Subaru Forester (up to 2005)
1100101103105106344
  • jeijei Member Posts: 143
    From my experience, Anco blades offer the best value. They seem to last slightly longer than the others. I don't believe Subaru sells just the rubber refill.
    John
  • declansdaddeclansdad Member Posts: 120
    Jonjons,
    The infant seat that my wife and I use the Avanta SE by Century. It connects via the base unit (we have one in each car) and also mounts in the Lifestyle Series stroller by Century. I think we purchased our stuff at Babys R Us--can't remember the cost, but I really like the fact that the system is versatile. Plus, I really like having the base strapped in the center of the back seat of the forester.
    Michael
  • wmquanwmquan Member Posts: 1,817
    The Century Avanta car seat _may_ become the subject of a recall. According to Denise and Alan Fields, the authors of "The Baby Bargain Book," Century has asked retailers to pull them off of the shelves because of problems. Century has not admitted to this, however, plus they do are discontinuing the model in favor of a new generation.
    One frustrating thing about car seats is that manufacturers can't help but botch things up sometimes, resulting in a recall. Even the vaunted Britax line has had two major recalls the last few years, and one was done in a quite unsatisfactory manner (incorrectly molded shell from their supplier, they got around it by giving customers extra shoulder harness padding to meet U.S. standards, rather than replace the entire seat).
    A version of the highly-regarded Graco Snugride has been recalled (nearly a million of them).
  • crossroadscrossroads Member Posts: 16
    I purchased a Draw Tite hitch for my new 02 Forester from my Subaru dealer. I was installing it. It didn't fit properly (bolt holes didn't line up on driver side). I talked to the parts manager at my dealership and he told me that they had never had problems with that hitch fitting properly. I felt that the implication was that I didn't know what I was doing... although this was never stated.
    Anyway after trying to install this several times, I took it back to the dealer. I then went out and purchased a Hidden Hitch. It fitted like a glove and it looks better than the Draw Tite would have. Much of the hitch frame is hidden and it includes a neat cover for the receiver hole hole.
    I don't know if any others have had trouble installing the Draw Tite, but if you are going to install a hitch, just be aware.
    Mike
  • scirocco22scirocco22 Member Posts: 721
    Bob-- When I purchased my 2002 last year, I was looking at the SoA site where each dealer will list their inventory ...example of a page: http://makeashorterlink.com/?L1AB25B9 --I noticed that for each Forester listing, it listed on its "Features" list an item called a "Rear Bumper Cover." When I asked my salesman what this item was, he scratched his head and told me that he thought it was in fact the protective rear bumper step pad ...which as you stated, is standard equipment across the current Forester line.
    It baffles me too, that this item will now be an option on the new Forester ...disappointing, indeed.
    --'rocco
  • jim1969jim1969 Member Posts: 62
    Does anyone know if the tweeters are pre-wired to fit behind the grills next to the door handles? I don't want to have to run wires if I buy the tweeters from the dealer and install them myself.
  • lakepoplakepop Member Posts: 221
    Well..you don't say what you are driving or what year so expect some questions.
    I do know that on the 2001 Forester L a plug in exists behind the grill.
    I upgraded my door speakers and added the tweeters. The tweeter grill is easily pried off and voila..prewired connector. This is a very easy mod ..at least on the 01 Forester.
    Note that a designated "pry" spot exists on the forward part of the grill and is identified by a small notch. Just take your time.
    Hope this helps.......... : )
    I have a '02 Forester S Premium. Is it prewired the same way? What did you upgrade your speakers with? The package from Subaru?
    Well..I'd just take off a grill and check...only takes a second. Or, you could shine a flashlight into the grill..I think you will be able to see.
    I use the Subaru tweets...bought them on sale for about $20 over a year ago.
    FWIW....I really cannot hear a significant imrovement.
  • willy128willy128 Member Posts: 4
    I have a Y2K Forester S. Anyone did turbo charge their Forester in CA? What's the catch doing this especially in CA? I think I saw Juice talked about this before but I remember the shop was in CO. Also I can't find the site anymore.
