GM Navigation system
Greetings all. I'm a Newbee here.
I have a 2007 Tahoe LTZ with the factory DVD/Navigation system. It causes a "Caution Screen" to display on the LCD to warn me about the perils of paying too much attention to the nav display while driving.
Well "OK I Get It". Now, is there any way to stop this screen from popping up every time I'm in the car? I can't find it anywhere in the owner's manual. I'm guessing there might be some undocumented feature that will let me cancel this.
Your help will be appreciated.
Tony
Tony
A software update fixed the problem. Although the warning still pops up it goes away by itself after 5 seconds or so.
Perhaps the next GM nav update will solve this problem.
Maybe a programmer will get get interested and figure a workaround and post the solution. Meanwhile I'll just keep pressing that button...
On long trips across interstates, the inability to use the touchscreen is very frustrating.
AD
How about disabling the switch that tells the computer the car is in park? I would think if you closed the contacts the nav would think you're in park. Anyone know how to do that?
http://www.coastaletech.com/gmlockpick3.htm
TOYOTA MATRIX 2003 DVD NAVIGATION
My car's DVD Navigation system CD & Navigation buttons do not respond sometimes even if I press it several times. And on certain occasions everything works fine. I checked the wire connections are all are good.
Since you had this kind of misfortune with your car could you advise me on how to get it functioning normally?
The disc is reading error and since the dvd goes in behind the gps unit (it opens on its own, slides up and out) I can't get it open. The screen keeps flashing between different codes, back to the radio, black and so on. Is there a manual way to open these things? Or another way to get the map dvd out??
GM wants $2700 for a new unit??!?!?!?!
