Ford Expedition Reprogramming the Remote
                    Someone broke into my 2000 Expedition, stole my wallet, keys etc. I have another remote here but need to Re program it.
Can anyone help?
Can anyone help?
Good luck
You need to go to your manual and read under "Keyless Entry", then, you enter the code that comes printed on your card when you bought the truck. If you had misfortune like me, I had to remove the right front kick panel and search for the "keyless entry module" that has the code printed right on it. On my 2003 Expedition, that is how it is. On some older FORD vehicles, the code is actually printed on the tailgate on the edge somewhere (only visible if you open the gate". Either way, once you get that "master code", you enter it, and then in your manual, it tells you what key to enter first, following that, you can now enter a new (your own) code. i hope that helps. Google is always helpful too.
thank you
matt
No in 2001 that was the design. I think it may have been as late as 04 or 05 when they made them to work with the car running.
