Dodge Ram General Operating Questions
in Dodge
Hi, i own a 01 dodge ram and i swear this thing is a money pit. I LOVE the truck but its just thing after thing with it, and from what i hear i do not think it is just me. Here are my main problems:
1) GAS, not only is this thing as big as a tank, it drinks gas like a tank. I get on average 10.1 mpg and that is about 70% city and 30% highway. Is anyone elses this bad or am i just not smooth enough?
2) Durability, the dash has cracked from sun exposure (i guess) the clips on the sunglasses and garage door remote break super-easy and my cupholder breaks if i put a drink in that is over a medium.
3) Electrical Issues, lights are weak, tow lights are iffy, if i turn the wheel to hard or roll down a window all the lights go dim. Anyone else have this prob.?
There are many more and i would like to hear others problems, if you can repost with any help, or to complain like myself
it would be greatly appreciated. Thank you very much for your time.
Yes, it only gets 12.3mpg at highway speed. I do 99% on road driving.
For the most part I lived in California, I never did anything special inside or out and have no cracked dash. I now live in Arizona and still have no problems other than the exterior paint cracking off.
You failed to mention if your truck is auto or stick. Mine is a 5 speed. You may of provided your own answer in not being smooth in the stop and go department.
As far as the electrical problem. It sounds like you need a good mechanic to go over it. Of course we are talking lots of $$$ here, they don't find the problem and fix it anymore it is just swap out parts till the problem is fixed.
Good luck
I bet I know how it got broken, too!
The PCV valve twists out by rotating it counterclockwise and pulling it away from the housing.
Best regards,
Dusty
I see plows outfitted on RAMs occasionally enough to know that current draw is not generally problem with the standard electrical package. What make and model of plow is this?
Dusty
Dusty
The alternator is the original 136 ampere. So I guess it's normal.
Dusty
Good luck,
Dusty
I would recommend that you obtain the electrical wiring diagram for that year RAM. You need to isolate potential possibilities and trace the issue down through the logical wiriing harnesses and connectors.
Good luck and best regards,
Dusty
kcram - Pickups Host
I've also seen a couple of RAM 1500s that had dry U-joints that caused a similar problem.
Dusty
Anyone else have a similar experience? We would like to get this fixed or we will have to get rid of the truck.
www.barbari.com
I have a cold air intake, Hypertec program burned in, Flowmaster CAT back exhaust. I also have a 6 inch lift with oversized all terrain tires.
You may be be thinking this truck must suck fuel like crazy!!!...but after i add a couple upgrades it helped me A LOT!!! (11.4 on the city).
About your dashboard????....Buddy!!! only thing you must do is add "Oil Protectant" in regular basis :shades: I live in Arizona and believe me the sun here is hell hot and i dont have any problems with it.
It is annoying as I am usally far away when I am using the remote and have to walk back to lock it or do the start/stop thing. The dealership can't figure it out.
I've tried both fobs but think the trucks reciever is the problem. Anyone else have this probelm?
Food for thought did you have a remote start system installed by the dealer?
If you did it might lead the technicians in the right direction to come up with a solution.
kcram - Pickups/Wagons Host
Aaron
