Dodge Ram Noises and Rattles
in Dodge
My truck has 24k miles all stock and it just started making a cricket noise on the pass side.It only makes it when I'm driving,I took it to the dealer they can't fine where its coming from. Any ideas
I do apologise for this response, I just couldn't resist. I truthfully have no idea what the problem is but Happy New Year from here in the UK, anyway.
Beyond that, I can only recommend a good inspection of the under carriage for loose components or signs of damage. I suppose U-joints could produce a noise like you are describing, or maybe loose wheel lug nuts?. Over the years I've seen so many strange things cause even stranger noises it would be hard to speculate in this case.
Good luck and best regards,
Dusty
If the valve train is noisy I've seen this caused by very low oil pressure, either by sludged oil galleries or a weak oil pump. There are quite a few engines that will produce a "tick" noise when the incorrect oil filter is used, although I can't remember a 318 being affected by this.
Other possibilities are a badly worn engine mounted fuel pump or a very loose timing chain.
If the noise is a distinctive and solitary "tick" I'd be prone to suspect an exhaust leak. An exhaust leak is very often confused with a noisy lifter, and vice-versa.
Best regards,
Dusty
Best regards,
Dusty
Mike
kcram - Pickups/Wagons Host