    -Kin.
  • qbrozenqbrozen Member Posts: 33,749
    Ok. I really thought I had this discussion in my subscriptions and it was just REALLY slow. Guess not. Anyway, I have some mechanical questions for the Forester and, I'm sorry to say, I can't sift back through 3000 posts to catch up, so maybe somebody can help me.
    I discovered a few weeks ago that our '98 has a moderate oil leak. Its coming from the rubber seal of the timing belt cover (is it a belt or a chain??). Actually, I'm calling it a timing belt cover when I really have no idea. Its the plastic cover that is located closest to the engine just behind the pulleys. This is my first H-type engine and I am completely in the dark. Anyway, I don't believe oil should be in that compartment at all, should it? Second, if it is in there, it seems as if we have a blown camshaft seal or crankshaft seal or both. Third, since this happened and we started to work on tracking down the problem, we've discovered that this engine seems to have a great deal of blow-by because there is actually quite a bit of pressure building up in the crankcase. If nothing else, can anyone with a non-leaking Forester tell me if, when the engine is running, they can pull the oil cap and feel a good deal of pulsing air being forced out of the crankcase? I'm really worried that I may have a blown ring, but it just seems so odd that the engine runs perfectly smooth. So we're thinking that maybe this is an inherent characteristic of this type of engine. Has anyone else had a similar oil leak problem that can let me know what to do? We are thinking about trading this in, but wanted to wait quite a bit longer before doing so. This is making me think we might have to step up our plans.
  • nypdaunypdau Member Posts: 38
    I am moving to Northwest NJ soon, which will double my commute distance, and I'd like more comfort/amenities. My Soobs seats are a wee bit firm for the grind that I am to face on route 80 each day:( Also, everyone on route 80 drives at least 80mph, and the wind noise is very pronounced at higher speeds.
    I am considering a Lexus RX-300, or a BMW3 series with AWD OR and this is a big OR, the 2003 Forester. I sat in one on the floor of the Javits yesterday, (it had leather seats:) and it felt wonderful...I am wondering how it will pan out in the reviews, Patti? :)
    Looks like a "no brainer" to me. Since $$$$ doesn't seem to enter into your equation......its got to be the Lexus RX-300!
    Its got to be apples vs apples OR go for the CAVIAR.
    Just my .02 + .01 ;)
    Oh you mean the lifted Camry? :)
    I'd go for the BMW if money wasn't an issue.
    -mike
  • hazozitahazozita Member Posts: 6
    I had an RX-300 (1999). Hated it! Granted, it was comfortable, but the handling was so-so at best, and rather scary in the snow. Plus, the turning circle is HUGE -- it was harder to park than vehicles twice the size.
    Sold it about a year ago and got a 2001 Forester S. I know what you mean about the road noise -- much louder than the RX-300. But, before you buy, take a long test drive including some twisty roads and tight parking spots.
    My wife has a BMW 330xi. If the Forester is not an option, I'd go for the BMW over the Lexus. Much better handling even in snow. The only complaint I have about the BMW is that there is no place to put all your "stuff" -- got spoiled with all the cubbies in my Subie.
  • lark6lark6 Member Posts: 2,565
    That piece conjured up some odd mental imagery...of Foresters running three-wide at Talladega!
    I still have to scratch my head at the marketing angle and demographics, though. It is clearly aimed at women in the US and Canada, but I'm not so sure that it is in the rest of the world. I picked up one of those paid-for magazine article type inserts from the UK's CAR fall 2000 which featured the Forester S turbo's prominent role in providing support to the Subaru World Rally Team (SWRT). Indeed there have been PR pics released of Foresters in SWRT livery.
    Maybe someone with a better idea of Subaru's global marketing strategy could clue us in...?
    Ed
  • odd1odd1 Member Posts: 227
    Don't mention that dog movie. All the men here are going to start thinking about the rabbit in that other movie. The mere site of that actress makes many people uneasy to this day.
