Chevy S10 - GMC S15 and Sonoma - Wet floor when it rains
loveroadsters
Member Posts: 4
in Chevrolet
I have a 96 S10 with almost 140,000 miles on it. When it rains I get wet carpet (only) on the driver's side. I don't see any water leaking in from the windows.
I am not sure if this wetness comes with the rain while the truck is NOT being driven, or only WHILE being driven, or both.
Thanks for any and all suggestions!!
My 2002 ext cab (when New) had a similar issue on the passenger's side.
At top passemger's corner of the windshield - the roof is welded to the upright suport from the lower body. Outside it looked Ok - but under the windshield rubber trim strip - at the top corner - it was open a tad between the metal supports. Water was getting down around the windshield rubber outside cosmetic rubber trim would run down under this rubber trim - and instead of running down around the windshield glass/ seal - it went inside the support weld hole and was dripping inside and down the inside of the support into the passember kickpanel area - and leaking into the passemger floor.
The dealer finally pull away the inside corner of the head liner - say the issue, caulked it up - and I had no more issues....
Hope this helps ...
Thanks Again!!
#2 The body seam on the driver side of the back of the cab wasn't caulked properly at the factory. Bead of sealer was an inch away frm the seam. Besides it being a quality disaster, I enjoyed driving it.
