Oldsmobile Aurora Security System/Alarm
in Oldsmobile
I recently lost the keys to my 97 Aurora and got a new set made by the dealer. However, without the key fob, the alarm goes off for the two minutes whenever i open a door, even if the car is running. Is there a way to kill the alarm until my new fob arrives by pulling a fuse or anything? It wouldn't be such a big deal but I work in downtown Indianapolis and have to park in a public parking garage and I get looks when getting in my car as if I stole it. Thanks a ton to anyone who can help.
Clean the resistor on your key with a Q-Tip dipped in alcohol. Try to start the car.
If no luck, use the Q-Tip and gently clean the contacts in your key switch. If you look in the switch, you'll see two prongs just inside the switch, that will match up to the key resistor.
If you're still having problems, the key switch may be bad.
Two options are available... have a new switch installed or find a VATS bypass that matches the resistance of your key.
The bypass is far cheaper and is an easy install if you have basic mechanical skills.
If you have a Volt Ohm Meter, you can check the resistance and construct a home made bypass with resistors from Radio Shack.
orange wire with the two white wires in it.Could someone tell me the color for the 95
aurora plz?
Hope this helps!
Well I charged the battery first and thought I would try to start the car. When I turn the key everything goes dark. Do you think there is still some sort of computer issue with this car that it will go completely dark when the key is turned. I will install a new starter in the next day or so but really wanted your opinion first. It seems very odd and hope Im not chasing my tail. I wish there was an easier way to see if this car needs a starter because the starter is located underneath the intake manifold!