    Albeit with this group the affair is a Subaru.
    That is an IROC race I'd like to see. I think they should be required to run that with all stuff for a family weekend get away in the cars. Maybe even require roof top carriers!
  • burnsmr4burnsmr4 Member Posts: 318
    I've been told that you get more for your money with the Acura MD-X than with either the BMW or the Lexus. The vehicle is similarly priced (last time I checked) and roomier. Honda/Acura reliability too.
    Not to mention the fact that I'd avoid the BMW for fear of another heater/fire recall across the BMW product line. Be sort of a bummer to get a new Bimmer only to have it catch on fire after 200 miles and melt to the ground -- no lie! It happened several times before the BMW got the recall rolling.
    Later,
    burnsmr4
    have the engine mounted in the wrong way. Also the MDX has an 8K mile differential (3 of em) oil change schedule which won't be cheap!
    -mike
  • c_hunterc_hunter Member Posts: 4,487
    Not a good choice. The quality and reliability has been below usual Honda standards, and it drives like a minivan (not surprising, considering its origins). I gave the MDX a thorough look, and it confirmed my choice of the LL Bean Outback.
    Craig
  • hayduke01hayduke01 Member Posts: 128
    After an uneventful first weekend with my Forester, I have a winner in the Favorite Accessory Competition. (The competition was actually unplanned, but the event and the winner were obvious).
    Colorado Springs has lots of microbreweries. They sell their product in half-gallon jugs (growlers). In preparing to go see some friends yesterday for an Easter dinner, I loaded a couple of growlers into the cargo net (Honorable Mention in the contest). The cargo net didn't keep the growlers upright. I didn't worry, because I knew the lids were on tight. WRONG!
    On returning home to pick up something I'd forgotten I saw that the growlers were no longer full; I saw a big puddle of beer in the back. My initial dismay turned to relief when I discovered that the cargo bin tray had contained the spill. My new Forester was safe; the carpet was safe. One of the simplest pieces of equipment imaginable had averted a minor disaster. For now at least, my Forester's still new.
    So the winner is. . . the cargo bin tray. It's easy to clean. I needed only water, Windex and a few rags. For a more severe spill, I would remove the whole thing and spray it down with a hose.
    I don't remember which feature package got me the tray or what it cost, but I'm glad that it was there. I highly recommend it.
    Great story. Just try not to get pulled over by the law until the cargo bin tray dries out, okay? ;-)
    Seriously, I like mine, too. No beer spilled in there, but lots of garden-type stuff like potting soil, mulch, fertilizer and the like. Sometimes car cleaning stuff like Windex and Simple Green, but so what? It's cleaner!
    Ed
  • peterson10peterson10 Member Posts: 116
    What in the world? If money was no object, you wouldn't be asking for informed opinions! And speaking of informed opinions: buy the '03 Forester (If I hadn't just bought an '02, I would) and send the balance of your "new-car-budget" to me. I'll invest it wisely in my daughters education, or a new fly rod, or something else more valuable than "cache". And your thrifty investment will earn dividends in the form of a car with innovative character, reassuring capability, and a reputation for quality that is the envy of the industry. BTW, I would prefer a cashier's check.
    Always happy to help,
    YetAnotherDave
  • bsvollerbsvoller Member Posts: 528
    We put a DrawTite hitch on our '01 Forester (unchanged in '02 as far as I know with regard to the hitch mount points) and it "fit like a glove" too. 7 bolts and half hour and it was on.
    I think you had the wrong part or something.
    hth
    -bv
  • jim_loves_carsjim_loves_cars Member Posts: 190
    James-
    Are you really worried about traffic on Route 80 going FAST into the city? LOL! 80 is usually a mess! If I were you I'd get something big and comfy loaded with electronics to pass the time sitting in traffic.
    How 'bout the new BMW 745 with the iDrive knob thingy. You might have time to actully figure out how it works.
