well.
See if you can negotiate a 10% off or something.
The water pump was also replaced.
With the labor charged of $340, the total cost reached about $550.
$100 labor charge is surely a steal, only if it can be done properly.
In 2002 the 4 cyl Accords and CRV's went to a timing chain that does not require replacement. It should last the life of the car.
The 1997-2001 CRV's used a belt that should be replaced at 105,000 miles or 7 years. It's an expensive job but once it's done, it's done. A person would be foolish not to replace the water pump, seals and drive belts while they are "in there".
If a person doesn't know if the belt has been changed, it is possible to pry back the timing belt cover and look in there with a flashlight. It's about a half hour job and it's not 100% foolproof but there are markings on the belt that a Honda Tech can look at and see if it's been replaced.
Note, I said a HONDA Tech. They deal with these every day and when they say it's been replaced, it has been.
Not a good thing to take a chance with.
If you decide to take it elsewhere you might save a bit buit make sure they know what they are doing. It's not an easy job!
Was the work performed at the dealership, or is the Honda Tech doing it on the side?
My mechanic, (independent), also replaces some seals that are very inexpensive and are easy to replace when doing the timing belt procedure. I think they are cam seals, but I'm not positive.
He also adjusts the valves during that procedure since it is so easily done at the time.
Dealerships are independantly owned. While you may have beef with the dealership, I would not project that on the brand it self.
However, if you get nowhere with the dealership, you may want to get Honda corporate involved and see if they can put pressure on the dealer.
Your optons are:
1) Notify the dealership of the discovery. If they know what is good for them, they will refund the original charges, and ask you to sign a waver to protect them from litigation.
2) If they ignore you, notify Honda Corporate. The phone number and address is in your owner's manual. Honda can pull the dealership's franchise license.
3) Notify BBB.
4) Take the original dealership to small claims court (Judge Judy kind of thing). It only costs $10-$15 to file, and you don't need a lawyer. Make sure you have all the ducks lined up. The court may ask for witness (second shop mechanic) testimony, however, the wirtten estimate from them, and the photos should be enough.
The only way to prevent another person from being taken like this, is to make sure the dealership knows that victims can "kick back."
I have taken a shop or two to small claims and won. They learned their lesson and hopefully stopped scamming people.
One shop refused to pay. I sent all their info to the Sheriff. They siezed the shops account, gave me my money and took their cut (2x of what I got).
Good luck. Courts are slow, but they work. It just takes persistence.
I know it is going to sound sexist, but bring a male along.
Many of the GM's are not your MBA educated business people. They are just glorified salesmen, who were really good at selling cars...
When you bring this male along, you will see them addressing the male, most of the time.
It is just what it is.
I always get a different answer from the mechanics than my fiancee. Even though, she knows cars just as well as me. But, she is a girl and they tell her that she needs blinker fluid, and her halogen fluid is low.
Hope this helps.
The CR-V has had a timing chain since 2002.
Unlike a timing belt, it is very unlikely you will ever need to replace a timing chain.
Here is a similar Q&A from another site (http://www.2carpros.com/makes/honda/accord3.htm)
Question: 1999 Honda Accord mileage: 106,000. The mechanic at the Honda dealer suggested the we replace the timing belt. Cost would be around $500. With this low mileage, should we be concerned about the timing belt?
Answer: Honda normally recommends replacing the timing belt at 60,000 miles. However, with your low mileage and the age of the car, it would be a good idea to replace the belt and the water pump.
change at a Honda repair shop:
The belt
The belt tensioner
Water pump
Cam shaft seals and crank shaft seals
Drive belts.
check radiator hoses
check pvc valve or replace if hard to replace
I have owned a 1993 and 1991 and now a 2003 Maxima and a Double over head cam 1995 toyota Camry 6 cyl.
I used my local mechanic to change the belt on the 1991 maxima. After about three weeks later I noticed quite a bit of oil in the engine compartment and drove to my mechanic Pronto.
The oil was running out of the timing belt enclosure, engine compartment splattered.
We found that the crank shaft front seal failed and ruined the belt. A front cam shaft seal failure will spray all the oil out of the engine in a very short period of time and destroy the engine
I called the Nissan Dealer and asked the service manager if the Maxima had problems with oil seal leaks. He said we don't have this problem. We always replace the seals when we change the timing belt.
This almost cost me an engine. We replaced the belt and seals and I went halves on that repair.
I still used him until he retired. he was a good mechanic but didn't know one small detail about the Maxima. Use the dealer for this Job.
My toyota 6 camry belt change cost about $757.00 for the complete job.
Check with their parts department and get price for all parts, gaskets and antifreeze replacement and labor
Type this list, triple spaced; (1) (2) etc.
Discuss this list with service manager, not the service representive. Arrive at a agreed upon price.
Have the service manager sign this paper or if necessary sign the shop work order under his signature.
Demand a copy of this contract BEFORE you give the dealer the keys.
Remember, approximately $1000.00 of your money is at risk here.
Remember, no copy of the contract, You leave your power with the Dealer.
I forgot the antifreeze and it cost me about $35.00
Sounds dicey..