    And that way you'd get to sit in traffic playing with your knob... ;-)
    -jim
    play nice... ;)
    Bob
    Must be spring in the air - the Jeep guys are talking about their wench experiences.
    Steady now :-)
    Steve
    Mike: the tray is standard. :-) I would have funneled the beer back into the growler!
    James: first off, glad you are fine after 9/11. I was wondering aloud if you were OK, peek in the Meet the Members topic to see my message.
    The new Forester is supposed to have a coefficient of drag .03 lower than the current one, which along with a stiffer structure may translate to a quieter ride. But if you can afford a Bimmer, I won't stop you.
    Patti? Is her name Glenn? Can you tell me if I'm Close, at least? :-)
    I think one guy at i Club was putting a turbo on his Forester. Check on the Forester forum there.
    -juice
  • maverick1017maverick1017 Member Posts: 212
    That's right, was it Ferretboy? anyways there was a discussion about a supplier willing to manufacture or source out turbos for the Forester and manufacture a Carbon Fiber hood w/a scoop to go with the turbo, they were working out the details of the turbo last time I checked. Haven't been back there in a while, wondering how that thing panned out...but the turbo package with the hood would run about 5k by itself, with an intercooler of course, the nice thing is the supplier is willing to offer a choice of either a front or a top mount intercooler...sweet deal if it materializes.
    Mike
    yeah, that's my favorite piece of access as well, it saved my butt more than a few times. the most recent was this past friday, had a 2+ gallon gas tank in the trunk, took a on ramp too quick, a bit too muc body roll, wham...the can tips over and gas all over the place, but the tray held all that spilled. got it cleaned up nice and easy enough...now how am i gonna get the strong smell out of the car? I aired it out the whole day Saturday, and it has gone down in deadliness a bit but man, driving for 20 minutes one way on my daily commute is a test of my bodies ability to carry oxygen.
    Mike
    I always recommend fresh ground coffee for odors. May not be enough in this case though.
    Steve
    How about a box or two of baking soda? For cover up if you can't absorb it all a couple of fresh-cut pine branches should help. And if that doesn't do it, there's always time. Good luck!
  • rkw2rkw2 Member Posts: 66
    I couldn't start my 98 forester with 75,000 miles on it last Thursday morning. I figured it was the battery. I didn't need the car for a couple of days and didn;t have time to wait for AAA t jump her. SO I tried to start it again Saturday morning. She started fine and purred like a kitten. No problems on Sat of Sun. This morning I went out and she started fine, but she first made a strange noise and it took her awhile to start (one crank but I had to hold it longer than I did in the past). I noticed this whenever I went to start the car today.
    Does anyone know what the cause might be and also the cure? Does anyone else have this probleM?
    Thanks fello subies...(98 Forester with 75 k and 1991 Legacy with 140k)
    Is it is in fact the battery. If it's the original one, I'd start there.
    -mike
    battery's cranking power depend on the temperature as well. So if thursday morning was cold, then the battery would have less cranking power than say Sat or Sun if both days were relatively warm. Since its a 98, I personally think its time to replace the battery. I replaced the one on my 98 last thanksgiving, it only had about 40K on it then. Good luck
    Mike
    >>James: first off, glad you are fine after 9/11. I was wondering aloud if you were OK, peek in the Meet the Members topic to see my message.<<
    Thanks for that! I've been remiss in not checking in more often. I actually retired from the NYPD last March (after 20 years) and am now flying corporate out of Teterboro (NJ), hence the move to NJ. Retired or not though, I volunteered to come back for the 9/11 effort, (as did hundreds of other retirees) and was picked up by an NYPD helo at Ft. Totten Queens, an hour after the towers went down. Luckily, my flightsuit still fit but there wasn't much for me to do. The retired pilots were in reserve for the anticipated scores of med-evacs, but sadly none were needed :( 14 of my former colleagues were lost from ESU. I spent 2 weeks there as my boss was stranded on Corsica.
    Anyway, glad to see the familiar names here in the Soobie Crew area.
    In answer to Petersen: It's not that I have money to burn, but since I am going to spend a lot of time in my next vehicle, I want to pass the time as comfortably as possible, as Jim says: "If I were you I'd get something big and comfy loaded with electronics to pass the time sitting in traffic."
    The question: Is the 2003 Forester that vehicle? Now that I am working in the private sector and getting a police pension as well, I can finally afford more. That being said, I bought the 01 Forester after exhaustive surfing these very pages, and was not disappointed! I will not throw $$$ at an L shaped badge unless of course, the RX-300 fits the bill. My choices are limited because I want the best blend of AWD, comfort, gadgets (kicka@# audio, etc) and of course price.
    So, I thought I had it narrowed down but now, not so sure!
    Juice: I Heard from my police friend in Pernambuco recently:)
  • allhorizonallhorizon Member Posts: 483
    James,
    Before you look at the BMW for AWD - why don't you consider an Audi A4 or A6? I am pretty sure even the VW Passat 4Motion outhandles the BMW in snow. The AWD BMW is for people who absolutely must have a BMW, but in my opinion it is not one of the better AWD vehicles around. The A4 is less expensive and in almost all ways a better car (IMO, but also according to many published reviews).
    - D.
  • grahampetersgrahampeters Member Posts: 1,786
    G'day
    Of course the really important question is what you did with the spilt beer. Did you:
    (a) get a straw and drink it
    (b) pour it back in the jar and not tell your friends
    (c) watch the entertainment as your neighbour's dog got jolly
    (d) throw it out?
    Cheers
    Graham
    Come on wed night to the Javits center with us and you'll get to check out all the cars and suvs :)
    -mike
    PS: Glad to hear you were ok after 9/11, it was a long walk for me from lower manhattan to uptown to NJ and finally back to Staten Island.
    My then-girlfriend/now-wife left a big ol' jar of "Christmas pickles" in the floorboard of my last car -- a '99 Mercury Cougar V-6. I was flinging the car around late for work one morning when the jar rolled into the front floorboard and shattered. Try getting "Christmas pickle" juice stench out of your car on your morning commute.
    Needless to say, I recently married the woman, on the condition that she limits holiday baking to things chocolate.
    Later,
    burnsmr4
  • storytellerstoryteller Member Posts: 476
    I smell a new theme coming on: stinky things that have got loose in my car. Let's not do that one!
  • nypaulnypaul Member Posts: 35
    Ha, you folks think pickles, beer or gasoline smell bad in your car? You haven't smelled a thing.
    As an aircraft mechanic I sometimes have to work with jet fuel. About 2 weeks after picking up our new Forester I wound up soaked in the stuff. Even though I washed up and changed my clothes before getting in the car to come home from work the inside of the car still smells of the jet fuel 2 weeks later. And that's despite using airfreshners and leaving the windows open at night. And that's without actually getting any of the fuel in the car. Just from the smell that was still on me.
    My wife says that in about another 2 weeks she'll let me back in the house :-)
    Paul
  • subaru_teamsubaru_team Member Posts: 1,676
    Well, Juice, I'd love to confirm how Close you are, but I will heed Allan's warning!
    Patti
  • ckirk4ckirk4 Member Posts: 11
    Does anyone have word on when the 2003 Forester will start arriving at dealerships?
  • kenskens Member Posts: 5,869
    My local dealer told me end of May for the 2003 Forester...
    Ken
    Ken is right again!
    Patti
  • goldencouple1goldencouple1 Member Posts: 209
    When my older brother was in high school he left a "school project" in the back of our Chevy...a cat he was dissecting! It was back there a couple of days, in Florida, by the way, before it made itself obvious. A) there was a furious father (my Dad had one good eye, and when he was mad, man could he use it to melt you to nothing; B) there was a very stinky car. Can't remember what Dad used to get rid of the smell, and as I remember, we got a new car about that time.
